I am a newbie to Arduino and am stuck trying to figure out why the following code always returns a value of 0 when measure_duration is called a second time in the loop function. This has not been making any sense to me. Any suggestions on how to get this code to work? What am I missing? Any help would be very appreciated.
// defines variables
const int trigPin = 9;
const int echoPin = 10;
const int relayPin = 7;
const int buzzerPin = 13;
unsigned long duration; // Time taken by sound wave round trip
unsigned long distance; // Distance from source to destination
pinMode(trigPin, OUTPUT); // Sets the digital pin 9 as output
pinMode(buzzerPin, OUTPUT); // Sets the digital pin 11 as output
pinMode(relayPin, OUTPUT); // sets the digital pin 7 as output
pinMode(echoPin, INPUT); // Sets the digital pin 10 as an Input
Serial.print("Entering loop\n");
digitalWrite(trigPin, LOW); // Sets the digital pin 9 off
delayMicroseconds(5); // waits for 2 micro seconds
digitalWrite(trigPin, HIGH); // Sets the digital pin 9 on
delayMicroseconds(10); // waits for 10 micro seconds
// Reads the echoPin, returns the sound wave travel time in microseconds
// duration = pulseIn(echoPin, HIGH);
duration = measure_duration();
if (duration == 0) {
Serial.println("Warning 1: We did not get a pulse from the sensor.");
// Calculating the distance
distance = duration * 0.034 / 2;
Serial.print("Distance1: " );
Serial.println(distance);
if ((distance > 6) && (distance < 10)) {
// start of cycle
digitalWrite(relayPin, HIGH);
digitalWrite(relayPin, LOW);
// end of cycle
// check for hand removal
boolean distanceOk = false;
// loop till one of the following conditions are met
// 1. user has removed hand so distance check will fail
while (distanceOk == false) {
delay(50);
Serial.println("Warning 2: We did not get a pulse from the sensor.");
Serial.print("Distance 2: " );
// check if state has not changed
digitalWrite(buzzerPin, HIGH); // Sets the buzzer pin 7 on
distanceOk = true;
Serial.println("Distance is ok now. Can exit the loop now.");
Serial.println("Exiting loop");
const unsigned long measure_duration() {
pinMode(echoPin, OUTPUT);
digitalWrite(echoPin, LOW);
delayMicroseconds(2);
digitalWrite(echoPin, HIGH);
return pulseIn(echoPin, HIGH);
(Tags added by Moderator)
