Engine not stopping for Card Scanner
Summary (Arduino Nano + L298N feeder + LDR + MAX9814 mic)
I'm building a MTG Card scanner but I'm stuck on my engine that is not turning off and restarting when it should and the Scanner keeps feeding cards.
Here's a short video of the expected behaviour for the scanner/feeding mechanism
The original design (from the engineer who designed the machine) uses:
  • L298N H-bridge for a DC motor feeder (ENA=D9, IN1=D8, IN2=D7)
  • LDR sensor on A7 with an LED shining at it to detect card position
  • TM1637 4-digit display + NeoPixel ring, buzzer, 2 buttons (start/stop toggle + counter reset)
  • Microphone input originally expected a digital “sound detected” signal (D0 HIGH) to trigger feeding after a phone “scan beep”
What works
  • Arduino Nano + IDE connectivity is OK (COM port, uploads fine).
  • Motor driver wiring is correct: a minimal test sketch toggling motor ON/OFF every 2 seconds works perfectly (so L298N + motor + ENA/IN pins are wired correctly and stopping the motor via IN1/IN2 LOW works).
  • LDR readings look reasonable when tested manually: LED aimed at LDR gives ~500–600, covering with a card drops to ~20–150.
Expected Behaviour - Step by Step
Based on the original design video, here's what SHOULD happen:
1. STARTUP
  • LED ring turns RED
  • LDR baseline calibrated (~500-600 with no card blocking)
  • Display shows "0000"
  • Motor OFF, waiting for button press
2. USER PRESSES START BUTTON (D6)
  • scannerActive = true
  • Motor STARTS (feeds first card toward scan position)
  • LED stays RED
3. CARD REACHES LDR SENSOR
  • LDR value DROPS (e.g., 500 → 150) as card blocks light
  • cardInPosition = true
  • Code detects: ldrValue < baseLdrValue - 50
4. CARD PASSES LDR (exits scan position) THIS IS WHERE IT FAILS
  • LDR value RISES back (e.g., 150 → 500)
  • Code detects: ldrValue > baseLdrValue - 30
  • Motor STOPS
  • cardInPosition = false
  • Card is now in position for phone camera to scan
5. WAITING FOR PHONE BEEP
  • Motor remains OFF
  • Scanner waits for phone app to recognize card
  • Phone app plays SUCCESS BEEP when card identified
6. MICROPHONE DETECTS BEEP
  • micValue spikes above threshold (~360)
  • soundDetected = true (edge trigger, not continuous)
  • Card count increments, display updates
  • Motor STARTS again (feeds next card)
7. REPEAT STEPS 3-6 FOR EACH CARD
8. TIMEOUT (no cards for 8 seconds)
  • Motor STOPS
  • LED BLINKS RED + Buzzer beeps
  • timeoutMode = true
What's Actually Happening
Step 4 fails: The motor doesn't stop because the LDR value never returns to baseline between cards during continuous feeding. It just keeps feeding too fast.
Result: Steps 3→4→5→6 collapse into one continuous feed:
Card1 enters → Card2 enters → Card3 enters → ... (motor never stops)
The condition ldrValue > baseLdrValue - 30 is never met because:
  • Cards pass too quickly for LDR to recover
  • Or the next card is already blocking before the previous one clears
  • Or ambient light / LED state changes have shifted the baseline
Microphone changes / current status
  • The original mic modules were unreliable (stuck HIGH / weird values), so I replaced them with a MAX9814 (wired VDD→5V, GND→GND, OUT→A2). Board has no indicator LEDs (expected).
  • MAX9814 analog values at idle are ~250–300 and claps/phone beep jump to ~400–500 (not huge spikes like 700+). I implemented analog threshold + edge detection in code (instead of digitalRead), but the motor-stop issue persists even when the microphone is fully disabled (soundDetected forced false) → so the core issue seems to be LDR/card-position logic under real feeding conditions rather than mic triggering.
What I’m looking for help with
  • Best practice for using an LED+LDR as a card position sensor in a feeder where cards pass quickly and ambient/stack effects prevent the signal returning to baseline between cards.
