Today I was digging into the EEPROM.h library to see if there's a neat way of reading/writing a word instead of just a single byte - there appears not to be. However, what there DOES appear to be is a whole slew of assignment operators...
(edit: trimmed down the block so it's more obvious for people to READ THE ABOVE CODE BLOCK as it's the entire purpose of this thread)
It seems like the library has a setup to utilize EEPROM space similar to variables... but there aren't any examples and I can't understand these "structs" to figure out how to make use of this functionality.
For example, I'm guessing I can do something like this:
... and without ever touching "EEPROM.read()" or "EEPROM.write()", I've read the value, incremented it (with extra steps), and written it back to EEPROM. But I am completely making up that initial declaration syntax out of my arse because that's the entire subject here - I don't know how to call it up.
EEPtr is another part of it but that seems less useful
Google gave me nothing but copies of the eeprom.h source file itself when I try looking for "EERef" so I think this is worth documenting somewhere. The Arduino docs - https://www.arduino.cc/en/Reference/EEPROM - say nothing about this functionality.
I thought it was pretty obvious that I'm looking for documentation on this part of the EEPROM.h library that is beyond just "get and put".
These entire sections of the .h file aren't documented anywhere... no idea how they work, no examples on how to use them.
How do you use them?
More to the point, these appear to be ways of working with EEPROM values as if they were variables, so how does one declare such a variable to make use of this feature?
As has been pointed out, put() and get() work with any data type of any. Are you confusing them with write() and read() which only deal with single bytes ?
Wow, for the third time, I'm talking about an undocumented function of the library - and even in OP, I pasted the portion of EEPROM.h that is of interest. Please go back to the first post and read the contents of it. There is a code block in there that is exactly what I'm interested in.
"get() and put()" aren't even relevant here at all. Nothing involving function calls at all. What I'm trying to understand is the part of EEPROM.h that defines a bunch of operators, as if you can manipulate EEPROM values simply by assigning a variable.
Can y'all please read OP before jumping to "hurr durr do you not know how EEPROM.h works? you just eeprom.read() and eeprom.write() euhhh" like I'm a freaking moron?
Not reading anything I wrote, eh? Might want to apply to work for eBay or Amazon customer service, they take people with bad reading comprehension like that. You really think I need help finding the Arduino EEPROM reference page, which I said DOES NOT HAVE documentation for these functions in the code?
Jesus, I thought this would be a quick and easy answer for someone that could read the code, but just finding anyone that can even read the EEPROM.h file seems to be hard to find...
FalconFour:
You might want to edit that bit as well, most people reading the start of your original message will be thinking why is put() not a neat way of writing a word with the EEPROM.h library ?
the description was explained higher up on the code:
EERef class.
This object references an EEPROM cell.
Its purpose is to mimic a typical byte of RAM, however its storage is the EEPROM.
This class has an overhead of two bytes, similar to storing a pointer to an EEPROM cell.
struct EERef{
EERef( const int index )
: index( index ) {}
//Access/read members.
uint8_t operator*() const { return eeprom_read_byte( (uint8_t*) index ); }
operator const uint8_t() const { return **this; }
srnet:
More apropos advice - Take the chip off your shoulder (i.e. lose the bad attitude) when asking for free help.
Lordy, thank you. This is the subject of the post, nothing else. Every reply prior to this had ignored this subject or mis-diagnosed the clearly stated case. I return respect when it's given, and I mirror disrespect the same. Earlier replies were very disrespectful, thinking I'm stupid for not reading (non-existent) docs on this subject. They might notice that EERef and EEPtr are entirely undocumented... but they couldn't read past "EEPROM.h" and thinking it's durr-durr basic.
The declaration syntax, "EEPtr ptr1(0)" and "EERef var1(1)" is what I didn't know about.
So, you can declare EEPROM variables with this neat new system, that will automatically read and write EEPROM as if it were a standard RAM variable. That's pretty nifty.
At least one earlier reply pointed out that your statement
was wrong which I felt important to point out whatever the subject of the thread
