DS3231 replacing DS1307
So i'm planning to use the DS3231 instead of DS1307 cause i can sync it, is the code to read time still
void read_time() {
 tmElements_t tm;
 if (RTC.read(tm)) {
 seconds = tm.Second;
 minutes = tm.Minute;
 hours = tm.Hour;
i doubt it but just to make sure,
Hard to say without knowing what library(s) your sketch uses. That's why you are asked to always post a full sketch.
But if the library you are using says that it supports ds3231 and ds1307, then the same code will probably work fine. The 2 chips are very similar in many ways.
Why can't you sync with ds1307?
You'd better use the Arduino library for DS3231 RTC.
this is what i'm trying to make except somewhat modified
Ok. Are you one of those people who asks for help but prefers not to answer any questions? If so, I will wish you good luck with your project.
the code is at the bottom of the page, link is hyperlinked,
here, just the link :
https://create.arduino.cc/projecthub/taifur/arduino-powered-water-bottle-42ee43
Oh yeah, with the ds1307 it looks reallllyy complicated, with ds3231 there's already a sketch and bat file to sync, but the library is specific only to ds1307, sorry missed that
This sketch? It's not the best!
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Time.h>
#include <TimeLib.h>
#include <Wire.h>
#include <DS1307RTC.h>
#include "LowPower.h"
#include "OneButton.h"
OneButton button(2, true);
const byte interruptPin = 2;
volatile int state = 0;
const int trigPin = 4;
const int echoPin = 5;
int piezoPin = 3;
const int digit[4] = {9,6,7,8};
int digit_value[4];
int digit_value1[4];
int button_press_count = 1;
const int segment[8] = {16,10,12,14,15,17,11,13};
const byte number[10][8] = {{1,1,1,1,1,1,0,0}, //0
                            {0,1,1,0,0,0,0,0}, //1
                            {1,1,0,1,1,0,1,0}, //2
                            {1,1,1,1,0,0,1,0}, //3
                            {0,1,1,0,0,1,1,0}, //4
                            {1,0,1,1,0,1,1,0}, //5
                            {1,0,1,1,1,1,1,0}, //6
                            {1,1,1,0,0,0,0,0}, //7
                            {1,1,1,1,1,1,1,0}, //8
                            {1,1,1,1,0,1,1,0}}; //9
const byte d[8] = {0,1,1,1,1,0,1,1};
const byte a[8] = {1,1,1,0,1,1,1,1};
const byte r[8] = {0,0,0,0,1,0,1,1};
const byte t[8] = {0,0,0,1,1,1,1,1};
int seconds, minutes, hours;
int water_in_ounch[15];
int water_intake_ounch[15];
int water_intake_days[7];
int water_intake_times = 0;
int previous_water_amount = 0;
int total_water_intake_today = 0;
int average_intake_last_week = 0;
int inatke_day = 1;
float average_water_level = 0; //store average of multiple reading
int water_amount_in_ounce = 0; //store calculated amount of water
int idle_time = 0;
int intake_day = 1;
int previous_value = 0;
  pinMode(interruptPin, INPUT_PULLUP);
  for(int i=6; i<=17; i++)
      pinMode(i, OUTPUT);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  button.attachClick(pressed);
  button.attachDoubleClick(doubleclick);
  button.attachLongPressStart(longPressStart);
  button.attachDuringLongPress(longPress);
long previous_state = millis();
int count = 1;
int daily_intake = 0;
int weekly_intake = 0;
long sleep_time = millis();
  read_time();
  button.tick(); // keep watching the push buttons:
  calculation();
  daily_intake = total_water_intake_in_day();
  weekly_intake = average_water_intake_last_week();
  if(button_press_count == 1){
    display_d();
    display_number(daily_intake);
  else if(button_press_count == 2){
    display_a();
    display_number(weekly_intake);
  else if(button_press_count == 3){
    display_r();
    display_number(water_amount_in_ounce);
  else if(button_press_count == 4){
    display_first_2(hours);
    display_last_2(minutes);
  if(idle_time>=120){
    alert();
    alert();
  if((millis() - sleep_time) >= 15000){
    display_off();
    attachInterrupt(digitalPinToInterrupt(interruptPin), blank, FALLING);
    LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
    detachInterrupt(digitalPinToInterrupt(interruptPin));
void display_digit(int digit){
  for(int i=0; i<8; i++){
    digitalWrite(segment[i], number[digit][i]);
void display_number(int number){
  int i=0;
  while(number>0){
    digit_value[2-i] = number%10;
    number = number/10;
    i++;
  digitalWrite(digit[1], HIGH);
  digitalWrite(digit[2], LOW);
  digitalWrite(digit[3], LOW);
  display_digit(digit_value[0]);
  delay(5);
  digitalWrite(digit[1], LOW);
  digitalWrite(digit[2], HIGH);
  display_digit(digit_value[1]);
  delay(5);
  digitalWrite(digit[3], HIGH);
  display_digit(digit_value[2]);
  delay(5);
  digit_value[0] = 0;
  digit_value[1] = 0;
  digit_value[2] = 0;
