I've tried everything I can think of (with my limited knowledge), and I can't seem to get the dayOfWeek value to work with my SWITCH function. I'm creating an INT called whatDayIsIt. When I print this to check on the INT, it's completely different than the dayOfWeek number. Usual whatDayIsIt returns 10 regardless of the dayOfWeek number returned. Any suggestions? Thanks!
This is an Arduino library for the Adafruit Thermal Printer.
Pick one up at --> http://www.adafruit.com/products/597
These printers use TTL serial to communicate, 2 pins are required.
Adafruit invests time and resources providing this open source code.
Please support Adafruit and open-source hardware by purchasing products
from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
MIT license, all text above must be included in any redistribution.
// If you're using Arduino 1.0 uncomment the next line:
#include "SoftwareSerial.h"
// If you're using Arduino 23 or earlier, uncomment the next line:
//#include "NewSoftSerial.h"
#include "Adafruit_Thermal.h"
#include "adalogo.h"
#include "adaqrcode.h"
#include <avr/pgmspace.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
int printer_RX_Pin = 5; // This is the green wire
int printer_TX_Pin = 6; // This is the yellow wire
int buttonState = 0; // variable for reading the pushbutton status
const int buttonPin = 2; // the number of the pushbutton pin
char* dayName[] = {"Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"};
Adafruit_Thermal printer(printer_RX_Pin, printer_TX_Pin);
void setup(){
#ifdef AVR
Wire.begin();
#else
Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
#endif
rtc.begin();
DateTime now = rtc.now();
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(__DATE__, __TIME__));
pinMode(7, OUTPUT); digitalWrite(7, LOW); // To also work w/IoTP printer
printer.begin();
// The following function calls are in setup(), but do not need to be.
// Use them anywhere! They're just here so they're run only one time
// and not printed over and over.
// Some functions will feed a line when called to 'solidify' setting.
// This is normal.
int whatDayIsIt = (now.dayOfWeek(), DEC);
printer.println("Date/Time placed into fridge:");
printer.justify('C');
printer.setSize('L');
printer.boldOn();
printer.println(now.dayOfWeek(), DEC);
printer.println(whatDayIsIt);
switch (whatDayIsIt) {
case 0:
printer.println(dayName[0]);
case 1:
printer.println(dayName[1]);
case 2:
printer.println(dayName[2]);
case 3:
printer.println(dayName[3]);
case 4:
printer.println(dayName[4]);
case 5:
printer.println(dayName[5]);
case 6:
printer.println(dayName[6]);
printer.boldOff();
printer.print(now.month(), DEC);
printer.print('/');
printer.print(now.day(), DEC);
printer.print('/');
printer.print(now.year(), DEC);
printer.println(' ');
printer.print(now.hour(), DEC);
printer.print(':');
printer.print(now.minute(), DEC);
printer.print(':');
printer.print(now.second(), DEC);
printer.println();
printer.println();
printer.println();
printer.sleep(); // Tell printer to sleep
printer.wake(); // MUST call wake() before printing again, even if reset
printer.setDefault(); // Restore printer to defaults
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// calculate a date which is 2 days
DateTime future (now.unixtime() + 2 * 86400L);
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
printer.boldOn();
printer.println("Toss after this Date/Time:");
printer.print(future.month(), DEC);
printer.print('/');
printer.print(future.day(), DEC);
printer.print('/');
printer.print(future.year(), DEC);
printer.print(future.hour(), DEC);
printer.print(':');
printer.print(future.minute(), DEC);
printer.print(':');
printer.print(future.second(), DEC);
printer.println();
printer.println();
printer.println();
