I need to drive 9 seven-segments displays (which are numitron tubes, actually). The typical supply voltage is 4.5V and each segment needs about 20mA. I plan to multiplex them to save microcontroller outputs. But I'm having a hard time finding the right IC given the sheer number of varieties available on Farnell/Mouser (I'm not even sure in which category to look :~).
I need ordinary 3-inputs, 8-output logic chips with the right current/voltage requirements (nothing fancy). I also need general-purpose transistors to use as switches (to cycle between the anodes). Could you direct me to models suitable for my project ?
If I understand correctly, this one works with a serial input. This means I'll need several serial pins if I want to lit more than one tube at a time (and with 9 tubes, this could produce a lot of flicker). I'm rather looking for a chip like the SN7414 (used for Nixies), with logic inputs, but for seven-segments display.
