Convert LDR value to Lux using ESP32
How can I make lux meter using LDR and esp32?
Welcome to the forum
Have you constructed a circuit and written a sketch that allows you to read the resistance of the LDR and print it on the Serial Monitor ?
If not, then now would be a good time to do it
FYI:
Get a calibrated light source, note your LDR result and go from there.
But remember that LDRs are not perfect. If you want accurate readings you'll have to use a photodiode.
also what spectral sensitivity curve do you want? each type of light sensor has a different response.
