Hey guys. I have a project going on where I'm trying to operate a sawmill with a phone app which I've created in MIT App Inventor. The mill has various motions that are controlled with electric motors or Hydraulic cylinders that are controlled by a SainSmart 16 relay module and a Mega2560 board via an HC05 BT module. My code is looking for a value of "A,a,B,b...etc." sent from my Android phone to control the various operations on the machine. This part seems to be working ok, except an occasional freezing of the Mega. I also have an Adafruit light ring to tell me the status of the machine. Blue for connected, amber for not connected and red for emergency stop mode.
My only guess for why the Mega is freezing is excessive current draw from a solenoid that controls a hydraulic lift. Although, if it were drawing more than the rated 10amps of the relay module, I would assume I would have a burned board. I believe the starter relay is only pulling around 3 amps. Does anyone have any experience with the Mega freezing? And, what am I doing wrong to cause it? It seems like the Arduino freezes right around the time I'm using the hydraulic pump.
Next issue, I'm using a Calt pull cable encoder to measure the thickness of wood i'm cutting. It's mounted to a carriage where the engine and saw blade sit and is raised and lowered with the hydraulic pump.
It's specs are:
Measuring Range :0~1000mm
Detection method : Incremental encoder
Revolution:0.1mm/pulse Rope :wire rope 0.6mm dia, Plastic coated wire rope ,rope maximum load: 16KG
Supply Voltage :5-26V Dc
Signals output : Pushpull with A B Z 3 channels
I'm getting the readings fine on my lcd display and on the phone but with the engine running the encoder is bouncing around so much that I can hardly tell at what position I'm located. Is there a simple way to change the sensitivity or how often it's displaying said reading so I can actually read the numbers? Or, is that a bad implementation of the encoder altogether?
Please keep in mind I'm very green to the Arduino world but I've tried to fumble my way thru to get an operational prototype machine. I know my code isn't up to many people's expectations but hopefully some sense can be made of it. Any help would be greatly appreciated. I'm including my entire code so hopefully someone will see an obvious error.
#include <Wire.h>
#include <AccelStepper.h>
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
char Incoming_value = 'A,a,B,b,C,c,D,d,E,e,F,f,G,g,H,h,J,j,K,k,L,l,M,m,N,n,P,p,Q,q,R,r,Z'; // Values to be received from smartphone app via HC-05 BT module.
//Motor functions will be operated with directional buttons within MIT App Inventor App and send values to Arduino Uno board.
//Sainsmart 16 module relay board has 12v power connected as well as jumpers from Mega2560 to Relay module.
volatile signed int temp, counter = 0; //This variable will increase or decrease depending on the rotation of encoder
int Distance = (counter * 0.0019685039370079);
String inputs;
#define relay1 45 //Connect relay1 to pin 30
#define relay2 44 //Connect relay2 to pin 31
#define relay3 43 //Connect relay3 to pin 32
#define relay4 42 //Connect relay4 to pin 33
#define relay5 41 //Connect relay5 to pin 34
#define relay6 40 //Connect relay6 to pin 35
#define relay7 39 //Connect relay7 to pin 36
#define relay8 38 //Connect relay8 to pin 37
#define relay9 37 //Connect relay9 to pin 38
#define relay10 36 //Connect relay10 to pin 39
#define relay11 35 //Connect relay11 to pin 40
#define relay12 34 //Connect relay12 to pin 41
