in peoples opinion is it more efficient to query the Registers or employ another Library
It isn't an either/or question. The mechanism for talking to the RTC IS the Wire library. The question is what data do you get from the RTC. Obviously, getting numeric data is more efficient than getting ASCII data, in terms of the number of bytes that have to be transferred.
MarkS1964:
So my question is,
in peoples opinion is it more efficient to query the Registers or employ another Library (Wire.h).
Here's how I do it:
#include <Wire.h>
byte ss=0, mi=0, hh=0, wd=6, dd=1, mo=1, yy=0;
Wire.begin();
// clear /EOSC bit
// Sometimes necessary to ensure that the clock
// keeps running on just battery power. Once set,
// it shouldn't need to be reset but it's a good
// idea to make sure.
// Wire.beginTransmission(0x68); // address DS3231
// Wire.write(0x0E); // select register
// Wire.write(0b00011100); // write register bitmap, bit 7 is /EOSC
// Wire.endTransmission();
// ask RTC for the time
// send request to receive data starting at register 0
Wire.beginTransmission(0x68); // 0x68 is DS3231 device address
Wire.write((byte)0); // start at register 0
Wire.requestFrom(0x68, 7); // request seven bytes (ss, mi, hh, wd, dd, mo, yy)
// check for a reply from the RTC, and use it if we can
if (Wire.available() >= 7) {
// if we're here, we got a reply and it is long enough
// so now we read the time
ss = bcd2bin(Wire.read()); // get seconds
mi = bcd2bin(Wire.read()); // get minutes
hh = bcd2bin(Wire.read()); // get hours
wd = bcd2bin(Wire.read());
dd = bcd2bin(Wire.read());
mo = bcd2bin(Wire.read());
yy = bcd2bin(Wire.read());
// show that we successfully got the time
Serial.print("Got the time: ");
printTime();
else {
// if we're here, that means we were unable to read the time
Serial.println("Unable to read time from RTC");
byte bcd2bin(byte x) {
// converts from binary-coded decimal to a "regular" binary number
return ((((x >> 4) & 0xF) * 10) + (x & 0xF)) ;
void printTime() {
// just like it says on the tin
Serial.print ("\'");
if (yy<10) Serial.print("0"); Serial.print(yy,DEC); Serial.print("-");
if (mo<10) Serial.print("0"); Serial.print(mo,DEC); Serial.print("-");
if (dd<10) Serial.print("0"); Serial.print(dd,DEC); Serial.print("(");
switch (wd) {
case 1: Serial.print("Mon"); break;
case 2: Serial.print("Tue"); break;
case 3: Serial.print("Wed"); break;
case 4: Serial.print("Thu"); break;
case 5: Serial.print("Fri"); break;
case 6: Serial.print("Sat"); break;
case 7: Serial.print("Sun"); break;
default: Serial.print("Bad");
Serial.print(") ");
if (hh<10) Serial.print("0"); Serial.print(hh,DEC); Serial.print(":");
if (mi<10) Serial.print("0"); Serial.print(mi,DEC); Serial.print(":");
if (ss<10) Serial.print("0"); Serial.print(ss,DEC); Serial.println("");
This should print the date and time to the serial monitor. Remember to select the correct baud rate.
Note that I number the weekdays starting from 1 for Monday. Some people prefer to use 1 for Sunday.
MarkS1964:
Without looking too deeply will it adapt to outputting the 2016 12 05 output?
You don't have to look particularly deeply to figure that out.
Just be aware that 2016, etc., will not fit in a byte. You need at least an int for that. This only matters, though, if you intend to store the "full" year number and not just display it.
