Hello, I recently bought a DS3231 RTC module for my next project. I am currently experimenting around it and its interrupt pin is not working. I am using it to wake up the arduino uno from deep sleep. How would I be able to fix it? I am currently using this rtc library: FabioCuomo-DS3231/RTClibExtended.cpp at master · FabioCuomo/FabioCuomo-DS3231 · GitHub The code I am using is its example code:
#include <Wire.h>
#include <RTClibExtended.h>
#include <LowPower.h>
#define wakePin 2 //use interrupt 0 (pin 2) and run function wakeUp when pin 2 gets LOW
#define ledPin 13 //use arduino on-board led for indicating sleep or wakeup status
RTC_DS3231 RTC; //we are using the DS3231 RTC
byte AlarmFlag = 0;
byte ledStatus = 1;
void wakeUp() // here the interrupt is handled after wakeup
//Set pin D2 as INPUT for accepting the interrupt signal from DS3231
pinMode(wakePin, INPUT);
//switch-on the on-board led for 1 second for indicating that the sketch is ok and running
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
//Initialize communication with the clock
Wire.begin();
RTC.begin();
RTC.adjust(DateTime(__DATE__, __TIME__)); //set RTC date and time to COMPILE time
//clear any pending alarms
RTC.armAlarm(1, false);
RTC.clearAlarm(1);
RTC.alarmInterrupt(1, false);
RTC.armAlarm(2, false);
RTC.clearAlarm(2);
RTC.alarmInterrupt(2, false);
//Set SQW pin to OFF (in my case it was set by default to 1Hz)
//The output of the DS3231 INT pin is connected to this pin
//It must be connected to arduino D2 pin for wake-up
RTC.writeSqwPinMode(DS3231_OFF);
//Set alarm1 every day at 18:33
RTC.setAlarm(ALM1_MATCH_HOURS, 33, 18, 0); //set your wake-up time here
RTC.alarmInterrupt(1, true);
//On first loop we enter the sleep mode
if (AlarmFlag == 0) {
attachInterrupt(0, wakeUp, LOW); //use interrupt 0 (pin 2) and run function wakeUp when pin 2 gets LOW
digitalWrite(ledPin, LOW); //switch-off the led for indicating that we enter the sleep mode
ledStatus = 0; //set the led status accordingly
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF); //arduino enters sleep mode here
detachInterrupt(0); //execution resumes from here after wake-up
//When exiting the sleep mode we clear the alarm
RTC.clearAlarm(1);
AlarmFlag++;
//cycles the led to indicate that we are no more in sleep mode
if (ledStatus == 0) {
ledStatus = 1;
else {
ledStatus = 0;
