You can probably get-by with a constant-current driver. I think most cheap laser pointers work that way. Some may even work like cheap LED flashlights, relying on battery resistance to limit current, but I don't know...
But a proper laser driver uses the 3rd "feedback" pin on the laser diode to monitor the actual light-output and keep it constant and controlled for maximum efficiency. ...Constant-controlled light output instead of constant current or constant electrical power.
I assume he's wiring the LM317 as a constant current driver. (It's normally a voltage regulator, putting-out constant voltage.)
With the correct constant-current source the voltage across an LED or laser "magically falls into place" because, with a diode, the resistance varies with current (or voltage).
A constant current supply or driver works the opposite of a regular power supply... With nothing connected you get the maximum available voltage as it tries to "push" current through infinite resistance, but no current flows with nothing connected.
If you short-out a constant-current power supply it puts-out the desired current at (nearly) zero voltage. It's OK to short a "properly-designed" constant-current supply, but I really don't know if the LM317 will survive... It depends on the voltage supplied to it, and the current through it.
...If you short-out a normal constant-current power supply (zero resistance), you get excess current and "bad things" can happen.
1 looks same as 2 and 3
2 and 3 are from same seller
if i searching for whole module (laser & driver) 850nm up to 1000mW uses drivers as in 1,2,3, but based on this driver desciprions they can handle more then 1000mW, so which driver is fit my laser diode? im a bit confused with that.
There is no datasheets, it seems like this are same PCB (1,2,3), i mean its china, a lot of manufactures produce same things
and this module, has almost same pcb
The LM317 is a linear voltage regulator, wired to give constant current, its flaw is the the voltage that is dropped across the regulator to provide the desired current causes losses.
These losses are HEAT, to much heat and the LM317 FAILS.
First you will need a CONSTANT CURRENT driver, set it to the 2.5A that your laser needs, or lower.
The LED will drop a voltage across it, the driver will keep the current set to what you desire independent of the voltage drop.
They are switchmode drivers, very efficient.
This YouTube video is very good to explain about laser and CC drivers.
None of those
They are all the same and are intended for blue-green LASERs, which have a significantly higher operating voltage than your IR LASER
Where do you measure this voltage?
Does the diode need to be connected when you adjust the voltage?
What do you adjust the voltage to, the min, typical, max?
Will it go low enough?
I assume that LD should be disconnected and i can measure it on LD +- pads, based on @DVDdoug comment
Updated @anon95813201 - seems like i was right (video) about this drivers - they can change voltage, but still you are right about minimum voltage of this drivers, it can be 3V for example.
Also based on your example with 1000 diodes - if we dont know exact voltage & current, then how driver know it? i mean in case you said there typ & max is based on avg of 1000 diodes), and they are not exact as in datasheet. Even with propper driver i need to know atleast required current for diode.
I own this one, and found description in ali, it says that it can be used as LED driver, so that means it can be used for laser diode too? Same process of adjustmens as in video i sent above, a bit lower max output current, but still same driver called (laser diode driver) with same max current, cost 10x more, and difference seems to me is only that laser special driver has TTL & fan pins.