void display_first_2(int number){
  int i=0;
  while(number>0){
    digit_value[1-i] = number%10;
    number = number/10;
    i++;
  digitalWrite(digit[0], HIGH);
  delay(3);
  digitalWrite(digit[0], LOW);
  delay(3);
void display_last_2(int number){
  int i=0;
  while(number>0){
    digit_value1[1-i] = number%10;
    number = number/10;
    i++;
  display_digit(digit_value1[0]);
  delay(3);
  display_digit(digit_value1[1]);
  delay(3);
void display_d(){
    digitalWrite(segment[i], d[i]);
  delay(5);
void display_a(){
    digitalWrite(segment[i], a[i]);
  delay(5);
void display_r(){
    digitalWrite(segment[i], r[i]);
  delay(5);
void display_t(){
    digitalWrite(segment[i], t[i]);
  delay(5);
void display_off(){
    digitalWrite(segment[i], LOW);
  delay(5);
void read_time() {
 tmElements_t tm;
 if (RTC.read(tm)) {
 hours = tm.Hour;
int distance_in_cm(){
  long duration, cm;
  // The sensor is triggered by a HIGH pulse of 10 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Read the signal from the sensor: a HIGH pulse whose
  // duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  duration = pulseIn(echoPin, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  return cm;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
void alert(){
  tone(piezoPin, 2000, 50);
  tone(piezoPin, 2000, 200);
  //delay(10);
void blank() {
  //tone(piezoPin, 2000, 100);
  //state++;
// This function will be called when the button1 was pressed 1 time (and no 2. button press followed).
void pressed() {
  //Serial.println("Button 1 click.");
  button_press_count++;
  alert();
  if(button_press_count == 5){
} // click
// This function will be called when the button1 was pressed 2 times in a short timeframe.
void doubleclick() {
  Serial.println("Button 1 doubleclick.");
} // doubleclick
// This function will be called once, when the button1 is pressed for a long time.
void longPressStart() {
  Serial.println("Button 1 longPress start");
} // longPressStart
// This function will be called often, while the button1 is pressed for a long time.
void longPress() {
  Serial.println("Button 1 longPress...");
  water_intake_ounch[water_intake_times - 1] = 0; //ignore last value
} // longPress
void calculation(){
  float water_level = 0;// store level in every step
  int read_value = 0; //read sensor reading in cm
  for(int i=0; i<5; i++){ //take five reading
      read_value = distance_in_cm();
      if(read_value>16 || read_value<3){// unstable reading
          return; //return to calling function because reading is unstable
      else if(read_value<=16 && read_value>=3){//valid value
          water_level = water_level + read_value;
      delay(10);
  average_water_level = 17 - water_level/5; //find average from five reading, 17 = botole height
  water_amount_in_ounce = int(average_water_level*1.87);//16 cm water level = 30 ounch
  if(water_intake_times==0){
     previous_water_amount = water_amount_in_ounce;
     water_intake_times = 1;
  if((water_amount_in_ounce < previous_water_amount-1) && (hours < 24)){//some water is consumed
    water_intake_ounch[water_intake_times - 1] = previous_water_amount - water_amount_in_ounce;
    water_intake_times++;
    idle_time = 0;
  else if(water_amount_in_ounce > previous_water_amount){ //water is refilled
    //water refil here
  else if(water_amount_in_ounce == previous_water_amount){ //no water consumed or reafill
    idle_time+=1;
  if(hours==23 && minutes==59){ // a day is over and all values start from zero for new day
    for(int i=0; i<15; i++){
      water_intake_ounch[i] = 0;
    intake_day++;
    if(intake_day==8){
      intake_day = 1;
int total_water_intake_in_day(){//calculate total water intake in a day
  for(int i=0; i<water_intake_times; i++){
    total_water_intake_today = total_water_intake_today + water_intake_ounch[i];
    water_intake_days[intake_day] = total_water_intake_today;
    return total_water_intake_today;
int average_water_intake_last_week(){//calculate average water intake last week
  for(int i=1; i<=intake_day; i++){
    average_intake_last_week = average_intake_last_week + water_intake_days[i-1];
  average_intake_last_week = average_intake_last_week/intake_day;
  return average_intake_last_week;
you telling me to rewrite all of that?
besides, it's for school, so i just need it to work, and it works, also i just want to replace the ds1307 with a ds3231 so i can alert at certain set time, for example at 9 or something
The DS3232RTC library should be an almost direct replacement for DS1307RTC.
Syncing is easy with DS1307RTC, see the TimeRTC example sketch from the Time library.
Also, no need to include Time.h, TimeLib.h is the Time library.
Is it a programming class?