#define relay13 33 //Connect relay13 to pin 42
#define relay14 32 //Connect relay13 to pin 43
#define relay15 31 //Connect relay13 to pin 44
#define relay16 30 //Connect relay13 to pin 45
bool BTState = false;
bool Emer_Stop = false;
//LED LIGHTS__________________________________________________________________________________________________
// Pattern types supported:
enum pattern { NONE, RAINBOW_CYCLE, THEATER_CHASE, COLOR_WIPE, SCANNER, FADE };
// Pattern directions supported:
enum direction { FORWARD, REVERSE };
// NeoPattern Class - derived from the Adafruit_NeoPixel class
class NeoPatterns : public Adafruit_NeoPixel
public:
// Member Variables:
pattern ActivePattern; // which pattern is running
direction Direction; // direction to run the pattern
unsigned long Interval; // milliseconds between updates
unsigned long lastUpdate; // last update of position
uint32_t Color1, Color2, Color3, Color4; // What colors are in use
uint16_t TotalSteps; // total number of steps in the pattern
uint16_t Index; // current step within the pattern
void (*OnComplete)(); // Callback on completion of pattern
// Constructor - calls base-class constructor to initialize strip
NeoPatterns(uint16_t pixels, uint8_t pin, uint8_t type, void (*callback)())
:Adafruit_NeoPixel(pixels, pin, type)
OnComplete = callback;
// Update the pattern
void Update()
if((millis() - lastUpdate) > Interval) // time to update
lastUpdate = millis();
switch(ActivePattern)
case RAINBOW_CYCLE:
RainbowCycleUpdate();
case THEATER_CHASE:
TheaterChaseUpdate();
case COLOR_WIPE:
ColorWipeUpdate();
case SCANNER:
ScannerUpdate();
case FADE:
FadeUpdate();
default:
// Increment the Index and reset at the end
void Increment()
if (Direction == FORWARD)
Index++;
if (Index >= TotalSteps)
Index = 0;
if (OnComplete != NULL)
OnComplete(); // call the comlpetion callback
else // Direction == REVERSE
--Index;
if (Index <= 0)
Index = TotalSteps-1;
// Reverse pattern direction
void Reverse()
Direction = REVERSE;
Direction = FORWARD;
Index = 0;
// Initialize for a RainbowCycle
void RainbowCycle(uint8_t interval, direction dir = FORWARD)
ActivePattern = RAINBOW_CYCLE;
Interval = interval;
TotalSteps = 255;
Index = 0;
Direction = dir;
// Update the Rainbow Cycle Pattern
void RainbowCycleUpdate()
for(int i=0; i< numPixels(); i++)
setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
show();
Increment();
// Initialize for a Theater Chase Theater Chase
void TheaterChase(uint32_t color2, uint32_t color3, uint8_t interval, direction dir = FORWARD)
ActivePattern = THEATER_CHASE;
TotalSteps = numPixels();
Color2 = color2;
Color3 = color3;
Index = 0;
Direction = dir;
// Update the Theater Chase Pattern
void TheaterChaseUpdate()
if ((i + Index) % 2 == 0)
setPixelColor(i, Color2);
setPixelColor(i, Color3);
show();
Increment();
// Initialize for a ColorWipe
void ColorWipe(uint32_t color, uint8_t interval, direction dir = FORWARD)
ActivePattern = COLOR_WIPE;
Color1 = color;
Index = 0;
Direction = dir;
// Update the Color Wipe Pattern
void ColorWipeUpdate()
setPixelColor(Index, Color1);
show();
Increment();
// Initialize for a SCANNNER
void Scanner(uint32_t color2, uint8_t interval)
ActivePattern = SCANNER;
TotalSteps = (numPixels() - 1) * 2;
Color2 = color2;
Index = 0;
// Update the Scanner Pattern
void ScannerUpdate()
for (int i = 0; i < numPixels(); i++)
if (i == Index) // Scan Pixel to the right
else if (i == TotalSteps - Index) // Scan Pixel to the left
else // Fading tail
setPixelColor(i, DimColor(getPixelColor(i)));
show();
