Ebay 1.44" inch ST7735 SPI 128*128 TFT LCD
First apologies if this post is not formatted correctly, it’s from my phone.
I just spent a frustrating 2hrs trying to get this lcd to work with my Wemos D1 mini:
https://wiki.wemos.cc/products:d1:d1_mini
LCD:
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F163236600496
They actually sent me this LCD which is different from the Ebay post:
According to the seller:
Specifications:
Driver IC: ST7735
Resolution: 128 x 128 pixels
IO interface:
RESET --directly to the microcontroller IO
CS --directly to the microcontroller IO
A0 --IO control registers select
SDA --IO control data transmission
SCK --IO control SPI bus
LED--High Level 3.3V backlight on
I’ve tried many different ways and when running ST77xx library example and editing the pin numbers, nada.
I’ve got two displays so I don’t think it’s hardware.
Going to try again in the morning, any advice appreciated.
Try using Bodmer's tft_espi library
@lesept I will do thanks :slight_smile:
lesept:
Got it working with my UNO, thanks. Just need now to see if it can work with my Wemos D1 mini :slight_smile:
