Enter the i value into href= tag
Running a web server using ESP8266WiFi.h
I want to enter the i value into href= tag.
int i = 0;
String scannedSSID = (WiFi.SSID(i));
while ( i < scannedSSID ) {
client.print("<p><a href= i ><button class=\"button\">" + scannedSSID + " " + enc + "</button></a></p>");
i++;
i is an integer, scannedSSID is a string. i will always be zero.
If you post your code (all of it) as described in How to get the best out of this forum, more forum members will read it.
close to the bottom in the www function
client.print("<p><a href=\"/5/on\"><button class=\"button\">" + scannedSSID + " " + enc + "</button></a></p>");
I want to attach the i value in the <a href= that will add a unique id to each button so that i can use a get or post.
#include <ESP8266WiFi.h>
#include <RTCVars.h>
WiFiServer server(80);
RTCVars state; // create the state object
int reset_counter;
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
String header;
const int wwwDelay = 100;
const int networkScanDelay = 2000;
unsigned long wwwPreviousTime = 0;
unsigned long NSDpreviousTime = 0;
  Serial.begin (115200);
  state.registerVar( &reset_counter );  // we send a pointer to each of our variables
  if (state.loadFromRTC()) {            // we load the values from rtc memory back into the registered variables
    reset_counter++;
    Serial.println("This is reset no. " + (String)reset_counter);
    state.saveToRTC();                  // since we changed a state relevant variable, we store the new values
    reset_counter = 0;
    state.saveToRTC();
  Serial.println("hello");
  server.begin();
  if (reset_counter == 0 ) {
    APmode();
    stationMode();
void APmode() {
  const String saId = "garbageProject";
  WiFi.mode(WIFI_AP);
  WiFi.softAP(saId);
void stationMode() {
  const char* ssid = "*******";
  const char* password = "*******";
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.print("Connecting");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.print("Connected, IP address: ");
  if (currentTime - wwwPreviousTime >= wwwDelay) {
    www();
    wwwPreviousTime = millis();
  if (currentTime - NSDpreviousTime >= networkScanDelay) {
    networkScan();
    Serial.print("Number of resets: ");
    Serial.println(reset_counter);
    NSDpreviousTime = millis();
void networkScan() {
  int i = 0;
  int numSSID = WiFi.scanNetworks();
  while ( i < numSSID) {
    unsigned int SSIDlength = scannedSSID.length();
    if (SSIDlength > 10) {
      scannedSSID.remove(10);
    Serial.print(i + 1);
    Serial.print(" ");
    Serial.print(scannedSSID);
    Serial.print("\t Encryption: ");
    printEncryptionType(WiFi.encryptionType(i));
    if ( i + 1 == numSSID) {
    i++;
void printEncryptionType(int thisType) {
  // read the encryption type and print out the name:
  switch (thisType) {
    case ENC_TYPE_WEP:
      Serial.println("WEP");
    case ENC_TYPE_TKIP:
      Serial.println("WPA");
    case ENC_TYPE_CCMP:
      Serial.println("WPA2");
    case ENC_TYPE_NONE:
      Serial.println("None");
    case ENC_TYPE_AUTO:
      Serial.println("Auto");
void www() {
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    Serial.println("New Client.");          // print a message out in the serial port
    String ssidSelected;
    String currentLine = "";                // make a String to hold incoming data from the client
    previousTime = currentTime;
    while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            if (header.indexOf("GET /5/on") >= 0) {           //handle the button pressed needs to be changed to generate like the html script does. see line 68.
              ssidSelected = "on";
              Serial.println("test ");
              Serial.print(ssidSelected);
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color:#4095c6; border-radius: 12px; color: white; padding: 16px 40px;transition-duration: 0.4s;}");
            client.println(".button:hover{background-color:#AED6F1;}");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}</style></head>");
            // Web Page Heading
            client.println("<body><h1>ESP8266 Web Server</h1>");
            int i = 0;
            String enc;
              char encryption = (WiFi.encryptionType(i));
              switch (encryption) {
                case ENC_TYPE_WEP:
                  enc = ("Encryption WEP");
                case ENC_TYPE_TKIP:
                  enc = ("Encryption TKIP");
                case ENC_TYPE_CCMP:
                  enc = ("Encryption WPA2");
                case ENC_TYPE_NONE:
                  enc = ("Encryption  none");
              i++;
            client.println("</body></html>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.flush();
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
just print your variable where you want it:
Fixed it. Thanks for the pointer I'm still learning how to code.
here is the relatively finished product.
#include <EEPROM.h>
int reset_counter;
int addr_ssid = 0;
int addr_password = 32;    // password index
int eepromSize = 512;
String WiFiPassword;
String ssid;
String password;
unsigned long previousResetTime = 0;
const int resetTiming = 1000;
unsigned long wwwStatusPreviousTime = 0;
  EEPROM.begin(512);
  for (int k = addr_ssid; k < addr_ssid + 32; ++k) {                //get SSID from memory
    ssid += char(EEPROM.read(k));
  for (int k = addr_password; k < addr_password + 32; ++k) {            //get password from memeory
    password += char(EEPROM.read(k));
  Serial.print("this is the value for ssid: ");
  Serial.println(ssid);
  Serial.print("this is the value for password: ");
  Serial.println(password);
  //SSID and Password eraser
  state.registerVar( &reset_counter);                               // we send a pointer to each of our variables
    reset_counter++;
    previousResetTime = millis();                                   //attached to reset timer below
    reset_counter = 0;
    state.saveToRTC();                                              //value passed to reset timer
  if (currentTime - previousResetTime <= resetTiming) {             //if the reset button is pressed more than once inside 1 second
    for (int i = 0; i < 64; EEPROM.write(i++, 0));                  //erase whatever is stored in the 0-64 address range
    EEPROM.commit();
  delay(100);
  server.begin();
  int ssidVal = ssid.length();
//  int passVal = password.length();                                might be useful for somethig else.
