I want to control a 24V dc motor using this H Bridge using the PWM on Due (3.3V) but the H bridge said it needs 5V logic. Spec sheet for chip said it only needs 1.5 V logic, would the Due work with this?
No it doesn't.
Grumpy_Mike:
No it doesn't.
Ok, must of read it wrong. But would it work with the due?
I would think 3.3v would be accepted by the H-bridge as a high logic signal.
leakedazaz:
Yes it says in the data sheet minimum value for registering as a high is 2.3V and the maximum for registering as a low is 1.5V, so yes it probably would.
