DRV8876 overheating problems
Here's an improved English translation of the text:
Hello everyone,
I hope you're doing well. I find myself in a situation with the DRV8876 component and I'm hoping you can help me. Thank you in advance.
Components:
  • DRV8876
  • ESP32
  • 12V DC Motor
  • Power supply
Objective: First, to control the motor's PWM from the code, and then to move on to a second challenge, which is to control the output current from the code.
Setup:
  • GND: common
  • VM pin of the DRV8876 connected to the power source (this pin is responsible for powering the motors) with an initial voltage of 5V
  • VIN pin (responsible for powering the driver) with an initial voltage of 5V
Situation/Problem: When making the connections as shown in the image, there's a high current spike even though it's only 5V. Despite the DRV8876 being capable of handling more, it's also heating up significantly. I'm not sure what could be causing this.
Note: The circuit doesn't have any external components to protect against overheating.
sorry for the bad translation, I don't speak the language well
escribe o pega el códigoconst int PH_PIN = 22;   // Pin PH del DRV8876
const int EN_PIN = 23;   // Pin EN del DRV8876
int pwmValue = 0;        // Valor inicial del PWM (0-255)
  // Configurar los pines como salidas
  pinMode(PH_PIN, OUTPUT);
  pinMode(EN_PIN, OUTPUT);
  // Inicializar comunicación serial
  Serial.println("Ingrese un valor de PWM (0-255):");
  // Verificar si hay datos disponibles en el monitor serial
  if (Serial.available() > 0) {
    // Leer el valor ingresado en el monitor serial
    int input = Serial.parseInt();
    // Validar que el valor esté en el rango permitido (0-255)
    if (input >= 0 && input <= 255) {
      pwmValue = input;
      Serial.print("Valor PWM actualizado a: ");
      Serial.println(pwmValue);
      // Actualizar el valor PWM en el pin EN
      analogWrite(EN_PIN, pwmValue);
      // Opcional: puedes ajustar la dirección del motor aquí si lo deseas
      // digitalWrite(PH_PIN, HIGH); // Dirección 1
      // digitalWrite(PH_PIN, LOW);  // Dirección 2
      Serial.println("Por favor, ingrese un valor válido entre 0 y 255.");
} aquí
¿Si subes el tema al foro en español porqué pones el texto en inglés?
Intenta agregando un capacitor de digamos 470uf 16V junto al driver del motor, en la entrada Vmotor.
Las fotos son lindas pero no sirven, un simple esquema es mucho mejor para nosotros.
Mano alzada, capturas y subes
Esto con esto, caja indicando driver piripipi modelo XYZ se entiende?
Conexiones de la fuente aunque las imaginamos.
Moderador
Porque pensó que basta con poner el cuerpo del post en inglés y tendría respuestas, pero si un solo comentario esta en español (y hay demasiados) saltan las alarmas y es derivado sin juicio previo a este Foro.
Para la próxima, si quieres postear algo en el foro en inglés todo absolutamente todo en inglés
Ahora agrega por favor sin borrar el texto en inglés un comentario en español. Deja las dos versiones del comentario introductorio, inglés/español.
Gracias.
