#include "dw3000.h"
#include "SPI.h"
extern SPISettings _fastSPI;
#define PIN_RST 27
#define PIN_IRQ 34
#define PIN_SS 4
#define TX_ANT_DLY 16385
#define RX_ANT_DLY 16385
#define ALL_MSG_COMMON_LEN 10
#define ALL_MSG_SN_IDX 2
#define RESP_MSG_POLL_RX_TS_IDX 10
#define RESP_MSG_RESP_TX_TS_IDX 14
#define RESP_MSG_TS_LEN 4
#define POLL_RX_TO_RESP_TX_DLY_UUS 450
/* Default communication configuration. We use default non-STS DW mode. */
static dwt_config_t config = {
5, /* Channel number. */
DWT_PLEN_128, /* Preamble length. Used in TX only. */
DWT_PAC8, /* Preamble acquisition chunk size. Used in RX only. */
9, /* TX preamble code. Used in TX only. */
9, /* RX preamble code. Used in RX only. */
1, /* 0 to use standard 8 symbol SFD, 1 to use non-standard 8 symbol, 2 for non-standard 16 symbol SFD and 3 for 4z 8 symbol SDF type */
DWT_BR_6M8, /* Data rate. */
DWT_PHRMODE_STD, /* PHY header mode. */
DWT_PHRRATE_STD, /* PHY header rate. */
(129 + 8 - 8), /* SFD timeout (preamble length + 1 + SFD length - PAC size). Used in RX only. */
DWT_STS_MODE_OFF, /* STS disabled */
DWT_STS_LEN_64, /* STS length see allowed values in Enum dwt_sts_lengths_e */
DWT_PDOA_M0 /* PDOA mode off */
static uint8_t rx_poll_msg[] = {0x41, 0x88, 0, 0xCA, 0xDE, 'W', 'A', 'V', 'E', 0xE0, 0, 0};
static uint8_t tx_resp_msg[] = {0x41, 0x88, 0, 0xCA, 0xDE, 'V', 'E', 'W', 'A', 0xE1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
static uint8_t frame_seq_nb = 0;
static uint8_t rx_buffer[20];
static uint32_t status_reg = 0;
static uint64_t poll_rx_ts;
static uint64_t resp_tx_ts;
extern dwt_txconfig_t txconfig_options;
UART_init();
_fastSPI = SPISettings(16000000L, MSBFIRST, SPI_MODE0);
spiBegin(PIN_IRQ, PIN_RST);
spiSelect(PIN_SS);
delay(2); // Time needed for DW3000 to start up (transition from INIT_RC to IDLE_RC, or could wait for SPIRDY event)
while (!dwt_checkidlerc()) // Need to make sure DW IC is in IDLE_RC before proceeding
UART_puts("IDLE FAILED\r\n");
while (1)
if (dwt_initialise(DWT_DW_INIT) == DWT_ERROR)
UART_puts("INIT FAILED\r\n");
while (1)
// Enabling LEDs here for debug so that for each TX the D1 LED will flash on DW3000 red eval-shield boards.
dwt_setleds(DWT_LEDS_ENABLE | DWT_LEDS_INIT_BLINK);
/* Configure DW IC. See NOTE 6 below. */
if (dwt_configure(&config)) // if the dwt_configure returns DWT_ERROR either the PLL or RX calibration has failed the host should reset the device
UART_puts("CONFIG FAILED\r\n");
while (1)
/* Configure the TX spectrum parameters (power, PG delay and PG count) */
dwt_configuretxrf(&txconfig_options);
/* Apply default antenna delay value. See NOTE 2 below. */
dwt_setrxantennadelay(RX_ANT_DLY);
dwt_settxantennadelay(TX_ANT_DLY);
/* Next can enable TX/RX states output on GPIOs 5 and 6 to help debug, and also TX/RX LEDs
* Note, in real low power applications the LEDs should not be used. */
dwt_setlnapamode(DWT_LNA_ENABLE | DWT_PA_ENABLE);
Serial.println("Range TX");
Serial.println("Setup over........");
/* Activate reception immediately. */
dwt_rxenable(DWT_START_RX_IMMEDIATE);
/* Poll for reception of a frame or error/timeout. See NOTE 6 below. */
while (!((status_reg = dwt_read32bitreg(SYS_STATUS_ID)) & (SYS_STATUS_RXFCG_BIT_MASK | SYS_STATUS_ALL_RX_ERR)))
if (status_reg & SYS_STATUS_RXFCG_BIT_MASK)
uint32_t frame_len;
/* Clear good RX frame event in the DW IC status register. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_RXFCG_BIT_MASK);
/* A frame has been received, read it into the local buffer. */
frame_len = dwt_read32bitreg(RX_FINFO_ID) & RXFLEN_MASK;
if (frame_len <= sizeof(rx_buffer))
dwt_readrxdata(rx_buffer, frame_len, 0);
/* Check that the frame is a poll sent by "SS TWR initiator" example.