  • How to robustly detect “one card has passed / reached position” (e.g., hysteresis, tracking min/max, relative thresholds, debouncing, time-based gating).
  • Optional: controlling feeder speed via ENA PWM to make LDR detection reliable.
PS the movie link posted above contains the design of the device.
Annotated Diagram
Current Sketch
#include <TM1637Display.h>
// Pins
const int ENA = 9;
const int IN1 = 8;
const int IN2 = 7;
const int buzzerPin = 11;
const int ldrPin = A7;
const int buttonResetPin = 3;
const int buttonManualTrigger = 6;
const int micPin = A2;
const int displayClkPin = 4;
const int displayDioPin = 5;
// Initialize display
TM1637Display display(displayClkPin, displayDioPin);
// Initialize Neopixel LED
Adafruit_NeoPixel ledRing(8, A0, NEO_GRB + NEO_KHZ800);
// Variables
int cardCount = 0;
bool motorRunning = false;
bool scannerActive = false;
bool cardInPosition = false;
bool timeoutMode = false;
unsigned long lastButtonPress = 0;
unsigned long lastResetPress = 0;
unsigned long lastCardDetectedTime = 0;
unsigned long lastCardMovedTime = 0;
const unsigned long timeoutDuration = 8000;
const unsigned long cardCountDelay = 1000;
unsigned long lastCardCountTime = 0;
int baseLdrValue;
// Lighting control
const int reasonBrightness = 255;
unsigned long dimmingStartTime = 0;
const unsigned long dimmingDuration = 5000;
bool isDimmed = false;
unsigned long colorFadeTime = 0;
int fadeStep = 0;
// --- MAX9814 mic detection (analog on A2) ---
int micThreshold = 360;                // tune later (based on your readings)
bool lastSoundState = false;
unsigned long lastSoundTriggerTime = 0;
const unsigned long soundCooldown = 400; // ms between triggers
// --- Optional: slow debug prints (Serial Monitor readable) ---
unsigned long lastDebugPrint = 0;
const unsigned long debugInterval = 200; // print every 200ms
//Startup sequence
const int startup = 5;  // Select the desired start sequence (1..5)
  pinMode(ENA, OUTPUT);
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(buttonResetPin, INPUT_PULLUP);
  pinMode(buttonManualTrigger, INPUT_PULLUP);
  pinMode(ldrPin, INPUT);
  pinMode(micPin, INPUT);
  ledRing.begin();
  setLightRed(reasonBrightness); // Calibrate LDR with red light
  ledRing.show();
  digitalWrite(ENA, HIGH);
  display.setBrightness(0x0f);
  display.showNumberDec(cardCount);
  baseLdrValue = analogRead(ldrPin);
  Serial.print("Basis LDR-Wert: ");
  Serial.println(baseLdrValue);
  // Selecting the start sequence
  switch (startup) {
    case 1: startupSequence1(); break;
    case 2: startupSequence2(); break;
    case 3: startupSequence3(); break;
    case 4: startupSequence4(); break;
    case 5: startupSequence5(); break;
    default:
      Serial.println("UngĂĽltige Startsequenz. Standard wird verwendet.");
      startupSequence1();
  int ldrValue = analogRead(ldrPin);
  // --- Microphone (MAX9814) analog detection ---
  int micValue = analogRead(micPin);
  bool soundState = (micValue > micThreshold);
  bool soundDetected = false;
  // Trigger only on LOW->HIGH edge + cooldown (prevents constant retriggering)
  if (soundState && !lastSoundState &&
      millis() - lastSoundTriggerTime > soundCooldown) {
    soundDetected = true;
    lastSoundTriggerTime = millis();
  lastSoundState = soundState;
  // --- Optional debug (comment out if not needed) ---
  if (millis() - lastDebugPrint > debugInterval) {
    lastDebugPrint = millis();
    Serial.print("LDR: ");
    Serial.print(ldrValue);
    Serial.print(" | base: ");
    Serial.print(baseLdrValue);
    Serial.print(" | MIC: ");
    Serial.print(micValue);
