Thank you jremington for your reply...
here is my ..... problematic code
#include <DS3231.h>
#include <Wire.h>
#include <avr/sleep.h>
DS3231 Clock;
byte year, month, date, DoW, hour, minute, second;
int INTERRUPT_PIN = 2;
int RTC_ON = 9; // D5 DHT PIN (ON - OFF)
volatile int flag = 0;
void setup () {
digitalWrite (RTC_ON, HIGH);
pinMode (RTC_ON, OUTPUT);
pinMode(INTERRUPT_PIN, INPUT);
//pull up the interrupt pin
// digitalWrite(INTERRUPT_PIN, HIGH);
Serial.begin(19200);
Wire.begin();
Clock.getTime(year, month, date, DoW, hour, minute, second);
Clock.setA1Time(DoW, hour, minute+1, second, 0x0, true, false, false);
// set A2 to two minutes past, on current day of month.
Clock.setA2Time(date, hour, minute+2, 0x0, false, false,false);
// Turn on both alarms, with external interrupt
Clock.turnOnAlarm(1);
Clock.turnOnAlarm(2);
if (Clock.checkAlarmEnabled(1) && Clock.checkAlarmEnabled(2)) {
Serial.println("Alarms Enabled");
attachInterrupt(0, SendReport, FALLING);
void loop () {
// power up clock chip
// activate I2C
Wire.begin();
//DateTime now = RTC.now();
if (Clock.checkIfAlarm(1) )
Serial.println("Alarm 1 Triggered");
if (Clock.checkIfAlarm(2))
Serial.println("Alarm 2 Triggered");
if(flag ==1)
Serial.println("FLAG = 1");
delay(2000);
Serial.println("FLAG = 0");
delay(2000);
// Display the time once more as a test of the getTime() function
Serial.print(year, DEC);
Serial.print("/");
Serial.print(month, DEC);
Serial.print("/");
Serial.print(date, DEC);
Serial.print("day of the week :");
Serial.println(DoW, DEC);
Serial.print(hour, DEC);
Serial.print(":");
Serial.print(minute, DEC);
Serial.print(":");
Serial.println(second, DEC);
// finished with clock
pinMode (RTC_ON ,INPUT);
digitalWrite (RTC_ON, LOW);
// turn off I2C
TWCR &= ~(bit(TWEN) | bit(TWIE) | bit(TWEA));
// turn off I2C pull-ups
digitalWrite (A4, LOW);
digitalWrite (A5, LOW);
Serial.println("Going to Sleep");
delay(600);
sleepNow();
Serial.println("AWAKE");
void sleepNow() {
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
attachInterrupt(0,SendReport, FALLING);
sleep_mode();
//HERE AFTER WAKING UP
sleep_disable();
detachInterrupt(0);
void SendReport() {
//do something quick, flip a flag, and handle in loop();
flag =1 ;
The above working when DS3231 powered from VCC and NOT when powered from RTC_ON pin.
