I managed to get the Time Date set and to stop it from resetting it every time I run the program.
Now I am interested in only certain parts of the TimeDate.
I do not find the variable that say denotes the Hours although I opened the .cpp file and the it has this
"t.hr = hourFromRegisterValue(readIn());" I assume this is the Hour variable, but when I put it into the example code that comes with the library "#include <DS1302.h>" it gives me the following error.
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Herman\Documents\Arduino\libraries\DS1302" "C:\Users\Herman\AppData\Local\Temp\arduino_build_173247\sketch\1302clockHR.ino.cpp" -o "C:\Users\Herman\AppData\Local\Temp\arduino_build_173247\sketch\1302clockHR.ino.cpp.o"
C:\Users\Herman\My Scetches\1302clockHR\1302clockHR.ino: In function 'void loop()':
1302clockHR:77:16: error: 'hr' was not declared in this scope
Serial.print(hr());
Multiple libraries were found for "DS1302.h"
Used: C:\Users\Herman\Documents\Arduino\libraries\DS1302
Using library DS1302 in folder: C:\Users\Herman\Documents\Arduino\libraries\DS1302 (legacy)
exit status 1
// Example sketch for interfacing with the DS1302 timekeeping chip.
// Copyright (c) 2009, Matt Sparks
// All rights reserved.
// http://quadpoint.org/projects/arduino-ds1302
#include <stdio.h>
#include <DS1302.h>
namespace {
// Set the appropriate digital I/O pin connections. These are the pin
// assignments for the Arduino as well for as the DS1302 chip. See the DS1302
// datasheet:
// http://datasheets.maximintegrated.com/en/ds/DS1302.pdf
const int kCePin = 5; // Chip Enable
const int kIoPin = 6; // Input/Output
const int kSclkPin = 7; // Serial Clock
// Create a DS1302 object.
DS1302 rtc(kCePin, kIoPin, kSclkPin);
String dayAsString(const Time::Day day) {
switch (day) {
case Time::kSunday: return "Sunday";
case Time::kMonday: return "Monday";
case Time::kTuesday: return "Tuesday";
case Time::kWednesday: return "Wednesday";
case Time::kThursday: return "Thursday";
case Time::kFriday: return "Friday";
case Time::kSaturday: return "Saturday";
return "(unknown day)";
void printTime() {
// Get the current time and date from the chip.
Time t = rtc.time();
// Name the day of the week.
const String day = dayAsString(t.day);
// Format the time and date and insert into the temporary buffer.
char buf[50];
snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d",
day.c_str(),
t.yr, t.mon, t.date,
t.hr, t.min, t.sec);
// Print the formatted string to serial so we can see the time.
Serial.println(buf);
} // namespace
// Initialize a new chip by turning off write protection and clearing the
// clock halt flag. These methods needn't always be called. See the DS1302
// datasheet for details.
//rtc.writeProtect(false);
//rtc.halt(false);
// Make a new time object to set the date and time.
// Sunday, September 22, 2013 at 01:38:50.
//Time t(2013, 9, 22, 1, 38, 50, Time::kSunday);
// Set the time and date on the chip.
//rtc.time(t);
// Loop and print the time every second.
printTime();
Serial.print(hr());
I trust I have included all relevant info.