    Serial.print(" | soundState: ");
    Serial.print(soundState);
    Serial.print(" | soundDetected: ");
    Serial.println(soundDetected);
  // Start button: Switching the scanner
  if (digitalRead(buttonManualTrigger) == LOW) {
    if (millis() - lastButtonPress > 300) {
      scannerActive = !scannerActive;
      lastButtonPress = millis();
      if (scannerActive) {
        setLightRed(255);
        moveCard();
        lastCardDetectedTime = millis();
        lastCardMovedTime = millis();
        stopMotor();
        isDimmed = false;
      ledRing.show();
  // Motor control
  if (!scannerActive && motorRunning) {
    stopMotor();
  // Reset button: Reset counter
  if (digitalRead(buttonResetPin) == LOW && millis() - lastResetPress > 300) {
    cardCount = 0;
    lastResetPress = millis();
  // When the scanner is active
    if (!cardInPosition && ldrValue < baseLdrValue - 50) {
      cardInPosition = true;
      // Serial.println("Card is promoted");
    if (cardInPosition && ldrValue > baseLdrValue - 30) {
      stopMotor();
      setLightRed(255);
      delay(50);
      // Serial.println("Card is scanned");
    if (millis() - lastCardMovedTime >= 3000 && !cardInPosition && !timeoutMode) {
      isDimmed = true;
    if (soundDetected) {
      isDimmed = false;
      setLightRed(255);
      moveCard();
      if (!timeoutMode && millis() - lastCardCountTime > cardCountDelay) {
        lastCardCountTime = millis();
        cardCount++;
    if (millis() - lastCardMovedTime > timeoutDuration && !timeoutMode) {
      timeoutMode = true;
      isDimmed = false;
      stopMotor();
      tone(buzzerPin, 1000, 500);
      // Serial.println("Timeout Mode");
  // Timeout mode flashes
  if (timeoutMode) {
    blinkRedLEDAndSoundBuzzer();
  // Pause mode - lights change smoothly
  if (!scannerActive && !timeoutMode) {
    fadeLights();
  if (isDimmed) {
    dimLights();
void moveCard() {
  if (scannerActive && !timeoutMode) {
    digitalWrite(IN1, LOW);
    digitalWrite(IN2, HIGH);
    motorRunning = true;
void stopMotor() {
  digitalWrite(IN2, LOW);
void blinkRedLEDAndSoundBuzzer() {
  static unsigned long lastBlinkTime = 0;
  if (currentMillis - lastBlinkTime >= 500) {
    lastBlinkTime = currentMillis;
    static bool ledState = false;
    ledState = !ledState;
    if (ledState) {
      setLightRed(255);
      tone(buzzerPin, 1000, 100);
      ledRing.clear();
      noTone(buzzerPin);
    ledRing.show();
void dimLights() {
  unsigned long elapsedTime = millis() - dimmingStartTime;
  int brightness = map(elapsedTime, 0, dimmingDuration, 255, 0);
  setLightRed(brightness);
  ledRing.show();
void fadeLights() {
  if (currentMillis - colorFadeTime >= 2000) {
    colorFadeTime = currentMillis;
    switch (fadeStep % 6) {
      case 0: ledRing.fill(ledRing.Color(255, 0, 0)); break;
      case 1: ledRing.fill(ledRing.Color(255, 127, 0)); break;
      case 2: ledRing.fill(ledRing.Color(255, 255, 0)); break;
      case 3: ledRing.fill(ledRing.Color(0, 255, 0)); break;
      case 4: ledRing.fill(ledRing.Color(0, 0, 255)); break;
      case 5: ledRing.fill(ledRing.Color(75, 0, 130)); break;
    ledRing.show();
    fadeStep++;
void setLightRed(int brightness) {
  for (int i = 0; i < ledRing.numPixels(); i++) {
    ledRing.setPixelColor(i, ledRing.Color(brightness, 0, 0));
  ledRing.show();
// --- Startup sequences (unchanged) ---
void startupSequence1() {
  ledRing.clear();
  ledRing.show();
    ledRing.setPixelColor(i, ledRing.Color(255, 0, 0));
    ledRing.show();
    delay(100);
  delay(200);
    ledRing.setPixelColor(i, ledRing.Color(0, 255, 0));
