Download code from a Arduino Board to Arduino Soft
Hi every one.
It might be a stupid quetsion but you know what people say. There is no stupid questions.
Anyway I can't remember which of my boards have which code on it.
I don't want to look at all my programs and guess which one is the right one and then overwrite the precious code on the board.
So is it possible to download ( decompile? ) the code from the board to the arduino software. Maybe there is a anti-Arduino that transform machine code to Human code.
Thanksssssssssssssssssssssssssssssssss :slight_smile:
You can do something like this using avrdude
avrdude -D -p m168 -c stk500 -P $port -U flash:r:$filename: -v -v -b 19200
to read the flash on your ATmega168 and write it to a file on your computer
You'll have to adjust the settings for your system
I'm not sure if there's a decompiler but you can save your .hex files and corresponding binaries and keep track of their checksums to figure out which program is loaded on a chip.
:slight_smile:
avrdude -F -v -v -v -v -pm168 -cstk500v1 -P/dev/ttyUSB0 -b19200 -D -Uflash:r:program.bin:r
will write the data from the ATmega168 to program.bin on a Linux system using /dev/ttyUSB0 as the USB port at 19200bps
This was tested and seems to work
:slight_smile:
I looked for a "how to install avrdude" on mac and that looks complicate. I've put the avrDude folder in my home directory and tried your command line but that didn't work. I added sudo but it gave me a warning, so I am not really sure if I should do this.
I am going to try it on linux tomorrow as it might be simpler and I don't mind messing around the linux computer as I have nothing on it.
Thank you for helping me.
I am not sure about the Mac but you can easily install avrdude on most Linux systems.
On yum systems => yum install avrdude
On apt-get systems => apt-get install avrdude
This usually takes just a couple of minutes.
Ubuntu and Fedora both have avrdude and avr-gcc packages and since they offer live CDs you can install it on just about any computer with internet access without having to install the OS.
:slight_smile:
Great!, I've got Ubuntu 8.4 installed so that you should pretty straight forward then.
sudo su -
should do the trick then :slight_smile:
Ubuntu has the following packages =>
avr-libc (1:1.4.7-1) [universe]
Standard C library for Atmel AVR development
avra (1.2.2-1) [universe]
Assembler for Atmel AVR microcontrollers
avrdude (5.5-1) [universe]
software for programming Atmel AVR microcontrollers
avrdude-doc (5.5-1) [universe]
documentation for avrdude
avrp (1.0beta3-6) [universe]
Programmer for Atmel AVR microcontrollers
avrprog (0.2.1-14) [universe]
The full list is here Ubuntu – Error
avrdude is part of the OS X Arduino install.
--Phil.
