Hello,
I'm running the program below on an arduino mega with an ethernet shield.
The purpose of the program is to :
- Read temperature and humidity
- Store the min & max temperature of the last 8 hours
- Send those 4 information on mqtt local server and on adafruit
- Record temperature on SD card
All is working fine except the min & max value that is returning -1000 and +1000.
I can't understand why, and the code was running fine a month sending consistent values on the mqtt local (but always sent -1000 and +1000 on Adafruit). I had to replace the sensor so it was off for a little while and since it's back in service I have -1000 and +1000 on local and adafruit. Very strange.
Any clue why ?
Thanks.
/************************* Library ***************************/
#include <SPI.h>
#include "Adafruit_MQTT_Client.h"
#include <Ethernet.h>
#include <SD.h>
#include "DFRobot_SHT20.h"
#include <Wire.h>
/************************* Ethernet Client Setup *****************************/
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEC};
IPAddress myDns(192, 168, 1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
/************************* SD *********************************/
const int chipSelect = 4;
/************************* MQTT brokers *********************************/
#define Local_SERVER "192.168.1.65"
#define Local_SERVERPORT 1883
#define Local_USERNAME "xxxxxxx"
#define Local_KEY "xxxxxxx"
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883
#define AIO_USERNAME "xxxxxxxx"
#define AIO_KEY "xxxxxxxx"
/************************* Time global *********************************/
unsigned long action_AIO = 0;
unsigned long action_Local = 0;
unsigned long action_SD = 0;
#define intervale_publication_AIO 10000 // 10secs Between each publication on internet
#define intervale_publication_Local 5000 // 4secs Between each publication on local network
#define intervale_publication_SD 1800000 // 30mins Between each publication on SD card
unsigned long temps = 0;
/************************* Array & tests *********************************/
#define interval_array 3600000 // Time between update of each value
#define interval_update_array 5000 // Time between each update of the same value of the array
#define size_array 10 // Number of value of the array
long time_array = 0 ;
long time_update =0 ;
byte index = 1 ;
float temp_max_tempo ;
float temp_min_tempo ;
float array_max [size_array];
float array_min [size_array];
float temperature_loop ;
float global_max_val ;
float global_min_val ;
/************ Global State ******************/
//Set up the ethernet client
EthernetClient client;
EthernetClient client2;
Adafruit_MQTT_Client mqtt_Local(&client, Local_SERVER, Local_SERVERPORT, Local_USERNAME, Local_KEY);
Adafruit_MQTT_Client mqtt_AIO(&client2, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
// You don't need to change anything below this line!
#define halt(s) { Serial.println(F( s )); while(1); }
/************************* Input Setup *********************************/
//#define adresseI2CduBME280 0x76
//Adafruit_BME280 bme;
//unsigned long action = 0;
DFRobot_SHT20 sht20;
/****************************** Feeds ***************************************/
Adafruit_MQTT_Publish Local_publi_temperature = Adafruit_MQTT_Publish(&mqtt_Local, Local_USERNAME "/feeds/temperature");
Adafruit_MQTT_Publish Local_publi_humidite = Adafruit_MQTT_Publish(&mqtt_Local, Local_USERNAME "/feeds/humidite");
Adafruit_MQTT_Publish Local_publi_max_temp = Adafruit_MQTT_Publish(&mqtt_Local, Local_USERNAME "/feeds/max_temp");
Adafruit_MQTT_Publish Local_publi_min_temp = Adafruit_MQTT_Publish(&mqtt_Local, Local_USERNAME "/feeds/min_temp");
Adafruit_MQTT_Publish AIO_publi_temperature = Adafruit_MQTT_Publish(&mqtt_AIO, AIO_USERNAME "/feeds/temperature");
Adafruit_MQTT_Publish AIO_publi_humidite = Adafruit_MQTT_Publish(&mqtt_AIO, AIO_USERNAME "/feeds/humidite");
Adafruit_MQTT_Publish AIO_publi_max_temp = Adafruit_MQTT_Publish(&mqtt_AIO, AIO_USERNAME "/feeds/max_temp_2");
