Thanks, I think the dual library feature is the best way to go right now since that thing is all over the file. It was included in the w5100.cpp file
* Copyright (c) 2010 by Cristian Maglie <c.maglie@bug.st>
* This file is free software; you can redistribute it and/or modify
* it under the terms of either the GNU General Public License version 2
* or the GNU Lesser General Public License version 2.1, both as
* published by the Free Software Foundation.
#include <stdio.h>
#include <string.h>
#include "w5100.h"
// W5100 controller instance
W5100Class W5100;
#define SPI_CS 10
#define TX_RX_MAX_BUF_SIZE 2048
#define TX_BUF 0x1100
#define RX_BUF (TX_BUF + TX_RX_MAX_BUF_SIZE)
#ifdef W5200
#define TXBUF_BASE 0x8000
#define RXBUF_BASE 0xC000
#else
#define TXBUF_BASE 0x4000
#define RXBUF_BASE 0x6000
#endif
void W5100Class::init(void)
delay(300);
SPI.begin(SPI_CS);
#ifdef W5200
// should be ok with no divider, W5200 support 80Mhz and SAM3X8E is cadenced to 84Mhz..
//have tried with webserver sample and it's ok but require more tests
// Set clock to 42Mhz (W5200 should support up to 80Mhz)
//SPI.setClockDivider(SPI_CS, 2);
#else
// Set clock to 4Mhz (W5100 should support up to 14Mhz)
SPI.setClockDivider(SPI_CS, 21);
#endif
SPI.setDataMode(SPI_CS, SPI_MODE0);
writeMR(1<<RST);
#ifdef W5200
for (int i=0; i<MAX_SOCK_NUM; i++) {
write((0x4000 + i * 0x100 + 0x001F), 2);
write((0x4000 + i * 0x100 + 0x001E), 2);
#else
writeTMSR(0x55);
writeRMSR(0x55);
#endif
SBASE[i] = TXBUF_BASE + SSIZE * i;
RBASE[i] = RXBUF_BASE + RSIZE * i;
uint16_t W5100Class::getTXFreeSize(SOCKET s)
uint16_t val=0, val1=0;
do {
val1 = readSnTX_FSR(s);
if (val1 != 0)
val = readSnTX_FSR(s);
while (val != val1);
return val;
uint16_t W5100Class::getRXReceivedSize(SOCKET s)
uint16_t val=0,val1=0;
do {
val1 = readSnRX_RSR(s);
if (val1 != 0)
val = readSnRX_RSR(s);
return val;
void W5100Class::send_data_processing(SOCKET s, const uint8_t *data, uint16_t len)
// This is same as having no offset in a call to send_data_processing_offset
send_data_processing_offset(s, 0, data, len);
void W5100Class::send_data_processing_offset(SOCKET s, uint16_t data_offset, const uint8_t *data, uint16_t len)
uint16_t ptr = readSnTX_WR(s);
ptr += data_offset;
uint16_t offset = ptr & SMASK;
uint16_t dstAddr = offset + SBASE[s];
if (offset + len > SSIZE)
// Wrap around circular buffer
uint16_t size = SSIZE - offset;
write(dstAddr, data, size);
write(SBASE[s], data + size, len - size);
else {
write(dstAddr, data, len);
ptr += len;
writeSnTX_WR(s, ptr);
void W5100Class::recv_data_processing(SOCKET s, uint8_t *data, uint16_t len, uint8_t peek)
uint16_t ptr;
ptr = readSnRX_RD(s);
read_data(s, ptr, data, len);
if (!peek)
ptr += len;
writeSnRX_RD(s, ptr);
void W5100Class::read_data(SOCKET s, volatile uint16_t src, volatile uint8_t *dst, uint16_t len)
uint16_t size;
uint16_t src_mask;
uint16_t src_ptr;
src_mask = src & RMASK;
src_ptr = RBASE[s] + src_mask;
if( (src_mask + len) > RSIZE )
size = RSIZE - src_mask;
read(src_ptr, (uint8_t *)dst, size);
dst += size;
read(RBASE[s], (uint8_t *) dst, len - size);
read(src_ptr, (uint8_t *) dst, len);
uint8_t W5100Class::write(uint16_t _addr, uint8_t _data)
#ifdef W5200
SPI.transfer(SPI_CS, _addr >> 8, SPI_CONTINUE);
SPI.transfer(SPI_CS, _addr & 0xFF, SPI_CONTINUE);
SPI.transfer(SPI_CS, 0x80, SPI_CONTINUE);
SPI.transfer(SPI_CS, 0x01, SPI_CONTINUE);
#else
SPI.transfer(SPI_CS, 0xF0, SPI_CONTINUE);
#endif
SPI.transfer(SPI_CS, _data);
return 1;
uint16_t W5100Class::write(uint16_t _addr, const uint8_t *_buf, uint16_t _len)
#ifdef W5200
SPI.transfer(SPI_CS, (0x80 | ((_len & 0x7F00) >> 8)), SPI_CONTINUE);
SPI.transfer(SPI_CS, _len & 0x00FF, SPI_CONTINUE);
for (uint16_t i=0; i<_len; i++)
SPI.transfer(SPI_CS, _buf[i], SPI_CONTINUE);
#else
SPI.transfer(SPI_CS, _buf[i]);
_addr++;
#endif
return _len;
uint8_t W5100Class::read(uint16_t _addr)
#ifdef W5200
SPI.transfer(SPI_CS, 0x00, SPI_CONTINUE);
#else
SPI.transfer(SPI_CS, 0x0F, SPI_CONTINUE);
#endif
uint8_t _data = SPI.transfer(SPI_CS, 0);
return _data;
uint16_t W5100Class::read(uint16_t _addr, uint8_t *_buf, uint16_t _len)
#ifdef W5200
SPI.transfer(SPI_CS, (0x00 | ((_len & 0x7F00) >> 8)), SPI_CONTINUE);
_buf[i] = SPI.transfer(SPI_CS, 0, SPI_CONTINUE);
#else
_buf[i] = SPI.transfer(SPI_CS, 0);
_addr++;
#endif
return _len;
void W5100Class::execCmdSn(SOCKET s, SockCMD _cmd) {
// Send command to socket
writeSnCR(s, _cmd);
// Wait for command to complete
while (readSnCR(s))
