I have connected an M2M sim in GSM Module at 7670C Dual Sim. It is getting good CSQ but failed to connect with internet. PDP context is getting failed and it is not receving any IP address or APN. I tried giving APN manually but still it is not registring with network. Getting Creg 3 or 1. I am giving sufficient power supply with 6 Amp current source.
When I connect same sim in my mobile or any other gsm module it works properly. When I connect data sim in this 7670C Module. It works perfectly. The only problem is Dual sim module with M2M sim.
It fast flash few times and then start slow flashing. Whenever it fast flash I receive this output
+CREG: 1
+CGEV: NW REATTACH
+IMSUEEVENT: 0,7
+CGEV: EPS PDN ACT 1
+CREG: 3
+CGEV: NW DETACH
+CGEV: ME PDN DEACT 8
+CGEV: NW PDN DEACT 1
Lets start with an annotated schematic showing how this project is wired. Show where the Arduino is involved and which one. Also post your code using code tags following the forum guidelines.
Most of your llink is tracking information etc. Whatever appears after the ‘?’ is generally junk. I striped the excess off and the link I posted here is the same.
It sounds like you have it working.
This is my GSM Module Picture.
Here is a link to the manuals:
Hopefully this will help you.
I have applied manually enterin the APN and also Activating PDP context. The apn set perfectly but activating PDP context gives error.
I have also tried following commands
AT+CGDCONT=1,"IP","ufone.corporate","10.14.192.4"
AT+CNMP=38
AT+CGACT=1,1 - > +CME ERROR: unknown error
Private APN Issue Report.pdf (385.1 KB)
I have attach the report
