Okay, I tried a few rate change. Keep in mind that I'm not a programmer so I'm having some difficulty.
The first problem is the call to the HttpClient.h library
So another library calls me and gives me errors.
I changed to ArduinoHttpClient.h and this part is solved.
Then I used the wifinina library instead of Ethernet and applied the changes to the code which I'm not sure about but everything seems to be fine.
Compile, no mistake.
Loading on arduino, no errors.
Arduino connects via wifi, then to the web server. Find the file, check it and start the download. Here hangs in half for time out.
Check for update file /update-v2.bin
Update status code: 200
Server returned update file of size 42484 bytes
Timeout downloading update file at 6865 bytes. Can't continue with update.
the code:
This example downloads sketch update over network.
It doesn't start the OTA upload sever of the ArduinoOTA library,
it only uses the InternalStorage object of the library
to store and apply the downloaded binary file.
To create the bin file for update, use in Arduino IDE command
"Export compiled binary".
To try this example, you should have a web server where you put
the binary update.
Modify the constants below to match your configuration.
Created for ArduinoOTA library in February 2020
by Juraj Andrassy
#include <WiFiNINA.h>
#include <ArduinoOTA.h>
#include <ArduinoHttpClient.h> // changed from HttpClient.h
#include "arduino_secrets.h"
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
int status = WL_IDLE_STATUS;
const short VERSION = 1;
#define Serial SerialUSB
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
void handleSketchDownload() {
const char* SERVER = "192.168.103.179"; // must be string for HttpClient
const unsigned short SERVER_PORT = 8080;
const char* PATH = "/update-v%d.bin";
const unsigned long CHECK_INTERVAL = 5000;
static unsigned long previousMillis;
if (currentMillis - previousMillis < CHECK_INTERVAL)
return;
// EthernetClient transport;
WiFiClient transport;
HttpClient client(transport, SERVER, SERVER_PORT);
char buff[32];
snprintf(buff, sizeof(buff), PATH, VERSION + 1);
Serial.print("Check for update file ");
Serial.println(buff);
client.get(buff);
int statusCode = client.responseStatusCode();
Serial.print("Update status code: ");
Serial.println(statusCode);
if (statusCode != 200) {
client.stop();
return;
int length = client.contentLength();
if (length == HttpClient::kNoContentLengthHeader) {
client.stop();
Serial.println("Server didn't provide Content-length header. Can't continue with update.");
return;
Serial.print("Server returned update file of size ");
Serial.print(length);
Serial.println(" bytes");
if (!InternalStorage.open(length)) {
client.stop();
Serial.println("There is not enough space to store the update. Can't continue with update.");
return;
byte b;
while (length > 0) {
if (!client.readBytes(&b, 1)) // reading a byte with timeout
InternalStorage.write(b);
length--;
InternalStorage.close();
client.stop();
if (length > 0) {
Serial.print("Timeout downloading update file at ");
Serial.println(" bytes. Can't continue with update.");
return;
Serial.println("Sketch update apply and reset.");
Serial.flush();
InternalStorage.apply(); // this doesn't return
//Initialize serial and wait for port to open:
while (!Serial) {
Serial.print("Sketch version ");
Serial.println(VERSION);
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
printCurrentNet();
printWifiData();
// check for updates
handleSketchDownload();
// add your normal loop code below ...
void printWifiData() {
// Stampa del indirizzo IP
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// Stampa del MAC Address
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
Serial.println(bytesToMACAddress(mac));
// Stampa dei dati di connessione: SSID, BSSID, RSSI e Criptazione
void printCurrentNet() {
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
Serial.println(bytesToMACAddress(bssid));
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
// Costruzione del MAC Address
String getMACAddress() {
byte mac[6];
return bytesToMACAddress(mac);
String bytesToMACAddress(byte mac[]) {
String m = "";
for (int i = 5; i >= 0; i--) {
m = m + byeToHex(mac[i]);
if (i > 0) {
m = m + ":";
return m;
String byeToHex(byte b) {
if (b < 16) {
return "0" + String(b, HEX);
return String(b, HEX);