Sure, what is the point of doing some research, understanding it, and learning something when you can just hand in someone else's work?
no, it isn't a programming class, i understand the code that is in this, but i am not saying i completely know it all about arduino and c++ programming, because i don't, hence i ask, when i saw something here that i didn't understand in the code i googled it, since i needed to know how it fully functioned first, i also googled this but to be sure i asked, and no, i am not handing in someone else's work, since this is about research, it is allowed to use someone else's work as long as it is open source, since i am handing in my research and findings using this. so kindly please stop assuming the worst in people before you've seen it, and yes, i will credit Khairul
It is hard to understand exactly what you mean in reply #9. If I understand correctly, it's really something like, "Okay the code I found is not very good, but I want to use it and I still don't understand how to modify it for DS3231."?
Is that a fair assessment?
It is not clear exactly what you want. To sync the time commonly refers to running a clock based off the microcontroller timing (such as the millis count), and periodically correcting that with a more accurate time source, such as an RTC, NTP server, etc.
Setting an alert at a specific time has nothing to do with syncing, and could be done with either the alarms in the RTC, or by comparing the current time with the desired alert time.
Why not simply use a DS1307? (I thought I would never ever say that, but this is a special circumstance...)
ohh i get the misunderstanding. meant syncing it to the world time,
also does this work?
#include <Time.h>
#include <Wire.h>
int piezoPin = 3;
int digit_value[4];
int inatke_day = 1;
int idle_time = 0;
int intake_day = 1;
      pinMode(i, OUTPUT);
int count = 1;
  read_time();
  calculation();
    display_d();
    display_a();
    display_r();
  if(idle_time>=120){
    alert();
    alert();
    display_off();
  int i=0;
  while(number>0){
    number = number/10;
    i++;
  delay(5);
  delay(5);
  delay(5);
  digit_value[0] = 0;
  digit_value[1] = 0;
  digit_value[2] = 0;
  int i=0;
  while(number>0){
    number = number/10;
    i++;
  delay(3);
  delay(3);
  int i=0;
  while(number>0){
    number = number/10;
    i++;
  delay(3);
  delay(3);
void display_d(){
  delay(5);
void display_a(){
  delay(5);
void display_r(){
  delay(5);
void display_t(){
  delay(5);
void display_off(){
  delay(5);
void readDS3231time(byte *seconds,
                    byte *minutes,
                    byte *hours,
                    byte *dayOfWeek,
                    byte *dayOfMonth,
                    byte *month,
                    byte *year)
  Wire.beginTransmission(DS3231_I2C_ADDRESS);
  Wire.write(0); // set DS3231 register pointer to 00h
  Wire.endTransmission();
  Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
  // request seven bytes of data from DS3231 starting from register 00h
  *seconds = bcdToDec(Wire.read() & 0x7f);
  *minutes = bcdToDec(Wire.read());
  *hours = bcdToDec(Wire.read() & 0x3f);
  *dayOfWeek = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month = bcdToDec(Wire.read());
  *year = bcdToDec(Wire.read());
  long duration, cm;
  return cm;
void alert(){
  //delay(10);
void blank() {
  //state++;
void pressed() {
  alert();
} // click
} // doubleclick
} // longPressStart
void longPress() {
} // longPress
void calculation(){
      delay(10);
    idle_time = 0;
    //water refil here
    idle_time+=1;
    intake_day++;
    if(intake_day==8){
      intake_day = 1;
How do you want us to test it?
oh no i'm just asking if it would theoretically work if i just put in
                    byte *minutes,
                    byte *hours,
                    byte *dayOfWeek,
                    byte *dayOfMonth,
                    byte *month,
                    byte *year)
where the read on DS1307 was, i assume it would,
when i used byte *seconds, i assume it's integer right? there's no int, but on example codes it just seemed as it was treated like an integer, the last one was this
seconds = tm.second
but above it already did
That is a horrible, ghastly way of returning values, list of pointers to global variables. Did you cut and paste it from some random place on the internet? Normally you would return a pointer to a single struct containing all 7 values. There are a lot of other better alternatives too. Such as, just including a DS3231 library and using it instead of writing custom code that you clearly don't understand.
It's a bit of guesswork how you intend to use it, since the function is never called by your code.
You ask it "it" would work, but you haven't really provided any complete "it" to respond to. You are leaping into minutae about variable type representation far far in advance of having anything remotely close to working. That is a misjudgement. Also you have included the DateTime library yet seem to have not used any part of it. That is another misjudgement.
Do you have any actual hardware? You really need to focus on producing and testing an actual sketch on actual hardware so you can see that something is a complete failure before bothering to ask here whether it will work or not.
When you post here, please provide complete, compileable code, along with a description of any behaviour or problems that you wish to discuss.
A byte is an unsigned integer, but not an 'int' type in this compiler. Hence either will hold small values like clock times, 0-59 for example.
