EEPROM to .csv file?
Can data from the internal EEPROM be saved as a .csv file?
mayamac-seid:
Yes.
You could write a sketch.
#include <EEPROM.h>
  for (int i=0; i<1024; i++)
    Serial.print(EEPROM[i]);
    Serial.print(", ");
void loop() {}
To save data sent by the Arduino using Serial.print(), instead of the serial monitor, use a terminal program like TeraTerm and enable logging to a text file.
jremington:
...or use Serial Monitor, Edit->Select All, Edit->Copy and paste the text into the text editor of your choice. You may even be able to paste directly into a spreadsheet.
mayamac-seid:
As has been said, the answer is yes but what is your application for this ?
