// I am trying to enable the INT1 interrupt when sudden acceleration occurs. ESP32 interfaced with LSMDSRX via i2c //
#include <Wire.h>
#define LSM6DSR_ADDRESS 0x6B // I2C address of the sensor
#define CTRL1_XL_REG 0x10 // Register address for accelerometer control
#define CTRL2_G_REG 0x11 // Register address for gyroscope control
#define ACCEL_DATA_REG 0x28 // Register address for accelerometer data (LSB)
#define GYRO_DATA_REG 0x22 // Register address for accelerometer data (LSB)
#define INT1_CTRL_REG 0x0D // Register address for INT1_CTRL
#define INT1_PIN 34 // This could be any digital pin on the ESP32 for INT1
byte receivedData[6];
int16_t accelX;
int16_t accelY;
int16_t accelZ;
double x3;
double y3;
double z3;
#define minVal -8315
#define maxVal 8315
Wire.begin(4, 5); // Initialize I2C communication
Serial.begin(115200); // Start serial communication for debugging
initializeSensor();
pinMode(INT1_PIN, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(INT1_PIN), handleLSMInterrupt, RISING);
readAndPrintSensorData();
void handleLSMInterrupt() {
void initializeSensor() {
// Configure accelerometer settings
Wire.beginTransmission(LSM6DSR_ADDRESS);
Wire.write(CTRL1_XL_REG);
// Set the accelerometer scale to ±2g (you can choose ±4g, ±8g, or ±16g as well)
Wire.write(0x18);
// Enable the accelerometer data ready interrupt on INT1 pin
Wire.write(0x01 << 3); // Bit 3 corresponds to accelerometer data ready interrupt
Wire.endTransmission();
void readAndPrintSensorData() {
Wire.write(GYRO_DATA_REG);
Wire.requestFrom(LSM6DSR_ADDRESS, 6, false); // Request 6 bytes (X, Y, Z accelerometer data)
for (int i = 0; i < 6; i++) {
receivedData[i] = Wire.read();
accelX = (receivedData[1] << 8) | receivedData[0]; // Combine LSB and MSB
accelY = (receivedData[3] << 8) | receivedData[2];
accelZ = (receivedData[5] << 8) | receivedData[4];
int xAng = map(accelX, minVal, maxVal, -90, 90);
int yAng = map(accelY, minVal, maxVal, -90, 90);
int zAng = map(accelZ, minVal, maxVal, -90, 90);
x3 = RAD_TO_DEG * (atan2(-yAng, -zAng) + PI);
y3 = RAD_TO_DEG * (atan2(-xAng, -zAng) + PI);
z3 = RAD_TO_DEG * (atan2(-yAng, -xAng) + PI);
Serial.print("X:");
Serial.println(x3);
I need suggestion to correct this code
