Encoder reading with interrupts
quoting a PM
After connecting my circuit to osciloscope I see that:
  • input encoder pins SS,8:
    SS - have about 1,2V amplitude while rotating ( I think its because Im using serial communication)
    8 - have correct value, 5V amplitude
  • volume encoder pins 13,SCK
    13 - have correct value, 5V amplitude, of course I have delete lines with LED blinking
    SCK - have correct value, 5V amplitude
anyway, each step is correct on osciloscope, only in software maybe there is some trick to have one gap step between changing direction of rotation
Without a schematic of your encoder-circuit and screenshots of your oscilloscope whith explanation which curves shows what the given info can only be used to speculate.
You seem to have not yet understood that posting fast too few information is slowing down finding a solution
best regards Stefan
Here I have sketch for 2 encoders:
/* Demo-Code that uses the Rotary-library from GitHub-User https://github.com/buxtronix
 * using his library https://github.com/buxtronix/arduino/tree/master/libraries/Rotary
 * in combination with a timer-interrupt executed 10000 times per second
 * Copyright 2023 StefanL38. Licenced under the GNU GPL Version 3.
 * A T T E N T I O N !
 * this demo-code uses Timer1 which is used by other libraries too.
 * This means using this code can interfere with other libraries
 * causing malfunction of both
 * This demo-code uses the TimerInterrupt.h-library from here
 * https://github.com/khoih-prog/TimerInterrupt/tree/master
 * The examples in the GiPo show how to use different timers
 * The demo-code simply prints the value of variable myCounter
 * each time the value of the variable changes
#define USE_TIMER_1     true
#if ( defined(__AVR_ATmega644__) || defined(__AVR_ATmega644A__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644PA__)  || \
        defined(ARDUINO_AVR_UNO) || defined(ARDUINO_AVR_NANO) || defined(ARDUINO_AVR_MINI) ||    defined(ARDUINO_AVR_ETHERNET) || \
        defined(ARDUINO_AVR_FIO) || defined(ARDUINO_AVR_BT)   || defined(ARDUINO_AVR_LILYPAD) || defined(ARDUINO_AVR_PRO)      || \
        defined(ARDUINO_AVR_NG) || defined(ARDUINO_AVR_UNO_WIFI_DEV_ED) || defined(ARDUINO_AVR_DUEMILANOVE) || defined(ARDUINO_AVR_FEATHER328P) || \
        defined(ARDUINO_AVR_METRO) || defined(ARDUINO_AVR_PROTRINKET5) || defined(ARDUINO_AVR_PROTRINKET3) || defined(ARDUINO_AVR_PROTRINKET5FTDI) || \
        defined(ARDUINO_AVR_PROTRINKET3FTDI) )
#endif
// To be included only in main(), .ino with setup() to avoid `Multiple Definitions` Linker Error
#include "TimerInterrupt.h"
#define TIMER1_INTERVAL_MS    1
#include <Rotary.h>
// Rotary encoder is wired with the common to ground and the two
// outputs to pins 5 and 6.
const byte channel_A_Pin = SS;
const byte channel_B_Pin = 8;
Rotary rotary = Rotary(channel_A_Pin, channel_B_Pin);
const byte channel_C_Pin = MISO;
const byte channel_D_Pin = SCK;
Rotary rotary1 = Rotary(channel_C_Pin, channel_D_Pin);
unsigned long myISR_TimerFrequency = 10000;
// myCounter that will be incremented or decremented by rotation.
// as this variable is changed in an interrupt-service-routine
// this variable MUST !! be declared volatile to make sure
// that it works properly !
volatile uint8_t myCounter = 0;
uint8_t last_myCounter = 0;
volatile uint8_t myCounter1 = 0;
uint8_t last_myCounter1 = 0;
void TimerHandler1() {
  unsigned char result = rotary.process();
  unsigned char result1 = rotary1.process();
  // depending on having detected rotation
  if (result == DIR_CW) {
    myCounter++;
  else if (result == DIR_CCW) {
    myCounter--;
  if (result1 == DIR_CW) {
    myCounter1++;
  else if (result1 == DIR_CCW) {
    myCounter1--;
void PrintFileNameDateTime() {
  Serial.println( F("Code running comes from file ") );
  Serial.println( F(__FILE__) );
  Serial.print( F("  compiled ") );
  Serial.print( F(__DATE__) );
  Serial.print( F(" ") );
  Serial.println( F(__TIME__) );
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - startOfPeriod >= TimePeriod ) {
    // more time than TimePeriod has elapsed since last time if-condition was true
    startOfPeriod = currentMillis; // a new period starts right here so set new starttime
    return true;
  else return false;            // actual TimePeriod is NOT yet over
unsigned long MyTestTimer = 0;  // Timer-variables MUST be of type unsigned long
const byte    OnBoard_LED = 13;
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer, BlinkPeriod) ) {
    digitalWrite(IO_Pin, !digitalRead(IO_Pin) );
  Serial.println("Setup-Start");
  PrintFileNameDateTime();
  Serial.print(F("\nStarting Argument_None on "));
  Serial.println(BOARD_TYPE);
  Serial.println(TIMER_INTERRUPT_VERSION);
  Serial.print(F("CPU Frequency = "));
  Serial.print(F_CPU / 1000000);
  Serial.println(F(" MHz"));
  // Timer0 is used for micros(), millis(), delay(), etc and can't be used
  // Select Timer 1-2 for UNO, 1-5 for MEGA, 1,3,4 for 16u4/32u4