Adafruit_MQTT_Publish AIO_publi_min_temp = Adafruit_MQTT_Publish(&mqtt_AIO, AIO_USERNAME "/feeds/min_temp");
/*------------------------------------ Setup ------------------------------------*/
Serial.println(F("Debut programme"));
Serial.print(F("\nInit the Client..."));
Ethernet.begin(mac);
delay(500); //give the ethernet time to initialize
//bme.begin(adresseI2CduBME280);
sht20.initSHT20();
delay(100);
sht20.checkSHT20();
temp_min_tempo = sht20.readTemperature() ;
temp_max_tempo = sht20.readTemperature() ;
global_max_val = sht20.readTemperature() ;
global_min_val = sht20.readTemperature() ;
for (int i=0; i < size_array; i++)
array_max [i] = sht20.readTemperature();
array_min [i] = sht20.readTemperature();
if (!SD.begin(chipSelect))
Serial.println("Card failed, or not present");
return;
Serial.println(F("Setup all good"));
/*------------------------------------ Loop ------------------------------------*/
temps = millis();
temperature_loop = sht20.readTemperature();
global_max_val = -1000;
global_min_val = 1000;
MQTT_AIO_connect() ;
MQTT_Local_connect() ;
if((millis() - time_update) > interval_update_array) // Update of the current array position if temperature > / <
//Serial.print("Check value #");Serial.println(index);
if (temp_max_tempo < temperature_loop)
array_max[index] = temperature_loop;
temp_max_tempo = temperature_loop;
//Serial.println("UPDATE");
if (temp_min_tempo > temperature_loop)
array_min[index] = temperature_loop;
temp_min_tempo = temperature_loop;
for (int i=0; i < size_array; i++) // Check what is the biggest vallue in both array
if (array_max[i] > global_max_val)
global_max_val=array_max[i];
if (array_min[i] < global_min_val)
global_min_val=array_min[i];
time_update = millis();
if((millis() - time_array) > interval_array) //Switch of array position and reset of old values
index = index + 1;
if(index >= size_array)
index = 0 ;
temp_max_tempo = temperature_loop; ;
temp_min_tempo = temperature_loop; ;
time_array = millis();
if ( ( temps - action_Local ) > intervale_publication_Local ) //Publication toutes les x secondes sur le MQTT Local
action_Local = temps ;
Local_publi_temperature.publish(sht20.readTemperature()) ;
Local_publi_humidite.publish(sht20.readHumidity()) ;
Local_publi_max_temp.publish((float)global_max_val);
Local_publi_min_temp.publish((float)global_min_val);
if ( ( temps - action_AIO ) > intervale_publication_AIO ) //Publication toutes les x secondes sur le MQTT Internet
action_AIO = temps;
AIO_publi_temperature.publish(sht20.readTemperature()) ;
AIO_publi_humidite.publish(sht20.readHumidity()) ;
AIO_publi_max_temp.publish((float)global_max_val);
AIO_publi_min_temp.publish((float)global_min_val);
if ( ( temps - action_SD ) > intervale_publication_SD ) //Publication toutes les x secondes sur la carte SD
File dataFile = SD.open("Temp_log.txt", FILE_WRITE);
if (dataFile)
dataFile.println(temperature_loop);
dataFile.close();
Serial.println("Ecriture SD");
Serial.println("error opening datalog.txt");
if(! mqtt_AIO.ping()) // ping the server to keep the mqtt connection alive
mqtt_AIO.disconnect();
if(! mqtt_Local.ping())
mqtt_Local.disconnect();
/************************* Voids *****************************/
void MQTT_AIO_connect()
int8_t ret;
// Stop if already connected.
if (mqtt_AIO.connected())
return;
Serial.print("Connecting to MQTT AIO... ");
while ((ret = mqtt_AIO.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt_AIO.connectErrorString(ret));
Serial.println("Retrying MQTT AIO connection in 5 seconds...");
delay(5000); // wait 5 seconds
Serial.println("MQTT AIO Connected!");
void MQTT_Local_connect()
int8_t ret2;
if (mqtt_Local.connected())
return;
Serial.print("Connecting to MQTT Local... ");
while ((ret2 = mqtt_Local.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt_Local.connectErrorString(ret2));
Serial.println("Retrying MQTT Local connection in 5 seconds...");
Serial.println("MQTT Local Connected!");
