Hey guys,
Beginner here, so please excuse any stupid questions. :-/ I just finished assembling the motor shield kit from Adafruit. I'm trying to get a 6V DC motor running. I've read the tutorial on using it but there are just a few things I am confused about. It says to use two external power sources (one for the Arduino, and one for the motor) for best performance. I am using a 9V power supply to power the Arduino, but I am not sure what to use to power the DC motor. The Adafruit site says this:
If you would like to have 2 seperate DC power supplies for the Arduino and motors. Plug in the supply for the Arduino into the DC jack, and connect the motor supply to the PWR_EXT block. Make sure the jumper is removed from the motor shield.
If you have a Diecimila Arduino, set the Arduino jumper to EXT. This is a suggested method of powering your motor project!
I am wondering about what type of power supply to use. It also says this:
the EXT_PWR terminals on the shield do not have a protection diode (for a fairly good reason). Be utterly careful not to plug it in backwards or you will destroy the motor shield and/or your Arduino!
What does it mean that it does not have a protection diode? Does this mean I can only use an exact 6v power supply? Again, I am sorry for such basic questions. I am still in the process of learning.
I have also seen a picture where the motor shield has a servo, dc motor, and a stepper all plugged in and the only power supply is connected into the Ardunio DC jack. What power supply would this be possibly with? Again, I am only trying to power a 6v DC motor, so could I potentially just use a 9v power supply plugged into the DC jack to power the Arduino and the DC motor?
Thanks in advance for the help!