* As the sequence number field of the frame is not relevant, it is cleared to simplify the validation of the frame. */
rx_buffer[ALL_MSG_SN_IDX] = 0;
if (memcmp(rx_buffer, rx_poll_msg, ALL_MSG_COMMON_LEN) == 0)
uint32_t resp_tx_time;
int ret;
/* Retrieve poll reception timestamp. */
poll_rx_ts = get_rx_timestamp_u64();
/* Compute response message transmission time. See NOTE 7 below. */
resp_tx_time = (poll_rx_ts + (POLL_RX_TO_RESP_TX_DLY_UUS * UUS_TO_DWT_TIME)) >> 8;
dwt_setdelayedtrxtime(resp_tx_time);
/* Response TX timestamp is the transmission time we programmed plus the antenna delay. */
resp_tx_ts = (((uint64_t)(resp_tx_time & 0xFFFFFFFEUL)) << 8) + TX_ANT_DLY;
/* Write all timestamps in the final message. See NOTE 8 below. */
resp_msg_set_ts(&tx_resp_msg[RESP_MSG_POLL_RX_TS_IDX], poll_rx_ts);
resp_msg_set_ts(&tx_resp_msg[RESP_MSG_RESP_TX_TS_IDX], resp_tx_ts);
/* Write and send the response message. See NOTE 9 below. */
tx_resp_msg[ALL_MSG_SN_IDX] = frame_seq_nb;
dwt_writetxdata(sizeof(tx_resp_msg), tx_resp_msg, 0); /* Zero offset in TX buffer. */
dwt_writetxfctrl(sizeof(tx_resp_msg), 0, 1); /* Zero offset in TX buffer, ranging. */
ret = dwt_starttx(DWT_START_TX_DELAYED);
/* If dwt_starttx() returns an error, abandon this ranging exchange and proceed to the next one. See NOTE 10 below. */
if (ret == DWT_SUCCESS)
/* Poll DW IC until TX frame sent event set. See NOTE 6 below. */
while (!(dwt_read32bitreg(SYS_STATUS_ID) & SYS_STATUS_TXFRS_BIT_MASK))
/* Clear TXFRS event. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_TXFRS_BIT_MASK);
/* Increment frame sequence number after transmission of the poll message (modulo 256). */
frame_seq_nb++;
/* Clear RX error events in the DW IC status register. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_ALL_RX_ERR);
Code 1 TX
#include "dw3000.h"
#define PIN_RST 27
#define PIN_IRQ 34
#define PIN_SS 4
#define RNG_DELAY_MS 1000
#define POLL_TX_TO_RESP_RX_DLY_UUS 240
#define RESP_RX_TIMEOUT_UUS 400
static uint8_t tx_poll_msg[] = {0x41, 0x88, 0, 0xCA, 0xDE, 'W', 'A', 'V', 'E', 0xE0, 0, 0};
static uint8_t rx_resp_msg[] = {0x41, 0x88, 0, 0xCA, 0xDE, 'V', 'E', 'W', 'A', 0xE1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
static double tof;
static double distance;
UART_init();
spiSelect(PIN_SS);
while (1)
while (1)
while (1)
/* Set expected response's delay and timeout. See NOTE 1 and 5 below.
