Drone Tracking Project
Does it note that the Federal Government is the primary user, and that amateur radio operation must accept interference from the primary user and cannot cause interference to the primary user? In addition, all other users must accept interference from higher users and must not cause interference to those other users.
No, the primary users are HAM users. The secondary users are non-government applications including remote control and packet radio users. Garage door openers, keyfob remotes, and Arduino compatible data transmitters use 433 MHz. The secondary users are limited to low power transmissions unlikely to interfere with Amateur Radio communications.
Wrong. The military has radar that operates in that band. Just a few years ago the Government notified the Amature repeater operators in the mountains around White Sands NM that they had to move all their repeaters to locations far away that would not interfere with operations in the White Sands area. And they all moved!
Did you look at the Federal Communications Commission document that I linked earlier? The 400-450MHz section of the entire spectrum table spans 3 pages. Between the international and US footnotes, there are many more applicable pages. My reading of the official document shows 410-450 MHz is assigned to Amateur Radio Operators.
Your evidence has no relevance whatsoever to the primary user of the 70cm Amateur Radio band. Also worth noting, White Sands New Mexico is specifically designated in the FCC spectrum table as a special restrictions area. Civilians are expressly forbidden from transmitting any signal that may interfere with government operations there. Requiring Amateur Radio repeaters be moved further away has nothing to do with the government being the primary user of those frequencies. It has everything to do with the location. This is evidenced by the Amateur Radio Repeaters continuing to operate on the same frequencies, but further away from White Sands.
Edit: Paul_KD7HB, I am disappointed with both of your comments regarding the 70cm HAM band and the additional authorized transmissions within the band. HAM callsign KD7HB registered with the FCC as Paul ___ with the Amateur Radio Extra (highest level) license effective as of 2018 has me expecting familiarity with FCC regulations especially relating to Amateur Radio frequency bands. Further, asserting that the US military operates radar on Amateur Radio 70cm frequencies really has me concerned.
Additionally, when I initially responded in this topic, I expected 433MHz Arduino compatible transmitters and their legal status in the US to be well known here. Including a US based company webpage link explaining how their products are legal in the USA didn’t seem necessary. Included it for the convenience of anyone wanting to verify the information. Would Adafruit links have been better received?