Increment();
// Initialize for a Fade
void Fade(uint32_t color1, uint32_t color2, uint16_t steps, uint8_t interval, direction dir = FORWARD)
ActivePattern = FADE;
TotalSteps = steps;
Color1 = color1;
Color2 = color2;
Index = 0;
Direction = dir;
// Update the Fade Pattern
void FadeUpdate()
// Calculate linear interpolation between Color1 and Color2
// Optimise order of operations to minimize truncation error
uint8_t red = ((Red(Color1) * (TotalSteps - Index)) + (Red(Color2) * Index)) / TotalSteps;
uint8_t green = ((Green(Color1) * (TotalSteps - Index)) + (Green(Color2) * Index)) / TotalSteps;
uint8_t blue = ((Blue(Color1) * (TotalSteps - Index)) + (Blue(Color2) * Index)) / TotalSteps;
ColorSet(Color(red, green, blue));
show();
Increment();
// Calculate 50% dimmed version of a color (used by ScannerUpdate)
uint32_t DimColor(uint32_t color)
// Shift R, G and B components one bit to the right
uint32_t dimColor = Color(Red(color) >> 1, Green(color) >> 1, Blue(color) >> 1);
return dimColor;
// Set all pixels to a color (synchronously)
void ColorSet(uint32_t color)
setPixelColor(i, color);
show();
// Returns the Red component of a 32-bit color
uint8_t Red(uint32_t color)
return (color >> 16) & 0xFF;
// Returns the Green component of a 32-bit color
uint8_t Green(uint32_t color)
return (color >> 8) & 0xFF;
// Returns the Blue component of a 32-bit color
uint8_t Blue(uint32_t color)
return color & 0xFF;
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos)
WheelPos = 255 - WheelPos;
if(WheelPos < 85)
return Color(255 - WheelPos * 3, 0, WheelPos * 3);
else if(WheelPos < 170)
WheelPos -= 85;
return Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
void Ring1Complete();
//void Ring2Complete();
//void StickComplete();
// Define some NeoPatterns for the two rings and the stick
// as well as some completion routines
NeoPatterns Ring1(48, 7, NEO_GRB + NEO_KHZ800, &Ring1Complete);
//NeoPatterns Ring2(16, 6, NEO_GRB + NEO_KHZ800, &Ring2Complete);
//NeoPatterns Stick(16, 7, NEO_GRB + NEO_KHZ800, &StickComplete);
// Define a stepper and the pins it will use
AccelStepper stepper(1,9,8); //ENABLE PIN 13, PULSE PIN 9, DIRECTION PIN 8
void setup(){
Ring1.begin();
Ring1.TheaterChase(Ring1.Color(0,10,100), Ring1.Color(0,0,50), 100);
lcd.init(); // initialize the lcd
lcd.init();
// Print a message to the LCD.
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("----Wood Militia----");
lcd.setCursor(0,1);
lcd.print("Let's Cut Some Wood!");
lcd.setCursor(0,2);
lcd.print("*Wood Militia 2021*");
lcd.setCursor(0,3);
lcd.print("Prgm. By Trent Wadle");
delay(4000);
lcd.clear();
delay(250);
lcd.setCursor(0,0);
lcd.print("Wood Miliita I-Mill");
lcd.setCursor(0,1);
lcd.print("---Blade Position---");
lcd.setCursor(9,2);
lcd.print(": Inches");
Serial.begin (9600);
pinMode(6, INPUT);
pinMode(2, INPUT_PULLUP); // internal pullup input pin 2
pinMode(3, INPUT_PULLUP); // internal pullup input pin 3
//Setting up interrupt
//A rising pulse from encoder activated ai0(). AttachInterrupt 0 is DigitalPin 2 on Arduino.
attachInterrupt(0, ai0, RISING);
//B rising pulse from encodenren activated ai1(). AttachInterrupt 1 is DigitalPin 3 on Arduino.
attachInterrupt(1, ai1, RISING);
pinMode(relay1, OUTPUT); //Set pins as outputs
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(relay5, OUTPUT);
pinMode(relay6, OUTPUT);
pinMode(relay7, OUTPUT);
pinMode(relay8, OUTPUT);
pinMode(relay9, OUTPUT);
pinMode(relay10, OUTPUT);
pinMode(relay11, OUTPUT);
pinMode(relay12, OUTPUT);
pinMode(relay13, OUTPUT);
pinMode(relay14, OUTPUT);
