Enabled, or enabled?
Just installed the Arduino IDE 2.3.2 on a newly installed system and get this.
Any Ideas?
Stuart
Please learn how to use the forum, instructions are HERE
Welcome to the forum
Which board have you got selected in the IDE ?
It's a nologo esp32 c3 supermini. I have since discovered that if i use the MakerGO ESP C3 Supermini, I dont have this problem. I have changed the board selected and it is now fine.i bought the board on aliexpress,so i have no idea of the branding of the actual device.
I think that below is the explanation.
If you analyse the boards.txt on your PC (or on the web: arduino-esp32/boards.txt at master · espressif/arduino-esp32 · GitHub), you will find the following
makergo_c3_supermini.name=MakerGO ESP32 C3 SuperMini
makergo_c3_supermini.menu.CDCOnBoot.default=Enabled
makergo_c3_supermini.menu.CDCOnBoot.default.build.cdc_on_boot=1
makergo_c3_supermini.menu.CDCOnBoot.dis_cdc=Disabled
makergo_c3_supermini.menu.CDCOnBoot.dis_cdc.build.cdc_on_boot=0
and
Nologo ESP32C3 Super Mini
nologo_esp32c3_super_mini.menu.CDCOnBoot.default=Enabled
nologo_esp32c3_super_mini.menu.CDCOnBoot.default.build.cdc_on_boot=1
nologo_esp32c3_super_mini.menu.CDCOnBoot.cdc=Enabled
nologo_esp32c3_super_mini.menu.CDCOnBoot.cdc.build.cdc_on_boot=1
You can see that the Nologo board has two enabled entries and both have the same effect on the cdc_on_boot flag.
Another funny below
SparkFun Pro Micro - ESP32C3
sparkfun_pro_micro_esp32c3.menu.CDCOnBoot.cdc=Enabled
sparkfun_pro_micro_esp32c3.menu.CDCOnBoot.cdc.build.cdc_on_boot=1
sparkfun_pro_micro_esp32c3.menu.CDCOnBoot.default=Enabled
sparkfun_pro_micro_esp32c3.menu.CDCOnBoot.default.build.cdc_on_boot=0
Although there are two entries with enabled, the effect is different on the cdc_on_boot flag.
