Downloading index: package_esp8266com_index.json never ends???
What OS, what were you doing? Missing 99.99999% of the information needed.
Windows 11.
I started IDE, the download message popped up and since yesterday evening, no progress.
You’re a lot more patient than me. I’d have closed the IDE and rebooted my PC long ago!
Do you have access to the internet?
I did it another time, and message came back.
Are you connected to the internet? Is your system clock 100% accurate?
Yes all of the above.
It happened in the past, just not for that long, and always jason.
Show me the actual error, do NOT interpret. Post the full error in code tags.
Does it look like this
https://arduino.esp8266.com/stable/package_esp8266com_index.json
Hi @mikemarcu. I'm going to ask you to provide the logs that Arduino IDE prints when you start it from the command line terminal. It is possible they will contain a clue that might help us to identify the cause of the problem.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Select File > Quit from the Arduino IDE menus if it is running.
All Arduino IDE windows will close. - Start Windows "File Explorer".
- Open the Arduino IDE installation folder.
ⓘ The default installation location is at one of the following paths:-
C:\Program Files\Arduino IDE -
(whereC:\Users\<username>\AppData\Local\Programs\Arduino IDE<username>is your Windows username)
If looking for it with your file manager or command line, note that the AppDatafolder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
- In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
A context menu will open. - Select "Open PowerShell window here" from the menu.
Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder. - Type the following command in the PowerShell window:
& ".\Arduino IDE" - Press the Enter key.
Debug output should now be printed to the PowerShell window as Arduino IDE starts. - Wait for Arduino IDE to finish starting.
- Switch back to the PowerShell window.
- Press the Ctrl+Shift+A keyboard shortcut.
This will select all the text in the PowerShell window. - Press the Ctrl+C keyboard shortcut.
This will copy the contents of the PowerShell window to the clipboard. - Open a reply here on this forum topic by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press the Ctrl+V keyboard shortcut.
This will paste the output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to publish the post.
Please let us know if you have any questions or problems while following those instructions.
PS C:\Users\mikem\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
& : The term '.\Arduino IDE' is not recognized as the name of a cmdlet, function, script file, or operable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:3
+ & ".\Arduino IDE"
+ CategoryInfo : ObjectNotFound: (.\Arduino IDE:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\Users\mikem\AppData\Local\Programs\Arduino IDE> & '.\Arduino IDE'
At line:1 char:3
+ & '.\Arduino IDE'
It appears that Arduino IDE is installed at some location on your computer other than C:\Users\mikem\AppData\Local\Programs\Arduino IDE
Did you check to see if you have a folder at the alternative default location?:
Yes, it it in C:\Program Files
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.5
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.5" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.2.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-04-02T13:16:49.885Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"theia"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.5","cliVersion":"1.2.0","buildDate":"2025-04-02T13:16:49.885Z"}
Starting backend process. PID: 19396
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/mikem/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-06-23T12:59:48.004Z root INFO Backend u.initialize: 42.6 ms [Finished 0.873 s after backend start]
2025-06-23T12:59:48.005Z root INFO Backend Object.initialize: 40.4 ms [Finished 0.873 s after backend start]
2025-06-23T12:59:48.006Z root INFO Backend a.initialize: 2.3 ms [Finished 0.873 s after backend start]
2025-06-23T12:59:48.006Z root INFO Backend a.initialize: 1.9 ms [Finished 0.873 s after backend start]
2025-06-23T12:59:48.006Z root INFO Backend u.initialize: 2.4 ms [Finished 0.873 s after backend start]
2025-06-23T12:59:48.009Z root INFO Backend l.initialize: 42.4 ms [Finished 0.875 s after backend start]
2025-06-23T12:59:48.019Z root INFO configured all backend app contributions
2025-06-23T12:59:48.020Z root INFO Backend l.onStart: 2.0 ms [Finished 0.891 s after backend start]
2025-06-23T12:59:48.020Z root INFO Backend d.onStart: 0.1 ms [Finished 0.891 s after backend start]
2025-06-23T12:59:48.021Z root INFO Backend a.onStart: 0.5 ms [Finished 0.892 s after backend start]
2025-06-23T12:59:48.021Z config INFO >>> Initializing CLI configuration...
2025-06-23T12:59:48.021Z root INFO Backend x.onStart: 0.5 ms [Finished 0.892 s after backend start]
2025-06-23T12:59:48.022Z config INFO Loading CLI configuration from c:\Users\mikem\.arduinoIDE\arduino-cli.yaml...
