I am currently trying to run a simple code to command an angular displacement for an encoded motor and after hours of searching, I stumbled upon the attached code (with some modifications for the arduino board used). The motor is currently just spinning but I want to be able to command to turn a specific angle.
I am using an MKRZero
Motor driver:
Encoded motor:
#define InA1 7 // INA motor pin
#define InB1 6 // INB motor pin
#define PWM1 2 // PWM motor pin
#define encodPinA1 5 // encoder A pin
#define encodPinB1 4 // encoder B pin
#define LOOPTIME 100 // PID loop time
#define FORWARD 1 // direction of rotation
#define BACKWARD 2 // direction of rotation
unsigned long lastMilli = 0; // loop timing
unsigned long lastMilliPrint = 0; // loop timing
long count = 0; // rotation counter
long countInit;
long tickNumber = 0;
boolean run = false; // motor moves
pinMode(InA1, OUTPUT);
pinMode(InB1, OUTPUT);
pinMode(PWM1, OUTPUT);
pinMode(encodPinA1, INPUT);
pinMode(encodPinB1, INPUT);
digitalWrite(encodPinA1, HIGH); // turn on pullup resistor
digitalWrite(encodPinB1, HIGH);
attachInterrupt(1, rencoder, FALLING);
moveMotor(FORWARD, 50, 1200*2); // direction, PWM, ticks number
delay(5000);
//moveMotor(BACKWARD, 100, 2400*2); // 464=360°
//delay(3000);
void moveMotor(int direction, int PWM_val, long tick) {
countInit = count; // abs(count)
tickNumber = tick;
if(direction==FORWARD) motorForward(PWM_val);
else if(direction==BACKWARD) motorBackward(PWM_val);
void rencoder() { // pulse and direction, direct port reading to save cycles
if (encodPinB1 & 0b00000001) count++; // if(digitalRead(encodPinB1)==HIGH) count_r ++;
else count--; // if (digitalRead(encodPinB1)==LOW) count_r --;
if(run)
if((abs(abs(count)-abs(countInit))) >= tickNumber) motorBrake();
void motorForward(int PWM_val) {
analogWrite(PWM1, PWM_val);
digitalWrite(InA1, LOW);
digitalWrite(InB1, HIGH);
run = true;
void motorBackward(int PWM_val) {
digitalWrite(InA1, HIGH);
digitalWrite(InB1, LOW);
run = true;
void motorBrake() {
analogWrite(PWM1, 0);
run = false;
