Hello, I am using an Uno R3 with an external 5v power supply going to 3 separate WS2813 strips. Using a heart beat sensor and Fast.Led I have the working code posted below where the LEDS "blink" to the heartbeat input.
I want to further this by having one LED strip blink to the heartbeat as it does currently in the code and the outer two strips then "echo" the middle LED strip or show the heartbeat blink delayed. I am newer and had a friend help me with the initial code so I am not entirely familiar with the best way to do this.
/* PACKAGES */
#include "FastLED.h"
#include <Wire.h>
#include "MAX30105.h"
/* GLOBAL VARIABLES */
#define MIN_BRIGHTNESS 20
#define LED_TYPE WS2813
#define COLOR_ORDER GRB
#define NUM_LEDS 288
#define num_strips 3
CRGB leds[NUM_LEDS];
uint8_t current_brightness = 40;
byte brightness_decrement = 40;
uint8_t color_at_index_on_strip[NUM_LEDS];
int led_offset_difference = 0;
int count_of_loop_iterations = 0;
uint8_t palette_switcher_index = 0;
MAX30105 particleSensor;
int most_recent_heartbeats[10];
int current_heartbeat_index = 0;
/* GRADIENTS */
DEFINE_GRADIENT_PALETTE( blue_gp ) {
0, 0, 218, 67, //
46, 0, 203, 107, //
176, 0, 159, 152, //
255, 33, 44, 190 //
DEFINE_GRADIENT_PALETTE( white_gp ) {
0, 255, 255, 255, //
46, 186, 202, 220, //
176, 120, 150, 185, //
255, 58, 95, 150 //
DEFINE_GRADIENT_PALETTE( red_gp ) {
0, 6, 255, 0, //
71, 0, 255, 153, //
122, 200, 200, 200, //
181, 110, 61, 6, //
255, 6, 255, 0 //
CRGBPalette16 currentPalette(blue_gp);
CRGBPalette16 targetPalette(white_gp);
/* LED FUNCTIONS */
void reset_leds() {
uint8_t middle = 16 / 2;
bool direction = false;
for (int i = 0; i < NUM_LEDS; i++) {
if (i % middle == 0) direction = !direction;
if (direction) color_at_index_on_strip[i] = i % middle;
else color_at_index_on_strip[i] = middle - (i % middle);
LEDS.setBrightness(MIN_BRIGHTNESS);
// for (uint8_t num : color_at_index_on_strip) Serial.println(num);
int get_array_size() {
return sizeof(most_recent_heartbeats) / sizeof(int);
int get_average() {
long sum = 0;
int length = get_array_size();
//Serial.println(length);
for (int i = 0; i < length; ++i) {
sum += most_recent_heartbeats[i];
int average = sum / length;
return average;
void set_next_most_recent(int value) {
most_recent_heartbeats[current_heartbeat_index] = value;
current_heartbeat_index = (current_heartbeat_index + 1) % get_array_size();
void set_next_palette() {
++palette_switcher_index;
if (palette_switcher_index > 2) palette_switcher_index = 0;
switch(palette_switcher_index) {
case 0:
currentPalette = blue_gp;
targetPalette = white_gp;
case 1:
currentPalette = white_gp;
targetPalette = blue_gp;
FastLED.addLeds <WS2813, 9>(leds, NUM_LEDS);
FastLED.addLeds <WS2813, 10>(leds, NUM_LEDS);
FastLED.addLeds <WS2813, 11>(leds, NUM_LEDS);
reset_leds();
// Initialize sensor
if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) {
Serial.println("MAX30105 was not found. Please check wiring/power.");
return;
//Setup to sense a nice looking saw tooth on the plotter
byte ledBrightness = 0x1F; //Options: 0=Off to 255=50mA
byte sampleAverage = 8; //Options: 1, 2, 4, 8, 16, 32
byte ledMode = 3; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
int sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
int pulseWidth = 411; //Options: 69, 118, 215, 411
int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange);
EVERY_N_MILLIS(25) {
for (int i = 0; i < NUM_LEDS; i++) leds[(i + led_offset_difference) % NUM_LEDS] = ColorFromPalette(currentPalette, i);
nblendPaletteTowardPalette(currentPalette, targetPalette, 500);
if (count_of_loop_iterations == 500) {
set_next_palette();
LEDS.setBrightness(current_brightness);
if (current_brightness <= MIN_BRIGHTNESS) current_brightness = MIN_BRIGHTNESS;
else current_brightness -= brightness_decrement;
++led_offset_difference;
++count_of_loop_iterations;
long current_scan = particleSensor.getIR() / 10;
set_next_most_recent(current_scan);
int average = get_average();
if (average > 9000) {
// Serial.print(average);
// Serial.print(" ");
// Serial.println(particleSensor.getIR() / 10);
if (current_scan - average > 3) current_brightness = 255;
LEDS.show();