2025-06-23T12:59:48.022Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-06-23T12:59:48.022Z root INFO Backend w.onStart: 0.5 ms [Finished 0.893 s after backend start]
2025-06-23T12:59:48.022Z discovery-log INFO start
2025-06-23T12:59:48.022Z discovery-log INFO start new deferred
2025-06-23T12:59:48.022Z root INFO Backend v.onStart: 0.3 ms [Finished 0.893 s after backend start]
2025-06-23T12:59:48.022Z root INFO Backend a.onStart: 0.1 ms [Finished 0.893 s after backend start]
2025-06-23T12:59:48.029Z root INFO Theia app listening on http://127.0.0.1:59788.
2025-06-23T12:59:48.029Z root INFO Finished starting backend application: 7.2 ms [Finished 0.901 s after backend start]
2025-06-23T12:59:48.029Z root WARN The local plugin referenced by local-dir:/c%3A/Users/mikem/.arduinoIDE/deployedPlugins does not exist.
2025-06-23T12:59:48.029Z root WARN The local plugin referenced by local-dir:/c%3A/Users/mikem/.arduinoIDE/plugins does not exist.
Restoring workspace roots: c:\Users\mikem\Documents\esp8266-weather-station-color\esp8266-weather-station-color
2025-06-23T12:59:48.029Z root WARN The local plugin referenced by local-dir:C:\Users\mikem\.arduinoIDE\plugins does not exist.
2025-06-23T12:59:48.034Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json"]},"directories":{"builtin":{"libraries":"C:\\Users\\mikem\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\mikem\\AppData\\Local\\Arduino15","user":"c:\\Users\\mikem\\OneDrive\\Documents\\Arduino"},"locale":"en"}
2025-06-23T12:59:48.034Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-06-23T12:59:48.034Z config INFO Loaded the CLI configuration.
2025-06-23T12:59:48.053Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/mikem/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/mikem/OneDrive/Documents/Arduino","additionalUrls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json"],"network":"none","locale":"en"}
2025-06-23T12:59:48.053Z config INFO Validating the CLI configuration...
2025-06-23T12:59:48.054Z config INFO The CLI config is valid.
2025-06-23T12:59:48.054Z config INFO <<< Initialized the CLI configuration.
isTempSketch: false. Input was c:\Users\mikem\Documents\esp8266-weather-station-color\esp8266-weather-station-color\esp8266-weather-station-color.ino
2025-06-23T12:59:48.112Z root INFO Resolve plugins list: 88.3 ms [Finished 0.984 s after backend start]
2025-06-23T12:59:48.149Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="arduino-cli version 1.2.0"
2025-06-23T12:59:48.149Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Using config file: c:\\Users\\mikem\\.arduinoIDE\\arduino-cli.yaml"
2025-06-23T12:59:48.149Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Executing `arduino-cli daemon`"
2025-06-23T12:59:48.168Z daemon INFO Daemon is now listening on 127.0.0.1:59789
{"IP":"127.0.0.1","Port":"59789"}
2025-06-23T12:59:48.168Z daemon INFO Daemon is running.
2025-06-23T12:59:48.238Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Checking signature" index="c:\\Users\\mikem\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\mikem\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2025-06-23T08:59:48-04:00" level=info msg="Missing signature file" index="c:\\Users\\mikem\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
time="2025-06-23T08:59:48-04:00" level=info msg="Loading hardware from: c:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages"
time="2025-06-23T08:59:48-04:00" level=info msg="Loading package arduino from: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2025-06-23T08:59:48-04:00" level=info msg="Missing signature file" index="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2025-06-23T08:59:48-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-06-23T08:59:48-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-06-23T08:59:48-04:00" level=info msg="Loading tools from dir: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-06-23T08:59:48-04:00" level=info msg="Loading package builtin from: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2025-06-23T08:59:48-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-06-23T08:59:48-04:00" level=info msg="Loading tools from dir: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
time="2025-06-23T08:59:48-04:00" level=info msg="Loading package esp8266 from: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2025-06-23T12:59:48.245Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Missing signature file" index="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json"
2025-06-23T12:59:48.271Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-06-23T08:59:48-04:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
2025-06-23T12:59:48.271Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2025-06-23T08:59:48-04:00" level=info msg="Loading tools from dir: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2025-06-23T12:59:48.272Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
2025-06-23T12:59:48.273Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2025-06-23T12:59:48.273Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
2025-06-23T12:59:48.273Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2025-06-23T12:59:48.314Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-06-23T12:59:48.317Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
time="2025-06-23T08:59:48-04:00" level=info msg="Loading libraries index file" index="c:\\Users\\mikem\\AppData\\Local\\Arduino15\\library_index.json"
2025-06-23T12:59:48.991Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-06-23T12:59:48.991Z daemon INFO time="2025-06-23T08:59:48-04:00" level=info msg="Adding libraries dir" dir="c:\\Users\\mikem\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-06-23T12:59:50.012Z root INFO creating connection for 1
2025-06-23T12:59:51.740Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 391.6 ms [Finished 3.676 s after frontend start]
2025-06-23T12:59:52.057Z root WARN A command editor.action.toggleStickyScroll is already registered.
