barcode scannerHi everybody
I tried to connect the barcode scanner to Arduino DUE. I googled but all the examples I found used a USB host shield. I tried to connect the scanner to native USB port and use the USBHost library.
I used Keyboard Controller example. Just to see if there is any response in Serial.
here is the link for barcode scanner data sheet.
#include <KeyboardController.h>
// Initialize USB Controller
USBHost usb;
// Attach keyboard controller to USB
KeyboardController keyboard(usb);
// This function intercepts key press
void keyPressed() {
Serial.print("Pressed: ");
printKey();
// This function intercepts key release
void keyReleased() {
Serial.print("Released: ");
printKey();
void printKey() {
// getOemKey() returns the OEM-code associated with the key
Serial.print(" key:");
Serial.print(keyboard.getOemKey());
// getModifiers() returns a bits field with the modifiers-keys
int mod = keyboard.getModifiers();
Serial.print(" mod:");
Serial.print(mod);
Serial.print(" => ");
if (mod & LeftCtrl)
Serial.print("L-Ctrl ");
if (mod & LeftShift)
Serial.print("L-Shift ");
if (mod & Alt)
Serial.print("Alt ");
if (mod & LeftCmd)
Serial.print("L-Cmd ");
if (mod & RightCtrl)
Serial.print("R-Ctrl ");
if (mod & RightShift)
Serial.print("R-Shift ");
if (mod & AltGr)
Serial.print("AltGr ");
if (mod & RightCmd)
Serial.print("R-Cmd ");
// getKey() returns the ASCII translation of OEM key
// combined with modifiers.
Serial.write(keyboard.getKey());
Serial.println("Program started");
delay(200);
// Process USB tasks
usb.Task();
this code working properly witch usb keyboard but not witch barcode scanner .please suggest what to do.