    ledRing.show();
    tone(buzzerPin, 1200, 100);
    delay(100);
  delay(200);
    ledRing.setPixelColor(i, ledRing.Color(0, 0, 255));
    ledRing.show();
    tone(buzzerPin, 1400, 100);
    delay(100);
  delay(200);
    ledRing.setPixelColor(i, ledRing.Color(255, 255, 255));
    ledRing.show();
    tone(buzzerPin, 1600, 100);
    delay(100);
  ledRing.fill(ledRing.Color(255, 255, 255));
  ledRing.show();
  tone(buzzerPin, 2000, 300);
  delay(300);
  ledRing.clear();
  ledRing.show();
  noTone(buzzerPin);
void startupSequence2() {
  ledRing.clear();
  ledRing.show();
    ledRing.setPixelColor(i, ledRing.Color(255, 165, 0));
    ledRing.show();
    tone(buzzerPin, 800 + (i * 50), 100);
    delay(100);
  delay(300);
  for (int j = 0; j < 3; j++) {
    for (int brightness = 0; brightness <= 255; brightness += 5) {
      ledRing.fill(ledRing.Color(brightness, brightness / 2, 0));
      ledRing.show();
      delay(10);
    for (int brightness = 255; brightness >= 0; brightness -= 5) {
      ledRing.show();
      delay(10);
    tone(buzzerPin, 1200, 150);
    delay(150);
  for (int i = 0; i < 3; i++) {
    ledRing.show();
    tone(buzzerPin, 2000, 100);
    delay(100);
    ledRing.clear();
    ledRing.show();
    noTone(buzzerPin);
    delay(100);
void startupSequence3() {
  ledRing.clear();
  ledRing.show();
    ledRing.setPixelColor(i, ledRing.Color(255, 0, 255));
    ledRing.show();
    tone(buzzerPin, 800 + (i * 30), 50);
    delay(50);
  noTone(buzzerPin);
  delay(300);
  int half = ledRing.numPixels() / 2;
  for (int i = 0; i <= half; i++) {
    ledRing.setPixelColor(half - i, ledRing.Color(0, 255, 255));
    ledRing.setPixelColor(half + i, ledRing.Color(0, 255, 255));
    ledRing.show();
    tone(buzzerPin, 1000 + (i * 40), 80);
    delay(80);
  noTone(buzzerPin);
  delay(300);
    ledRing.show();
    tone(buzzerPin, 1500, 100);
    delay(200);
    ledRing.fill(ledRing.Color(0, 0, 100));
    ledRing.show();
    delay(200);
  noTone(buzzerPin);
  delay(300);
    ledRing.setPixelColor((i + ledRing.numPixels() / 2) % ledRing.numPixels(), 0);
    ledRing.show();
    tone(buzzerPin, 2000 + (i * 20), 30);
    delay(30);
  noTone(buzzerPin);
  delay(300);
  ledRing.show();
  tone(buzzerPin, 2500, 150);
  delay(150);
  ledRing.clear();
  ledRing.show();
  noTone(buzzerPin);
void startupSequence4() {
  Serial.println("Starte Startup-Sequenz 4");
  ledRing.clear();
  ledRing.show();
    ledRing.show();
    delay(50);
  noTone(buzzerPin);
  delay(300);
    ledRing.show();
    delay(80);
  noTone(buzzerPin);
  delay(300);
    ledRing.show();
    delay(200);
    ledRing.show();
    delay(200);
  noTone(buzzerPin);
  delay(300);
    ledRing.show();
    delay(30);
  noTone(buzzerPin);
  delay(300);
  ledRing.show();
  delay(150);
  ledRing.clear();
  ledRing.show();
  noTone(buzzerPin);
void startupSequence5() {
  ledRing.clear();
  ledRing.show();
    ledRing.show();
    tone(buzzerPin, 800 + (i * 20), 50);
    delay(50);
    ledRing.setPixelColor(i, 0);
  noTone(buzzerPin);
  delay(300);
  for (int i = half; i >= 0; i--) {
    ledRing.setPixelColor(half - i, ledRing.Color(255, 255, 0));
    ledRing.setPixelColor(half + i, ledRing.Color(255, 255, 0));
    ledRing.show();
    tone(buzzerPin, 1000 + (i * 50), 50);
    delay(80);
  noTone(buzzerPin);
  delay(300);
    ledRing.show();
    delay(200);
    ledRing.clear();
    ledRing.show();
    delay(200);
  noTone(buzzerPin);
  delay(300);
    ledRing.setPixelColor(half - i, 0);
    ledRing.setPixelColor(half + i, 0);
    ledRing.show();
    tone(buzzerPin, 2000 - (i * 50), 50);