  if (ssid == 0 ) {
    APmode();
    stationMode();
void APmode() {
  const String pass = "gp123456789";
  WiFi.mode(WIFI_AP);
  WiFi.softAP( saId, pass);
  Serial.println("WiFi access point started.");
    Serial.print(".");
    www();
  if (currentTime - wwwStatusPreviousTime >= 10000) {
    Serial.println("Webserver running");
    wwwStatusPreviousTime = millis();
/********* webserver code provided
  Rui Santos
  Complete project details at https://randomnerdtutorials.com
void www() {
  // Variable to store the HTTP request
  String header;
  // Current time
  // Previous time
        header += c;
          if (currentLine.length() == 0) {                                        // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            client.println("HTTP/1.1 200 OK");                                    // and a content-type so the client knows what's coming, then a blank line:
            client.println();
            String ssidHeader = (header);                                         //redundant veriable for ease of understanding
            String passwordWorker = header;                                       //redundant veriable for ease of understanding
            int HTTPindex = ssidHeader.indexOf("HTTP");
            String scannedSSID;
            if (HTTPindex == 6) {                                                 //if the header has other than intial GET
              client.println("<body><h1>ESP8266 Web Server</h1>");                // Web Page Heading
              for (int i = 0; i < numSSID; i++) {
                client.print("<p><a href='" + scannedSSID + "'><button class=\"button\">" + scannedSSID + "</button></a></p>");
            int passwordIndex = ssidHeader.indexOf("?");                          //See if a password was attached to header
            if (passwordIndex == -1) {                                            //if there is no password
              ssidHeader.remove(0, 5);                                            //remove GET /
              unsigned int L = ssidHeader.length();                               //get lenght after trimming beginning.
              int HTTPindex = ssidHeader.indexOf("HTTP");                         //find first instance of HTTP
              ssidHeader.remove(HTTPindex - 1, L);                                //remove from the space before H in HTTP to end of string
              ssidSelected = ssidHeader;                                          //whats left of the header is the SSID
              Serial.println("");
              Serial.print("Write WiFi SSID at address "); Serial.println(addr_ssid);
              Serial.print("");
              for (int i = 0; i < ssidSelected.length(); ++i) {
                EEPROM.write(addr_ssid + i, ssidSelected[i]);
                Serial.print(ssidSelected[i]); Serial.print("");
            unsigned int rt = ssidSelected.length();                              //if an SSID is set then display password web page
            if (rt >= 1) {
              client.println("<body><h1>ESP8266 Web erver</h1>");
              client.println("<body><h1>WiFi Password</h1>");
              client.println("<title>ESP Input Form </title>");
              client.println("<form>");
              client.println("<input type=\"text\" name=\"WiFiPassword\">");
              client.println("<input type=\"submit\"value=\"Submit\">");
              client.println("</form><br>");
            if (passwordIndex >= 0) {
              int pwIndex = passwordWorker.indexOf("=");                          //count header string to the first oinstance of =
              passwordWorker.remove(0, pwIndex + 1);                              //remove from beginning of string to and including =
              unsigned int L = passwordWorker.length();                           //get the current length of the string
              int HTTPindex = passwordWorker.indexOf("HTTP");                     //find first instance of HTTP
              passwordWorker.remove(HTTPindex - 1, L);                            //remove from the space before H in HTTP to end of string
              WiFiPassword = passwordWorker;                                      //whats left in header is the wifi password
              Serial.println("");
              Serial.print("Write WiFi Password at address ");
              Serial.println(addr_password);
              Serial.print("");
              for (int j = 0; j < WiFiPassword.length(); j++)
                EEPROM.write(addr_password + j, WiFiPassword[j]);
                Serial.print(WiFiPassword[j]); Serial.print("");
            Serial.println("");
            if (EEPROM.commit()) {
              Serial.println("Data successfully committed");
              Serial.println("ERROR! Data commit failed");
            client.println("</body></html>");                                     //The HTTP response ends with another blank line
            client.println();
            currentLine = "";
    header = " ";
    client.flush();
    client.stop();
    Serial.println("");
    Serial.print("ssid is: ");
    Serial.println(ssidSelected);
    Serial.print("wifi pass word is: ");
    Serial.println(WiFiPassword);
two hints:
don't use HTTP/1.1 without the http header field "content-length".
if you don't know the length of your payload, use HTTP/1.0
As we know now that you are using an esp8266:
on an esp8266 ... don't build the HTTP on your own. Use the ESP8266HTTPClient, which will make the things easier for your.
See the example ESP8266HTTPClient | BasicHttpclient as start!
Thank you for the hints. I am going to start digging into that. If you want to follow the code here’s the link to GitHub https://github.com/XRC5/apToStationMode
If not I will repost here when I think I’m done.
... in Arduino IDE just looked at Examples/DNSServer/CaptivePortalAdvanced and it does all this crap. Guess I'm done with this project. Good learning experience though.