Opening channel for service path '/services/electron-window'.
2025-06-23T12:59:52.439Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 652.0 ms [Finished 4.362 s after frontend start]
2025-06-23T12:59:52.528Z root INFO Start frontend contributions: 1319.3 ms [Finished 4.451 s after frontend start]
2025-06-23T12:59:52.528Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-06-23T12:59:52.537Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-06-23T12:59:52.538Z root INFO >>> Restoring the layout state...
2025-06-23T13:00:02.467Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192) starting instance
2025-06-23T13:00:02.492Z root INFO [hosted-plugin: 21192] [Object: null prototype] {}
2025-06-23T13:00:02.796Z root INFO Deploy plugins list: 14771.6 ms [Finished 15.667 s after backend start]
2025-06-23T13:00:02.802Z root INFO [c214daeb-e059-4b92-8bb9-eef38ba1597e] Waiting for backend deployment: 10291.5 ms [Finished 14.737 s after frontend start]
2025-06-23T13:00:03.677Z daemon INFO time="2025-06-23T09:00:03-04:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from c:\\Users\\mikem\\OneDrive\\Documents\\Arduino\\libraries\\DFR0126-master: invalid library: no header files found"
2025-06-23T13:00:03.689Z discovery-log INFO start resolved watching
2025-06-23T13:00:03.719Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\mikem\Documents\esp8266-weather-station-color\esp8266-weather-station-color\esp8266-weather-station-color.ino>, response: <c:\Users\mikem\Documents\esp8266-weather-station-color\esp8266-weather-station-color>.
2025-06-23T13:00:04.044Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM8","label":"COM8","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x6001"],["serialNumber","B0028G0FA"],["vid","0x0403"]],"hardwareId":"B0028G0FA"}},"error":""}
2025-06-23T13:00:04.045Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-06-23T13:00:04.046Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM7","label":"COM7","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]],"hardwareId":""}},"error":""}
2025-06-23T13:00:04.046Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM6","label":"COM6","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]],"hardwareId":""}},"error":""}
2025-06-23T13:00:04.743Z root INFO [c214daeb-e059-4b92-8bb9-eef38ba1597e] Sync of 23 plugins: 1943.5 ms [Finished 16.680 s after frontend start]
2025-06-23T13:00:04.823Z root INFO ------- SERIALIZED LAYOUT DATA -------
2025-06-23T13:00:04.823Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/esp8266-weather-station-color.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":47,\"column\":1},\"position\":{\"lineNumber\":47,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":93,\"column\":1},\"firstPositionDeltaTop\":-2},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":865,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/ArialRounded.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":882,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/CONTRIBUTING.md"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":74,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/README.md"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":41,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/TZinfo.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":3,\"column\":1},\"firstPositionDeltaTop\":-12},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":475,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/TouchControllerWS.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":109,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/TouchControllerWS.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":36,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/moonphases.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":429,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/settings.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":76,\"column\":46},\"position\":{\"lineNumber\":76,\"column\":46}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":69,\"column\":1},\"firstPositionDeltaTop\":-8},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":117,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/weathericons.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":3801,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/SunMoonCalc.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":140,\"column\":1},\"position\":{\"lineNumber\":140,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":112,\"column\":1},\"firstPositionDeltaTop\":-17},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":140,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/OpenWeatherMapCurrent.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":120,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/OpenWeatherMapForecast.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":131,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/mikem/Documents/esp8266-weather-station-color/esp8266-weather-station-color/SunMoonCalc-a.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":11,\"column\":1},\"firstPositionDeltaTop\":-10},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":140,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":8}},"mainPanelPinned":[false,false,false,false,false,false,false,false,false,false,false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":227,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"multiline\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2025-06-23T13:00:04.824Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2025-06-23T13:00:06.154Z root INFO <<< The layout has been successfully restored.