pinMode(relay15, OUTPUT);
pinMode(relay16, OUTPUT);
digitalWrite(relay1, HIGH); //Switch relay1 off
digitalWrite(relay2, HIGH); //Swtich relay2 off
digitalWrite(relay3, HIGH); //Switch relay3 off
digitalWrite(relay4, HIGH); //Swtich relay4 off
digitalWrite(relay5, HIGH); //Switch relay5 off
digitalWrite(relay6, HIGH); //Swtich relay6 off
digitalWrite(relay7, HIGH); //Switch relay7 off
digitalWrite(relay8, HIGH); //Swtich relay8 off
digitalWrite(relay9, HIGH); //Swtich relay9 off
digitalWrite(relay10, HIGH); //Swtich relay10 off
digitalWrite(relay11, HIGH); //Swtich relay11 off
digitalWrite(relay12, HIGH); //Swtich relay12 off
digitalWrite(relay13, HIGH); //Swtich relay13 off
digitalWrite(relay14, HIGH); //Swtich relay14 off
digitalWrite(relay15, HIGH); //Swtich relay15 off
digitalWrite(relay16, HIGH); //Swtich relay16 off
//Stepper Configuration_______________________________________
stepper.setMaxSpeed(1000.0);
stepper.setAcceleration(900.0);
stepper.runToNewPosition(500);
Ring1.Update();
byte Distance = (counter * 0.0019685039370079);
if (digitalRead(6) == HIGH)
BTState=true;
Ring1.Color2 = (0,0,255);
//Ring1.Color2 = (0,255,255);
//Ring1.ColorSet(Ring1.Color(0,0,255));
//Ring1.Interval = 300;
//Ring1.TheaterChase(Ring1.Color(0,10,100), Ring1.Color(0,0,50), 100);
//Ring1.ActivePattern = SCANNER;
//Ring1.Interval = 10;
//Ring1.Update();
Ring1.ActivePattern = FADE;
Ring1.Interval = 2;
else {
BTState=false;
lcd.setCursor(0,3);
lcd.print(" BT DISCONNECTED ");
//Ring1.TheaterChase(Ring1.Color(255,204,0), Ring1.Color(204,51,0),200);
//Ring1.Color1 = (255,150,0);
//Ring1.Color2 = (255,250,0);
//Ring1.Interval = 100;
//Ring1.Update();
//Ring1.show();
Ring1.TheaterChase(Ring1.Color(244,100,0), Ring1.Color(255,245,75), 18);
//Ring1.Interval = 22;
Ring1.Update();
if ((Serial.available() > 0) && (BTState == true));
Incoming_value = Serial.read(); //Using If Function to switch relays on/off.
if(Incoming_value == 'A')
digitalWrite(relay1, LOW);
//Serial.println("Engine Starting");
lcd.setCursor(2,3);
lcd.print("Engine Starting");
else if(Incoming_value == 'a')
//Serial.println("Engine Start Released");
lcd.setCursor(2,3);
lcd.print(" ");//End of Relay
else if(Incoming_value == 'B')
digitalWrite(relay2, LOW);
//Serial.println("Engine Relay Engaged");
else if(Incoming_value == 'b')
//Serial.println("Engine Relay Disengaged"); //End of Relay
else if(Incoming_value == 'C')
stepper.setMaxSpeed(720);
stepper.setAcceleration(672);
stepper.runToNewPosition(384);
stepper.stop();
//Serial.println("Engine High Rpm");
lcd.setCursor(2,3);
lcd.print("Engine High RPM");
else if(Incoming_value == 'c')
stepper.runToNewPosition(0);
stepper.stop();
//Serial.println("Engine Low Rpm"); //End of Relay
lcd.setCursor(2,3);
else if(Incoming_value == 'D')
digitalWrite(relay4, LOW);
//Serial.println("Carriage Going Up");
lcd.setCursor(2,3);
lcd.print("Carriage Going Up");
else if(Incoming_value == 'd')
//Serial.println("Carriage Stopped"); //End of Relay
lcd.setCursor(2,3);
else if(Incoming_value == 'E')
digitalWrite(relay5, LOW);
//Serial.println("Carriage Going Down");
lcd.setCursor(0,3);
lcd.print("Carriage Going Down");
else if(Incoming_value == 'e')
lcd.setCursor(0,3);
else if(Incoming_value == 'F')
digitalWrite(relay12, LOW);
//Serial.println("Blade Adjust Moving In");
lcd.setCursor(3,3);
lcd.print("Blade Guide In");
else if(Incoming_value == 'f')
//Serial.println("Blade Adjust Stopped"); //End of Relay
lcd.setCursor(3,3);
else if(Incoming_value == 'G')
digitalWrite(relay11, LOW);
