I am trying to connect my Arduino/elegoo mega 2560 r3 with the m6e nano rfid using hardware serial I made the changes to the code for the library for reading the tag, I made sure the switch is in the HW - UART, and used the serial2 of the mega and after uploading code it shows this in the serial monitor:
and it is not detecting the tag at all
This is the connection, and I ensured the wiring is also right.
here is the code:
Reading multiple RFID tags, simultaneously!
By: Nathan Seidle @ SparkFun Electronics
Date: October 3rd, 2016
https://github.com/sparkfun/Simultaneous_RFID_Tag_Reader
Single shot read - Ask the reader to tell us what tags it currently sees. And it beeps!
// Library for controlling the RFID module
#include "SparkFun_UHF_RFID_Reader.h"
// Create an instance of the RFID module
RFID rfidModule;
// Use Hardware Serial2 for communication with the RFID module
#define rfidSerial Serial2 // Use Serial2 for the Elegoo Mega 2560 R3
// Set the baud rate for the RFID module
#define rfidBaud 115200 // Set baud rate to 115200 for hardware serial
// Specify which module you are using
#define moduleType ThingMagic_M6E_NANO
// #define moduleType ThingMagic_M7E_HECTO
#define BUZZER1 9
//#define BUZZER1 0 //For testing quietly
#define BUZZER2 10
pinMode(BUZZER1, OUTPUT);
pinMode(BUZZER2, OUTPUT);
digitalWrite(BUZZER2, LOW); //Pull half the buzzer to ground and drive the other half.
while (!Serial);
Serial.println("Initializing...");
if (setupRfidModule(rfidBaud) == false)
Serial.println("Module failed to respond. Please check wiring.");
while (1); // Freeze!
rfidModule.setRegion(REGION_NORTHAMERICA); // Set to North America
rfidModule.setReadPower(500); // 5.00 dBm
Serial.println(F("Press a key to scan for a tag"));
while (!Serial.available()); // Wait for user to send a character
Serial.read(); // Throw away the user's character
byte myEPC[12]; // Most EPCs are 12 bytes
byte myEPClength;
byte responseType = 0;
while (responseType != RESPONSE_SUCCESS)
myEPClength = sizeof(myEPC); // Length of EPC is modified each time .readTagEPC is called
responseType = rfidModule.readTagEPC(myEPC, myEPClength, 500); // Scan for a new tag up to 500ms
Serial.println(F("Searching for tag"));
// Beep!
tone(BUZZER1, 2093, 150); // C
delay(150);
tone(BUZZER1, 2349, 150); // D
delay(150);
tone(BUZZER1, 2637, 150); // E
delay(150);
// Print EPC
Serial.print(F(" epc["));
for (byte x = 0; x < myEPClength; x++)
if (myEPC[x] < 0x10) Serial.print(F("0"));
Serial.print(myEPC[x], HEX);
Serial.print(F(" "));
Serial.println(F("]"));
// Gracefully handles a reader that is already configured and already reading continuously
boolean setupRfidModule(long baudRate)
rfidModule.begin(rfidSerial, moduleType); // Tell the library to communicate over serial port
// Test to see if we are already connected to a module
rfidSerial.begin(baudRate); // Start serial at desired baud rate
delay(100); // Wait for port to open
// Ignore initial messages from the module
while (rfidSerial.available())
rfidSerial.read();
rfidModule.getVersion();
if (rfidModule.msg[0] == ERROR_WRONG_OPCODE_RESPONSE)
rfidModule.stopReading(); // Stop continuous reading
Serial.println(F("Module continuously reading. Asking it to stop..."));
delay(1500);
// The module did not respond, assume it's been powered on and is communicating at 115200bps
rfidSerial.begin(115200); // Start serial at 115200
rfidModule.setBaud(baudRate); // Set module baud rate
rfidSerial.begin(baudRate); // Start the serial port at user's chosen baud rate
delay(250);
// Test the connection
if (rfidModule.msg[0] != ALL_GOOD)
return false; // Something is not right
// Set protocol and antenna
rfidModule.setTagProtocol(); // Set protocol to GEN2
rfidModule.setAntennaPort(); // Set TX/RX antenna ports to 1
return true; // We are ready to rock
Please kindly let me know what I am doing wrong. Thank you