2025-06-23T13:00:06.557Z root INFO Initialize the workbench layout: 13617.5 ms [Finished 18.091 s after frontend start]
2025-06-23T13:00:06.560Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-06-23T13:00:06.560Z root INFO [c214daeb-e059-4b92-8bb9-eef38ba1597e] Loading plugin contributions
2025-06-23T13:00:06.560Z root INFO [c214daeb-e059-4b92-8bb9-eef38ba1597e] Load contributions of 23 plugins: 398.3 ms [Finished 18.492 s after frontend start]
2025-06-23T13:00:06.648Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-06-23T13:00:06.649Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2025-06-23T13:00:07.136Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
2025-06-23T13:00:07.137Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
2025-06-23T13:00:07.137Z root ERROR [hosted-plugin: 21192] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-06-23T13:00:07.153Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): PluginManagerExtImpl/init()
2025-06-23T13:00:07.528Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-arduino-api@0.1.2 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.635Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(json-language-features@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.643Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.644Z root INFO [hosted-plugin: 21192] Debugger contribution has been registered: cortex-debug
2025-06-23T13:00:07.657Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-arduino-tools@0.1.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.664Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(cpp@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.666Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(json@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.668Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.671Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-cs@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.673Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-de@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.675Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-es@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.681Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-fr@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.683Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.685Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-it@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.687Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-ja@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.688Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-ko@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.689Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.691Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-pl@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.693Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-pt-BR@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.695Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-ru@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.696Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-tr@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.698Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.700Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-zh-hans@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.701Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): initializing(vscode-language-pack-zh-hant@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-06-23T13:00:07.756Z root INFO Frontend application start: 16036.6 ms [Finished 20.628 s after backend start]
2025-06-23T13:00:07.790Z root INFO Replace loading indicator with ready workbench UI (animation): 952.8 ms [Finished 19.449 s after frontend start]
2025-06-23T13:00:07.790Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-06-23T13:00:07.790Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-06-23T13:00:07.840Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\node\jsonClientMain)
2025-06-23T13:00:07.932Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2025-06-23T13:00:08.001Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-06-23T13:00:08.002Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-06-23T13:00:08.003Z daemon INFO time="2025-06-23T09:00:07-04:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-06-23T09:00:07-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-06-23T09:00:07-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-06-23T13:00:08.005Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
calling activation function on VS Code Arduino Tools
calling activation function on Arduino IDE API for VS Code extensions
2025-06-23T13:00:08.337Z root ERROR ---- !!!SLOW!!! DURATION: search took 546.656 ms. Args: [{"type":"Updatable"}] ----
2025-06-23T13:00:08.339Z root INFO [c214daeb-e059-4b92-8bb9-eef38ba1597e] Starting plugins.
2025-06-23T13:00:08.348Z daemon INFO time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="esp8266:python3@3.7.2-post1"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2025-06-23T09:00:08-04:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-06-23T13:00:08.349Z root ERROR Failed to get debug config: esp8266:esp8266:d1_mini:baud=921600,xtal=80,eesz=4M2M,dbg=Disabled,lvl=None____,ip=lm2f,vt=flash,exception=disabled,stacksmash=disabled,wipe=none,ssl=all,mmu=3232,non32xfer=fast, undefined Error: Debugging is not supported.
