i am doing a wireless dimming control system for lights,using arduino as my thesis. As light sensor am going to use a simple LDR because the problem needs to be cheap and because i don't have much time to order and wait for a more precisive sensor to arrive.
The point is that the LDR does't not give results in LUX.
Do i have to calibrate the LDR with a light source and a LUX meter? Reading some research papers ,i saw tha some use the equation LUX=500/Rldr to convert the output of the LDR into LUX.Searching the internet i couldn't find information such as where it comes or how it is invented..
Could anyone help me?, Should i use it because it really would save me lots of time..
Sorry for my bad english and thank you in advance.
I think that you can determine the LDRs response by recording the output at different distances from a simple non-directional lamp. Light intensity will decrease by the square of the distance.
However you would need a lux meter if you want absolute values.
Your problem is akin to asking: "I have a smooth rod and I want to use it to measure inches (or centimetres or whatever): will I need to put marks on it using a ruler as a known reference?"
akis31:
no my problem is that for the equation i have written above i can not find information and if it is valid so i don't know if i can use it
I have tried a few times, without success, to get my head around lux and candelas for measuring the comparative efficiency of halogen and led lamps. So I have no idea whether your formula is even structured correctly.
I do know, however, that there can be great variation between LDRs so I don't see how it could be a universal formula.
I don't see how that could ever be true! Rldr is an unknown factor, as pointed out all LDR's vary! in size, shape and DARK resistance.
As Robin says If you can get your hands on a LUX meter, then you only need to do a few test on various lights or daylight, try a google for LUX, candela, etc.
akis31:
Look, no magic formula is going to let you convert volts (or ohms) into lux. The lux is a photometric unit, which means that it's balanced against the average sensitivity of the human eye to visible light. It's a bell-shaped curve that centres at about 555 nm wavelength for daylight vision. Since you said that you have access to a lux meter, why not use it? There is but one way to go: work in a dark room with a light dimmer. While keeping the lux meter and your LDR close to each other, on the same plan and at the same angle from your light source, increase the light in small increments and record both the reading of the lux meter and the voltage from the LDR (maybe with an arduino doing analogRead). As it's already been suggested, halving the distance will increase the illuminance by a factor four.
I can see that the resistance of an LDR may be inversely proportional to the light intensity, because the current flowing is likely to be proportional to the number of photons striking the surface of the LDR.
However, I can see no reason that there will be a universal formula, with a nice round number (such as 500) as a constant in the equation.
I think that this formula that you have found, is only going to be a rough approximation for one particular type of LDR.
Different geometries, and different compositions of the materials used in LDRs are going to give different constants of proportionality in the equation linking resistance with light intensity.
The LDR is a blunt instrument for measuring light.
Any attempt to massage then numbers to get lux from a 10 cent LDR is doomed from the start, as people have described above.
Not only is the spectral response of the eye and LDR different, LDR's have a painfully slow response, taking minutes to settle after a change in light level. The ones we typically end up using aren't meant for making precise measurements, but rather
They're really only good for detecting presence or absence of light, and maybe one or two levels in between.
If you want a precise way to sense light, you need a better light sensor - an inexpensive example is the I2C BH1750, which approximates the eyes response curve and returns results in lux.
