egArray was not declared in this scope
I'm doing a problem to print the array again in reverse order, but it keeps showing that "egArray was not declared in this scope". Can anyone help me?
  int egArray[10]={8,7,6,3,2,1,5,4,9,10};
  int num;
  for ( int index=egArray.length - 1; index > =0 ; index--) {
     Serial.println(egArray[index]);
Its true?
If you read the instructions on how to use the forum well,
" How to get the best out of this forum"
so you shouldn't post code image.
Post the complete code using the appropriate tags.
Sorry, I had no idea about this. Will change right away.
your array only exists inside the setup() function by its a local variable.
To use it in other functions it needs to be declared as global.
Study about variables.
Here is also giving compilation error:
.lengh is used to "Strings" .
"length() - Arduino Reference"
I modified it to look like this:
sizeof(egArray) -1
As the array is of "int", and int in arduino occupies 2, the size of your array will be 20
try this code:
// int egArray[10] = {8,7,6,3,2,1,5,4.9,10};   //  <<<<<--------- . between 4 and 9 my fault
 int egArray[10] = {8,7,6,3,2,1,5,4,9,10};
  delay(100);
  //for(int index = sizeof(egArray)/2;  index >= 0; index--)
 for(int index = (sizeof egArray / sizeof (int)) -1; index >= 0; index--)
  {Serial.println(egArray[index]);
make this change
  int num;
read about
WARNING: 'sizeof' returns the size IN BYTES. Your 9-int array has a size of 18 (or 36 on a 32-bit processor). You want:
WARNING: Your 'int' array contains a 4.9 which will be truncated to 4.
Tks @johnwasser
