Do not even think about using a breadboard with 10 ampere currents!
All motor and power connections should be made using 12 (or 14 if short) gauge wire and soldered.
You should power the arduino from a separate supply than the pump controller 12V supply.
It would probably be prudent to add in-line fuse holders or panel mount fuse holder and slow blow fuses.