    delay(80);
  noTone(buzzerPin);
  delay(300);
  for (int i = 0; i < 2; i++) {
    ledRing.show();
    delay(150);
    ledRing.clear();
    ledRing.show();
    noTone(buzzerPin);
    delay(150);
Cookies, logins etc are not accepted.
What it’s doing depends on the code and the wiring. Please post real schematics. Mystery Frizings are useless for analyzing.
Excuse me and affermative, first time posting here. I have removed the video to my current behaviour. I have posted a link to my sketches on GH and the wiring scheme. The movie on YT shows the design.
Why not work on one sketch so I do not select the wrong one?
What do you consider "the position?" Before the motor, in the box? Other?
What devices are available? If I suggest "none" will you require one?
In this piece of code stopMotor() allows the motor to restart by making motorRunning become false bypassing this motor control.
// Motor control
    stopMotor();
card position would be relative to a card getting fed out of the stack (from the bottom) it will be fed out, cover the LDR sensor that sits in between the card stack and the box. The LDR being deprived of LED light would indicate a that 'a card is passing' and the LDR receiving light again would mean a card has passed and is now in position. Then engine should wait and IF a sound is played by my scanning app on the phone (succesful scan) --> next card needs to be fed.
The original sketch was supplied by the engineer who desined the whole device. I just printed it in 3D and built it. However during the build I ran into this problem with the engine. I provided the original code for reference.
Have you verified that this is actually happening? You have indicated you are not using the identical card used by the original developer.
Posting an annotated schematic as requested by @Railroader Would go a long way in helping solve your problem.
This is Arduino Forum. GH is something different.
Did my suggestion solve, do nothing, or exacerbate the problem?
So, which one is it? Should I keep guessing the wrong one?
it clearly mentions original versus modified does it not?
I'm sorry but I thought pasting in the full code in here would just create bloat, hence why I uploaded the .ino code on GH. What is the problem exactly?
Yes I did test all these scenarios with the serial monitor. the LDR sensor effectively indicates when a card enters and passes.
I'm sorry I'm new to Arduino and prototyping although being in the development and engineering space, I will look into it and try to provide this asap.
Good! Now, what happens to this indication in your program? Follow it through the program with prints until you get to where the motor is supposed to stop. Debugging!
If You don’t post in Arduino Forum You can’t expect to reach Arduino Forum people.
Hi, @maxplaining
Welcome to the forum.
It will show you how to post your code.
Can you post some images of your project?
So we can see your component layout.
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
Message received.
I have edited my post, annotated the wiring diagram provided the full code in my post.
Thank you, I have edited my post to be more detailed, annotated the wiring diagram with most crucial elements i think and provided the code in full in the post itself. First time project and I'm aware I can upgrade the schematic, working on that in the meantime.
To see the design I would advise to checkout the movie link provided in the post up top, it shows both the design and how it should operate a lot more clearly than I could capture in images of my version in it's current state.
