Elegoo - Problem Uploading to Board
Hey, everyone! Having a hell of a time with this Elegoo Arduino car kit I bought off of Amazon.
I followed the (badly written) instructions to the letter, but the images they provided of the boards weren't the same boards I have to work with.
Now that it's done, I can't even upload a simple Blink program to it; I just keep getting the repeated error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xee
It does that 10 times and then says "problem uploading to board".
What I've tried:
  1. Uninstalling/Reinstalling the driver.
  2. Downloading/Installing the driver for the cheap Chinese knockoff chip I realize I got (CH341SER).
  3. Punched the wall repeatedly.
  4. Lay awake at night for hours because every time I close my eyes, I see "problem uploading to board" behind my eyelids.
Now I'm coming here in the desperate hope that you guys can help me. My system config is as follows:
Board - ATMEGA328P
Computer - ASUS ROG (Windows 10)
I'm a super-noobie at this stuff, so use small words and let me know what other information you need.
Cheers!
Jordan
Bump
You haven't linked the instructions, so we can't comment on that.
Driver is working, something else is not.
Could be anything, hardware failure, wrong board selected (try telling it it's a nano, pro mini, or official uno), wrong bootloader present on chip, no bootloader present on chip, board has been sawn in half and the side with the microcontroller discarded.
The sync error contains very little useful information, so it's a real pain to help people with. That's why you don't get much response on it. The forum is filled with people asking for help with it, and really all you can do is give a laundry list of possibilities and tell them to figure out which one it is.
At the very least, you've given me a few thoughts. Although I WILL say that I'm pretty sure the board hasn't been sawn in half. :stuck_out_tongue:
I'll give these a shot and get back. Thanks!!
JG
When uploading, do you see the LED on pin 13 blinking twice? This indicates that the chip has been reset, and that it is working correctly. If it doesn't, then your chip might be dead, or it has the wrong bootloader installed, or just no bootloader at all.
Every time the chip resets, a small program, called the bootloader, is executed. Its purpose is to receive new sketches, and write them to the internal memory.
When you hit 'upload' in the Arduino IDE, it resets the Arduino, and then tells the bootloader that a new sketch has to be uploaded. The bootloader should then respond that it is ready to receive the new sketch. The error you get is just telling you that the computer doesn't receive a reply from the bootloader, so it can't upload.
As DrAzzy said, there's a whole list of possible causes, making it really hard to troubleshoot ...
It could be because you connected something to pins 0 and/or 1, because the microcontroller is just dead, because it doesn't have the right bootloader, because the computer expects the wrong response because you selected the wrong board in the Tools menu, etc ...
Pieter
Well, I'm a complete n00b; if I were to provide pictures of my build, would you at least be able to tell me if I've got everything wired right?
We could check the wiring, yes, but there's probably more to it than just the wiring ... Anyway, it would be a step in the right direction if we could rule bad wiring out. :wink:
Thanks, guys.
Quick thing I found out; if I detach the expansion board, I'm able to upload sketches just fine. Plug in the expansion board; busted.
Thoughts?
There's probably something connected to pins 1 and 0. Those pins are used for the communication with the PC as well, so you can't use them while uploading, or while using the Serial class in your sketch.
The problem is that the expansion board slots directly into both pins 0 and 1. Do I clip those pins or what?
JordanG:
No, you'll probably need them later, just take off the shield when uploading.
I think the problem is the bluetooth module, if you get it out before you upload the sketch, it lets you just fine.
There is a real problem uploading programme to smart robot car kit v1.0 I bought this kit to build not to be
a computer programmer
I have sent an email to elegoo today Has anyone tried that and if so what response did you get
if any?
No one seems to know what the problem is, please help or it is going back to amazon
Regards Colin
This is not a problem with the board, it's normal.
The Arduino uses pins 0 and 1 (UART0, or Serial) to communicate with the on-board USB-To-Serial converter. This means that in order to upload a new program to the Arduino, you need these pins. If you connect anything else to pins 0 and 1, it will interfere with the upload.
To communicate with the shield, you also need UART0, so you have to connect it to pins 0 and 1. That's fine, as long as you disconnect it when uploading new programs.
Pieter
Just for anyone that's having this problem. It states in the instruction manual that you cannot upload a program while the Bluetooth module is connected. The problem may be that it instructs you to upload your program, then on the next page it informs you about the error.
