I'm moderately new to electronics and i have a question about my current project.
I have an arduino micro powered by a 6 AA battery pack to VIN. I use the arduino to drive a bluetooth shield (chinese €6 board) and an M5450 current sink through the 5V regulated output. I as use those 5v to drive up to 35 leds (3v, 20mA) using the m5450 as a driver/sink.
My prototype did not connect more that 20 leds now, that worked.
My question is: can I continue to drive all leds from the arduino regulator or do i need to add an external regulator to power the leds? I have an lm7805 here somewhere...
Thank you for your time to help me out!
Use the rule of thumb:
Put your thumb on the Arduino regulator. If it's hot, use an external regulator.
The regulator is only rated for 800mA.
35mA * 20 = 700mA, plus some current for the Arduino. How much does the bluetooth need?
Here's a m5450 datasheet I found.
Maybe regulator is not even needed for the LEDs, just run from 6V and change the current limit resistor for the brightness desired.
M5450 STM LED driver.pdf (145 KB)
CrossRoads:
Thanks, i'll take that road!
CrossRoads:
Success! I've finished the board without the extra regulator and powered the leds directly from the battery. Thanks
