In the following project only the encoders that are connected to interrupt pins will count up and down, the rest will only count up. The project is for sound control dials that will be turned by hand.
Will I need to get a board that has more interrupt pins? or is there a work around?
code:
/* Encoder Library - TwoKnobs Example
* http://www.pjrc.com/teensy/td_libs_Encoder.html
* This example code is in the public domain.
#include <Encoder.h>
const int NUM_SLIDERS = 5;
#define ENCODER_DO_NOT_USE_INTERRUPTS
#define NUMPIXELS 5
#define PIN 7
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int analogSliderValues[NUM_SLIDERS];
// Change these pin numbers to the pins connected to your encoder.
// Best Performance: both pins have interrupt capability
// Good Performance: only the first pin has interrupt capability
// Low Performance: neither pin has interrupt capability
Encoder knobMaster(2,11);
Encoder knobDiscord(4 , 6);
Encoder knobChrome(12,8);
Encoder knobGaming(3,9);
Encoder knobMusic(10, 5);
int Master, Discord, Chrome, Gaming, Music;
int masterMute, discordMute, chromeMute, gamingMute, musicMute;
int masterDebounceTime;
// avoid using pins with LEDs attached
//buttons: 1, A5, A2, A1, A6
const int masterButton=A4;
const int discordButton=A5;
const int chromeButton=A2;
const int gamingButton=A0;
const int musicButton=A1;
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 175; // the debounce time; increase if the output flickers
int masterState=0;
int discordState=0;
int chromeState=0;
int gamingState=0;
int musicState=0;
Serial.begin(4800);
pinMode(masterButton, INPUT_PULLUP);
pinMode(discordButton, INPUT_PULLUP);
pinMode(chromeButton, INPUT_PULLUP);
pinMode(gamingButton, INPUT_PULLUP);
pinMode(musicButton, INPUT_PULLUP);
analogSliderValues[0] = 512;
knobMaster.write(51);
analogSliderValues[1] = 512;
knobDiscord.write(51);
analogSliderValues[2] = 512;
knobChrome.write(51);
analogSliderValues[3] = 512;
knobGaming.write(51);
analogSliderValues[4] = 512;
knobMusic.write(51);
pixels.begin();
pixels.clear();
masterMute=0;
discordMute=0;
chromeMute=0;
gamingMute=0;
musicMute=0;
Master = knobMaster.read();
Discord = knobDiscord.read();
Chrome = knobChrome.read();
Gaming = knobGaming.read();
Music = knobMusic.read();
checkButtons();
checkEncoders();
sendSliderValues();
//printSliderValues();//debug
pixels.show();
void sendSliderValues() {
String builtString = String("");
for (int i = 0; i < NUM_SLIDERS; i++) {
builtString += String((int)analogSliderValues[i]);
if (i < NUM_SLIDERS - 1) {
builtString += String("|");
Serial.println(builtString);
void printSliderValues() {
String printedString = String("Slider #") + String(i + 1) + String(": ") + String(analogSliderValues[i]) + String(" mV");
Serial.write(printedString.c_str());
Serial.write(" | ");
Serial.write("\n");
void checkButtons(){
if (digitalRead(masterButton)==0 && masterState ==0){
masterMute = !masterMute ;
masterState =1;
delay(25);
if (digitalRead(masterButton)==1){
masterState=0;
if (digitalRead(discordButton)==0 && discordState ==0){
discordMute = !discordMute ;
discordState =1;
delay(25);
if (digitalRead(discordButton)==1){
discordState=0;
if (digitalRead(chromeButton)==0 && chromeState ==0){
chromeMute = !chromeMute ;
chromeState =1;
delay(25);
if (digitalRead(chromeButton)==1){
chromeState=0;
if (digitalRead(gamingButton)==0 && gamingState ==0){
gamingMute = !gamingMute ;
gamingState =1;
delay(25);
if (digitalRead(gamingButton)==1){
gamingState=0;
if (digitalRead(musicButton)==0 && musicState ==0){
musicMute = !musicMute ;
musicState =1;
delay(25);
if (digitalRead(musicButton)==1){
musicState=0;
void checkEncoders(){
if (Master > 0 && Master < 102 && masterMute==0){
analogSliderValues[0]=Master*10;
pixels.setPixelColor(4, pixels.Color(0, 150, 0));
else if (masterMute==0 && (Master > 102 || Master==102)){
analogSliderValues[0]=102*10;
knobMaster.write(102);
else if (masterMute==1){
analogSliderValues[0]=0;
pixels.setPixelColor(4, pixels.Color(150, 0, 0));
else {
knobMaster.write(0);
if (Discord > 0 && (Discord < 102 && discordMute==0)){
analogSliderValues[1]=Discord*10;
pixels.setPixelColor(3, pixels.Color(0, 150, 0));
else if (discordMute==0 && Discord > 102 || Discord==102){
analogSliderValues[1]=102*10;
knobDiscord.write(102);
else if (discordMute==1){
analogSliderValues[1]=0;
pixels.setPixelColor(3, pixels.Color(150, 0, 0));
else {
knobDiscord.write(0);
if (chromeMute==0 && Chrome > 0 && Chrome < 102){
analogSliderValues[2]=Chrome*10;
pixels.setPixelColor(2, pixels.Color(0, 150, 0));
else if (chromeMute ==0 && (Chrome > 102 || Chrome==102)){
analogSliderValues[2]=102*10;
knobChrome.write(102);
else if (chromeMute==1){
analogSliderValues[2]=0;
pixels.setPixelColor(2, pixels.Color(150, 0, 0));
else {
knobChrome.write(0);
if (gamingMute==0 && Gaming > 0 && Gaming < 102){
analogSliderValues[3]=Gaming*10;
pixels.setPixelColor(1, pixels.Color(0, 150, 0));
else if (gamingMute==0 && (Gaming > 102 || Gaming==102)){
analogSliderValues[3]=102*10;
knobGaming.write(102);
else if (gamingMute==1){
analogSliderValues[3]=0;
pixels.setPixelColor(1, pixels.Color(150, 0, 0));
else {
knobGaming.write(0);
if (musicMute==0 && Music > 0 && Music < 102){
analogSliderValues[4]=Music*10;
pixels.setPixelColor(0, pixels.Color(0, 150, 0));
else if (musicMute ==0 && (Music > 102 || Music==102)){
analogSliderValues[4]=102*10;
knobMusic.write(102);
else if (musicMute==1){
analogSliderValues[4]=0;
pixels.setPixelColor(0, pixels.Color(150, 0, 0));
else {
knobMusic.write(0);
