My board says Nano V3 on it.
When I try to load the code onto the board, my options are Nano, Nano 33 and Nano 32. If I click on Nano, I can chose between ATmega328p, ATmega328p (old bootloader) and ATmega168.
I don't see V3 anywhere. Is my board outdated or should I select one of the options above?
Any help is appreciated.
Dave
The first attempt was done using Arduinos online.
I just downloaded the Arduino software and tried again and am left with an error message which can be seen in the screenshot below.
Any idea as to what I did wrong?
Yes, chose Nano >> ATmega328p
if that doesn't work then chose Nano >> ATmega328p (old bootloader)
one of those 2 should work. usually the old bootloader.
It is possible to burn a new boot loader if desired
The "programmer not responding" error is often a bad USB cable they often send with clone Nano's it's a very common issue. try another cable.
PS, I have a Mac, if it matters. These are my port options:
Sweet. Will do and report back in a minute or so
using a known good cable?
Yea, it's a verified cable. It's saying "error uploading, check if the board is currently available"
in your screenshot of the error above you can see a button that says "Copy error messages" hit that and paste the new error message here.
You may need to install the CH340 driver on your Mac.
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Nano, ATmega328P"
Sketch uses 2016 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 49 bytes (2%) of dynamic memory, leaving 1999 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
Great idea! A driver might be it! I'll search the forums for installation instructions and will report back
@BitSeeker may be right I forgot about that one
It was the CH340 Driver. Thank you for solving my problem. Solution accepted.
