Hi everyone.
I'm working on Modbus communication with a Rockwell PLC but I'd like to know if anyone has seen a method that uses EIP IO or tags with an EDS file for quick setup and install?
Thanks.
Hi everyone.
Thanks.
I guess that should read EtherNet/IP. You shouldn't use acronyms here in the forum that are only common in part of the PLC world.
I'm not aware of an Arduino implementation but there is an opensource implementation that might be adopted to Arduino but expect quite some work. And use one of the Arduino boards with lots of memory, it doesn't look like a resource-friendly implementation.