* As this example only handles one incoming frame with always the same delay and timeout, those values can be set here once for all. */
dwt_setrxaftertxdelay(POLL_TX_TO_RESP_RX_DLY_UUS);
dwt_setrxtimeout(RESP_RX_TIMEOUT_UUS);
Serial.println("Range RX");
/* Write frame data to DW IC and prepare transmission. See NOTE 7 below. */
tx_poll_msg[ALL_MSG_SN_IDX] = frame_seq_nb;
dwt_writetxdata(sizeof(tx_poll_msg), tx_poll_msg, 0); /* Zero offset in TX buffer. */
dwt_writetxfctrl(sizeof(tx_poll_msg), 0, 1); /* Zero offset in TX buffer, ranging. */
/* Start transmission, indicating that a response is expected so that reception is enabled automatically after the frame is sent and the delay
* set by dwt_setrxaftertxdelay() has elapsed. */
dwt_starttx(DWT_START_TX_IMMEDIATE | DWT_RESPONSE_EXPECTED);
/* We assume that the transmission is achieved correctly, poll for reception of a frame or error/timeout. See NOTE 8 below. */
while (!((status_reg = dwt_read32bitreg(SYS_STATUS_ID)) & (SYS_STATUS_RXFCG_BIT_MASK | SYS_STATUS_ALL_RX_TO | SYS_STATUS_ALL_RX_ERR)))
frame_seq_nb++;
uint32_t frame_len;
/* Check that the frame is the expected response from the companion "SS TWR responder" example.
if (memcmp(rx_buffer, rx_resp_msg, ALL_MSG_COMMON_LEN) == 0)
uint32_t poll_tx_ts, resp_rx_ts, poll_rx_ts, resp_tx_ts;
int32_t rtd_init, rtd_resp;
float clockOffsetRatio;
/* Retrieve poll transmission and response reception timestamps. See NOTE 9 below. */
poll_tx_ts = dwt_readtxtimestamplo32();
resp_rx_ts = dwt_readrxtimestamplo32();
/* Read carrier integrator value and calculate clock offset ratio. See NOTE 11 below. */
clockOffsetRatio = ((float)dwt_readclockoffset()) / (uint32_t)(1 << 26);
/* Get timestamps embedded in response message. */
resp_msg_get_ts(&rx_buffer[RESP_MSG_POLL_RX_TS_IDX], &poll_rx_ts);
resp_msg_get_ts(&rx_buffer[RESP_MSG_RESP_TX_TS_IDX], &resp_tx_ts);
/* Compute time of flight and distance, using clock offset ratio to correct for differing local and remote clock rates */
rtd_init = resp_rx_ts - poll_tx_ts;
rtd_resp = resp_tx_ts - poll_rx_ts;
tof = ((rtd_init - rtd_resp * (1 - clockOffsetRatio)) / 2.0) * DWT_TIME_UNITS;
distance = tof * SPEED_OF_LIGHT;
/* Display computed distance on LCD. */
snprintf(dist_str, sizeof(dist_str), "DIST: %3.2f m", distance);
test_run_info((unsigned char *)dist_str);
/* Clear RX error/timeout events in the DW IC status register. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_ALL_RX_TO | SYS_STATUS_ALL_RX_ERR);
/* Execute a delay between ranging exchanges. */
Sleep(RNG_DELAY_MS);
CODE 2 RX
These codes example codes from Makerfabs
and I using two Makerfabs ESP32 UWB DW3000 board
https://github.com/Makerfabs/Makerfabs-ESP32-UWB-DW3000
RX sends a set signal.
TX sends a signal back when it receives a set signal.
RX calculates the distance using the time between sending and receiving the signal.
It works but
The problem is that it takes 17.2 seconds to get the first distance data
After that, every frame rate(delay) I set will be output normally.
Through debugging, I found that
Here,I found that[SYS_STATUS_RXFCG_BIT_MASK] takes 17.2 seconds to change from 0 to 1
I've tried a variety of ways
Change or eliminate the timeout
Break while statement
etc...
But it always took 17.2 seconds
Both codes have that while statement
If I boot one board 10 sec later than other board, It will takes 27.2 sec for paring
AI says that 17.2 seconds is the internal registry reset time
But I don't have much knowledge in this field, so I have no idea what to do