//Serial.println("Blade Adjust Moving Out");
lcd.setCursor(2,3);
lcd.print("Blade Guide Out");
else if(Incoming_value == 'g')
lcd.setCursor(2,3);
else if(Incoming_value == 'H')
digitalWrite(relay7, LOW);
//Serial.println("Carriage Traverse FWD");
lcd.setCursor(2,3);
lcd.print("Carriage FWD Cut");
else if(Incoming_value == 'h')
//Serial.println("Carriage Traverse Stopped"); //End of Relay
lcd.setCursor(2,3);
else if(Incoming_value == 'J')
digitalWrite(relay8, LOW);
//Serial.println("Carriage Traverse REV");
lcd.setCursor(2,3);
lcd.print("Carriage Return");
else if(Incoming_value == 'j')
lcd.setCursor(2,3);
else if(Incoming_value == 'K')
digitalWrite(relay14, LOW);
//Serial.println("Backstop Raise");
lcd.setCursor(2,3);
lcd.print("Backstop Raising");
else if(Incoming_value == 'k')
//Serial.println("Backstop Paused"); //End of Relay
lcd.setCursor(2,3);
else if(Incoming_value == 'L')
digitalWrite(relay13, LOW);
//Serial.println("Backstop Lower");
lcd.setCursor(1,3);
lcd.print("Backstop Lowering");
else if(Incoming_value == 'l')
//Serial.println("Backstop Pause"); //End of Relay
lcd.setCursor(1,3);
else if(Incoming_value == 'M')
digitalWrite(relay6, LOW);
//Serial.println("Blade Engaged");
lcd.setCursor(2,3);
lcd.print("Blade Engaged");
else if(Incoming_value == 'm')
//Serial.println("Blade Disengaged"); //End of Relay
lcd.setCursor(2,3);
else if(Incoming_value == 'N')
digitalWrite(relay10, LOW);
//Serial.println("Coolant On");
else if(Incoming_value == 'n')
//Serial.println("Coolant Off"); //End of Relay
else if(Incoming_value == 'P')
digitalWrite(relay3, LOW);
//Serial.println("Choke ON");
lcd.setCursor(2,3);
lcd.print("Choke ON");
else if(Incoming_value == 'p')
//Serial.println("Choke OFF");
lcd.setCursor(2,3);
lcd.print("Choke OFF");
else if(Incoming_value == 'Q')
digitalWrite(relay15, LOW);
//Serial.println(" ");
else if(Incoming_value == 'q')
digitalWrite(relay15, HIGH); //End of Relay
else if(Incoming_value == 'S')
digitalWrite(relay16, LOW);
else if(Incoming_value == 's')
digitalWrite(relay16, HIGH); //End of Relay
else if(Incoming_value == 'R')
counter= 0;
lcd.setCursor(0,3);
lcd.print(" Encoder Reset ");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(9,2);
else if(Incoming_value == 'r')
lcd.setCursor(0,3);
lcd.print(" ");
else if(Incoming_value == 'Z')
Ring1.clear();
Emer_Stop= true;
lcd.setCursor(0,3);
lcd.print(" EMERGENCY STOP ");
// Ring1.TheaterChase(Ring1.Color(255,20,0), Ring1.Color(255,0,0),200);
//Ring1.Update();
//Ring1.show();
// delay(2000);
else if(Incoming_value != 'Z')
Emer_Stop= false;
lcd.setCursor(0,3);
lcd.print(" ");
//strip.clear();
//Ring1.Update();
// Ring1.show();
//Ring1.TheaterChase(Ring1.Color(0,0,255), Ring1.Color(0,150,255), 200);
if (Emer_Stop == true)
Ring1.TheaterChase(Ring1.Color(244,0,0), Ring1.Color(255,50,0), 18);
Ring1.Update();
delay(20000);
else (Emer_Stop = false);
float Dim = counter*0.0019685039370079;
// Send the value of counter
if( counter != temp ){
//Serial.println ("Board Thickness");
//Serial.print("\n");
lcd.setCursor(4,2);
lcd.print(Dim, 2);
Serial.println (Dim);
//Serial.println ("Inches");
temp = counter;
char letters[] = "aAbBcCdDeEfFgGhHiIjJkKlLmMnNoOpPqQrR";
void ai0() {
// ai0 is activated if DigitalPin nr 2 is going from LOW to HIGH
// Check pin 3 to determine the direction
if(digitalRead(3)==LOW) {
counter++;
}else{
counter--;
void ai1() {
// ai0 is activated if DigitalPin nr 3 is going from LOW to HIGH
// Check with pin 2 to determine the direction
if(digitalRead(2)==LOW) {
counter--;
}else{
counter++;
Ring1.Reverse();