  // Timer 2 is 8-bit timer, only for higher frequency
  // Timer 4 of 16u4 and 32u4 is 8/10-bit timer, only for higher frequency
  ITimer1.init();
  // Using ATmega328 used in UNO => 16MHz CPU clock ,
  // For 16-bit timer 1, 3, 4 and 5, set frequency from 0.2385 to some KHz
  // For 8-bit timer 2 (prescaler up to 1024, set frequency from 61.5Hz to some KHz
  if (ITimer1.attachInterruptInterval(TIMER1_INTERVAL_MS, TimerHandler1)) {
    Serial.print(F("Starting  ITimer1 OK, millis() = ")); Serial.println(millis());
  else {
    Serial.println(F("Can't set ITimer1. Select another freq. or timer"));
  BlinkHeartBeatLED(OnBoard_LED, 250);
  // check if value has changed
  if (last_myCounter != myCounter) {
    // only if value REALLY HAS changed
    byte difference = abs(last_myCounter - myCounter);
    if (difference != 1) {
      Serial.println("difference != 1 counter jumped !!");
    last_myCounter = myCounter; // update last_myCounter
    Serial.print("myCounter=");
    Serial.println(myCounter);
  if (last_myCounter1 != myCounter1) {
    byte difference = abs(last_myCounter1 - myCounter1);
    last_myCounter1 = myCounter1; // update last_myCounter
    Serial.print("myCounter1=");
    Serial.println(myCounter1);
as I wrote to Stefan, when Im rotate in one direction all is ok, but when I go to second direction, first move is a gap, next move is read correct.
I have already connect input pins of arduino to the oscilloscope and I see:
Also because of new encoder library Im out of space of flash. Now 108% :frowning:
what library is this? Please post a github-link.
Investing maybe 10 minutes into a decent and detailed posting can speed up finding a solution a mimimum of 30 minutes. Often hours or days. So investing 10 minutes into a detailed posting is a very good investion.
If your µC is already overloaded with the code like posted in post #44
I recommend using a Seeeduino XIAO:
three times faster clock: 48 Mhz
four times bigger bitwitdh: 32 bit
bigger RAM 32kB
bigger flash 256kB
With posting this schematic of a hardware-debouncing I made the decision to point on this
tips how to improve your posting style
Seeduino XIAO looks good. Just to little of pins.
I have uploaded my sketch after disabling bootloader. All works, only with this one I have problem. On previous rotary library all works (I have tested this).
if (result1 == DIR_CW){
switch (count) {
        case 0:
switch (count) {
        case 0:
          led1 = led1 + 1;
          if (led1 > 250) led1 = 0;
if (led1 <= 42.5) {
    currentColorValueRed = 255;
    currentColorValueGreen = led1 * 6;
    currentColorValueBlue = 0;
  if ((led1 > 42.5) && (led1 <= 85)) {
    currentColorValueRed = 255 - (led1 - 43) * 6;
    currentColorValueGreen = 255;
  if ((led1 > 85) && (led1 <= 127.5)) {
    currentColorValueRed = 0;
    currentColorValueBlue = (led1 - 85) * 6;
  if ((led1 > 127.5) && (led1 <= 170)) {
    currentColorValueGreen = 255 - (led1 - 127.5) * 6;
    currentColorValueBlue = 255;
  if ((led1 > 170) && (led1 <= 212.5)) {
    currentColorValueRed = (led1 - 170) * 6;
    currentColorValueGreen = 0;
  if ((led1 > 212.5) && (led1 <= 255)) {
    currentColorValueBlue = 255 - (led1 - 212.5) * 6;
  analogWrite(redPin, currentColorValueRed);
  analogWrite(bluePin, currentColorValueBlue);
  analogWrite(greenPin, currentColorValueGreen);
if (result1 == DIR_CCW){
switch (count) {
        case 0:
    led1 = led1 - 1;
          if (led1 < 0) led1 = 250;
if (led1 <= 42.5) {
its freeze here. all variables are same as it is in old sketch with old rotary library,like this:
byte redPin = 11;
byte greenPin = 9;
byte bluePin = 6;
byte currentColorValueRed;
byte currentColorValueGreen;
byte currentColorValueBlue;
byte led1 = 10;
byte led2 = 20;
byte led3 = 30;
byte led4 = 40;
byte led5 = 50;
byte led6 = 60;
same situation if I will change variables to float. Also same situation when I will delete "X.5" from 127.5 to 127 and other)
I'm very serious about this. You should read it
The problem:
  • when Im rotating to the left , value should go from 0 to 255 => 0,255,254,253...
  • when Im rotating to the right, value should go from 0 to 255 => 0,1,2,3,4...255
Now to the left I can go to from position 0 to 170 then arduino freezes. Like it was this step:
Going from 0 to upper (rotating to the right) frezze arduino immediately
Also rotating to the left should go from 0.. to 250:
led1 = led1 - 1;
but it starts from 255
There are so many users in the forum with questions.
I have to choose which one to support.
As your very last chance to be supported
either you are able to post your complete sketch as a code-section
and
post serial printing as a code-section or I will terminate my support for you.
If you like to chat use snapchat , chatGPT or whatever
Problem was with analogWrite on pins vs Timer1 for Rotary library :
11 - D6
09 - 14
6 - 11
after changing timer from 1 to 4 problem is solved.