at Object.callback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:3962465)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:6679373)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:2572294)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:2571739)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:4307911
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2025-06-23T13:00:08.351Z root INFO [hosted-plugin: 21192] PLUGIN_HOST(21192): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-06-23T13:00:08.766Z root INFO [hosted-plugin: 21192] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-06-23T13:00:08.766Z root INFO [hosted-plugin: 21192] calling activation function on Cortex-Debug
2025-06-23T13:00:08.771Z root INFO [hosted-plugin: 21192] GDB server console created
2025-06-23T13:00:08.794Z root INFO [hosted-plugin: 21192] calling activation function on JSON Language Features (built-in)
2025-06-23T13:00:08.794Z root INFO [c214daeb-e059-4b92-8bb9-eef38ba1597e] Start of 23 plugins: 2232.5 ms [Finished 20.730 s after frontend start]
2025-06-23T13:00:08.816Z root INFO [c214daeb-e059-4b92-8bb9-eef38ba1597e] Waiting for backend deployment: 20.9 ms [Finished 20.754 s after frontend start]
2025-06-23T13:00:08.816Z root INFO [c214daeb-e059-4b92-8bb9-eef38ba1597e] Loading plugin contributions
2025-06-23T13:00:08.836Z root INFO Starting language server: esp8266:esp8266:d1_mini:baud=921600,xtal=80,eesz=4M2M,dbg=Disabled,lvl=None____,ip=lm2f,vt=flash,exception=disabled,stacksmash=disabled,wipe=none,ssl=all,mmu=3232,non32xfer=fast
2025-06-23T13:00:09.988Z daemon INFO time="2025-06-23T09:00:09-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-06-23T13:00:09.989Z daemon INFO time="2025-06-23T09:00:09-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
2025-06-23T13:00:09.989Z daemon INFO time="2025-06-23T09:00:09-04:00" level=info msg="Adding libraries dir" dir="c:\\Users\\mikem\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-06-23T13:00:11.011Z daemon INFO time="2025-06-23T09:00:11-04:00" level=info msg="Updating index" url="http://arduino.esp8266.com/stable/package_esp8266com_index.json"
2025-06-23T13:00:11.013Z daemon INFO time="2025-06-23T09:00:11-04:00" level=info msg="Starting download" url="http://arduino.esp8266.com/stable/package_esp8266com_index.json"
2025-06-23T13:00:11.015Z root INFO core-client-provider [platform-index] Downloading index: package_esp8266com_index.json
2025-06-23T13:00:20.640Z daemon INFO time="2025-06-23T09:00:20-04:00" level=info msg="Checking signature" index="c:\\Users\\mikem\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\mikem\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-06-23T13:00:20.802Z daemon INFO time="2025-06-23T09:00:20-04:00" level=info msg="Missing signature file" index="c:\\Users\\mikem\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
2025-06-23T13:00:20.802Z daemon INFO time="2025-06-23T09:00:20-04:00" level=info msg="Loading hardware from: c:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages"
2025-06-23T13:00:20.803Z daemon INFO time="2025-06-23T09:00:20-04:00" level=info msg="Loading package arduino from: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2025-06-23T13:00:20.949Z daemon INFO time="2025-06-23T09:00:20-04:00" level=info msg="Missing signature file" index="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2025-06-23T13:00:21.247Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-06-23T09:00:21-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2025-06-23T13:00:21.247Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-06-23T09:00:21-04:00" level=info msg="Loading tools from dir: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2025-06-23T13:00:21.248Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2025-06-23T13:00:21.249Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-06-23T13:00:21.249Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2025-06-23T13:00:21.250Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loading package builtin from: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\builtin"
2025-06-23T13:00:21.251Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-06-23T09:00:21-04:00" level=info msg="Loading tools from dir: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-06-23T13:00:21.252Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2025-06-23T13:00:21.252Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-06-23T13:00:21.253Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2025-06-23T13:00:21.253Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2025-06-23T13:00:21.254Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
2025-06-23T13:00:21.255Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loading package esp8266 from: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2025-06-23T13:00:21.286Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Missing signature file" index="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json"
2025-06-23T13:00:21.564Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-06-23T09:00:21-04:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
2025-06-23T13:00:21.564Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2025-06-23T09:00:21-04:00" level=info msg="Loading tools from dir: C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2025-06-23T13:00:21.565Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
2025-06-23T13:00:21.565Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2025-06-23T13:00:21.565Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
2025-06-23T13:00:21.566Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2025-06-23T13:00:21.594Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2025-06-23T13:00:21.599Z daemon INFO time="2025-06-23T09:00:21-04:00" level=error msg="Waiting discovery process termination: exit status 1" discovery="builtin:mdns-discovery"
