ENC28J60 Ethernet module and pinout?
Hello, I have been trying to figure out the library and pinout for the ENC28J60 Ethernet module. Does anyone know where I can find the correct one that works library and pinout? there are a few out there I can not get to work. I have tried them all.
Joseph
How are we supposed to recommend a library if you have already tried them all?
Better, a list of libraries you have tried and maybe the sketch you used to test if they worked or not and possibly any error message generated during compilation and/or operation
Hello you are right. Forgot to list the sites I used so far. But I found my problem. For some odd reason I had to use a older version of IDE and somehow got them to upload and work with no problem. The newer one was giving a lot of errors. I had to look at the errors closely because I missed something I didn’t understand and had to look up the error online to figure out what it was.
Joseph
HI @josephchrzempiec
There are some modules that use this chip(ENC28J60)
Here is the datasheet, pinout and schematic of what I use.
ENC28J60-H.pdf (449.7 KB)
And use this libs:
ETHER_28J60.zip (6.6 KB)
etherShield.zip (17.0 KB)
RV mineirin
Thank you. I'm having a hard time wiring this up. That i almost gave it up. When i finally wired it up the libraries won't compile because the ones i found online was for a older IDE.
Joseph
Thank you very much for that. It works now. The other libraries i found online use the older IDE. In the newer IDE it wouldn't even compile.
Joseph
