pulseIn with ultrasonic sensor taking too long
I am experiencing an issue with the pulseIn function, which causes a significant delay of around 700 milliseconds in my code. Below is the function I am using to get the counter distance:
void get_Counter_Distance() { long start = millis();
digitalWrite(counter_trigpin, LOW);
delayMicroseconds(2);
long s1 = millis();
digitalWrite(counter_trigpin, HIGH);
delayMicroseconds(10);
long s2 = millis();
long s3 = millis();
// Measure the duration of the echo
long counter_duration = pulseIn(counter_echopin, HIGH, 100000);
long s4 = millis();
// Calculate the distance in cm
counter_distance = counter_duration * 0.034 / 2;
long end = millis();
if (s4 - s3 > 200) {
Print_Lcd_Message("warning delay", "get ctr dist", 0);
Serial.println(s4 - s3);
// Serial.print("get_Counter_Distance() took:");
// Serial.print(end - start); Serial.print(",");
// Serial.print(s1 - start); Serial.print(",");
// Serial.print(s2 - s1); Serial.print(",");
// Serial.print(s3 - s2); Serial.print(",4-3: ");
// Serial.print(s4 - s3); Serial.print(",");
// Serial.print(end - s4); Serial.print(",");
// Serial.println(counter_distance);
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
I wonder why you are not checking for zero? Zero is returned if the time-out value is reached.
Which Arduino? Which ultrasonic sensor?