time="2025-06-23T09:00:21-04:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
time="2025-06-23T09:00:21-04:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:mdns-discovery"
2025-06-23T13:00:21.599Z daemon INFO time="2025-06-23T09:00:21-04:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2025-06-23T13:00:21.600Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM7","label":"COM7","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[],"hardwareId":""}},"error":""}
2025-06-23T13:00:21.601Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM6","label":"COM6","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[],"hardwareId":""}},"error":""}
2025-06-23T13:00:21.601Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM8","label":"COM8","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[],"hardwareId":""}},"error":""}
2025-06-23T13:00:21.602Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-06-23T13:00:21.606Z daemon INFO time="2025-06-23T09:00:21-04:00" level=error msg="Waiting discovery process termination: exit status 1" discovery="builtin:serial-discovery"
time="2025-06-23T09:00:21-04:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
2025-06-23T13:00:21.606Z daemon INFO time="2025-06-23T09:00:21-04:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:serial-discovery"
2025-06-23T13:00:22.275Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM8","label":"COM8","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x6001"],["serialNumber","B0028G0FA"],["vid","0x0403"]],"hardwareId":"B0028G0FA"}},"error":""}
2025-06-23T13:00:22.276Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-06-23T13:00:22.277Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM7","label":"COM7","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]],"hardwareId":""}},"error":""}
2025-06-23T13:00:22.278Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM6","label":"COM6","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]],"hardwareId":""}},"error":""}
2025-06-23T13:00:22.403Z daemon INFO time="2025-06-23T09:00:22-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-06-23T13:00:22.406Z daemon INFO time="2025-06-23T09:00:22-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
time="2025-06-23T09:00:22-04:00" level=info msg="Loading libraries index file" index="c:\\Users\\mikem\\AppData\\Local\\Arduino15\\library_index.json"
2025-06-23T13:00:22.940Z daemon INFO time="2025-06-23T09:00:22-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-06-23T13:00:22.940Z daemon INFO time="2025-06-23T09:00:22-04:00" level=info msg="Adding libraries dir" dir="c:\\Users\\mikem\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-06-23T13:00:22.947Z daemon INFO time="2025-06-23T09:00:22-04:00" level=info msg="Resolving include SPI.h for arch esp8266"
time="2025-06-23T09:00:22-04:00" level=info msg=" found better lib" lib=SPI prio=6B0
2025-06-23T13:00:24.496Z daemon INFO time="2025-06-23T09:00:24-04:00" level=info msg="Resolving include ESP8266WiFi.h for arch esp8266"
2025-06-23T13:00:24.497Z daemon INFO time="2025-06-23T09:00:24-04:00" level=info msg=" found better lib" lib=ESP8266WiFi prio=6B0
2025-06-23T13:00:25.737Z daemon INFO time="2025-06-23T09:00:25-04:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from c:\\Users\\mikem\\OneDrive\\Documents\\Arduino\\libraries\\DFR0126-master: invalid library: no header files found"
2025-06-23T13:00:26.064Z daemon INFO time="2025-06-23T09:00:26-04:00" level=info msg="Resolving include XPT2046_Touchscreen.h for arch esp8266"
2025-06-23T13:00:26.065Z daemon INFO time="2025-06-23T09:00:26-04:00" level=info msg=" found better lib" lib="ThingPulse XPT2046 Touch" prio=3EB
2025-06-23T13:00:27.804Z daemon INFO time="2025-06-23T09:00:27-04:00" level=info msg="Resolving include JsonListener.h for arch esp8266"
2025-06-23T13:00:27.804Z daemon INFO time="2025-06-23T09:00:27-04:00" level=info msg=" found better lib" lib="Json Streaming Parser" prio=3EB
2025-06-23T13:00:28.940Z daemon INFO time="2025-06-23T09:00:28-04:00" level=info msg="Resolving include OpenWeatherMapCurrent.h for arch esp8266"
time="2025-06-23T09:00:28-04:00" level=info msg=" found better lib" lib=OpenWeatherMapCurrent prio=6A7
2025-06-23T13:00:30.040Z daemon INFO time="2025-06-23T09:00:30-04:00" level=info msg="Resolving include OpenWeatherMapForecast.h for arch esp8266"
2025-06-23T13:00:30.040Z daemon INFO time="2025-06-23T09:00:30-04:00" level=info msg=" found better lib" lib=OpenWeatherMapForecast prio=6A7
2025-06-23T13:00:31.148Z daemon INFO time="2025-06-23T09:00:31-04:00" level=info msg="Resolving include MiniGrafx.h for arch esp8266"
time="2025-06-23T09:00:31-04:00" level=info msg=" found better lib" lib="Mini Grafx" prio=3F5
2025-06-23T13:01:16.785Z daemon INFO time="2025-06-23T09:01:16-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-06-23T13:01:16.786Z daemon INFO time="2025-06-23T09:01:16-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mikem\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
2025-06-23T13:01:16.786Z daemon INFO time="2025-06-23T09:01:16-04:00" level=info msg="Adding libraries dir" dir="c:\\Users\\mikem\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
NOW the error disappeared.
Thanks for the update! Even though it is not as satisfying as finding an explanation for the problem, I guess we can be happy enough that the problem is no longer occurring.
If it comes back later, let us know and we'll see if we are able to investigate further.
The Arduino developers are already tracking the problem of the index download process sometimes hanging or taking an exceptionally long time, so your report has been formally noted:
Regards, Per
Thank you,
