Erreur de compilation pour la carte Arduino/Genuino Uno
Bonjour les amis,
J'ai qq soucis j'aimerai bien afficher l'heure sur mon LCD avec ce code, lorsque je fait les test de compil j'ai le message "Erreur de compilation pour la carte Arduino/Genuino Uno":
#include <LiquidCrystal.h>
#include <DS1302RTC.h>
// Init the DS1302
// Set pins: CE, IO,CLK
DS1302RTC RTC(6, 7, 8);
// Init the LCD
// initialize the library with the numbers of the interface pins
// lcd(RS, E, d4, d5, d6, d7)
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// Setup LCD to 16x2 characters
lcd.begin(16, 2);
// Activate RTC module
digitalWrite(DS1302_GND_PIN, LOW);
pinMode(DS1302_GND_PIN, OUTPUT);
digitalWrite(DS1302_VCC_PIN, HIGH);
pinMode(DS1302_VCC_PIN, OUTPUT);
lcd.print("RTC activated");
lcd.clear();
if (RTC.haltRTC())
lcd.print("Clock stopped!");
lcd.print("Clock working.");
lcd.setCursor(0,1);
if (RTC.writeEN())
lcd.print("Write allowed.");
lcd.print("Write protected.");
delay ( 2000 );
// Setup time library
lcd.clear();
lcd.print("RTC Sync");
setSyncProvider(RTC.get); // the function to get the time from the RTC
if(timeStatus() == timeSet)
lcd.print(" Ok!");
lcd.print(" FAIL!");
delay ( 2000 );
lcd.clear();
static int sday = 0; // Saved day number for change check
// Display time centered on the upper line
lcd.setCursor(3, 0);
print2digits(hour());
lcd.print(" ");
print2digits(minute());
lcd.print(" ");
print2digits(second());
// Update in 00:00:00 hour only
if(sday != day()) {
// Display abbreviated Day-of-Week in the lower left corner
lcd.setCursor(0, 1);
lcd.print(dayShortStr(weekday()));
// Display date in the lower right corner
lcd.setCursor(5, 1);
lcd.print(" ");
print2digits(day());
lcd.print("/");
print2digits(month());
lcd.print("/");
lcd.print(year());
// Warning!
if(timeStatus() != timeSet) {
lcd.print(F("RTC ERROR: SYNC!"));
// Save day number
sday = day();
// Wait small time before repeating :slight_smile:
delay (100);
void print2digits(int number) {
if (number >= 0 && number < 10) {
lcd.write('_');
lcd.print(number);
J'ai vérifier toute la connectique, ajuster les N° de pins en fonction des mes branchements...
Le message apparait même que la carte ne soit pas connectée bizar, bizar...
Par contre j'ai un doute que le code soit adapter à la UNO R3???
Pour info j'ai essayais de changer le type de carte par une "Arduino/Genuino Mega or Mega 2560" c'est toujours la même chose....
je ne sais pas se qui cloche ?????
Votre aide et avis seront bien accueillis.
Bien cordialement à vous.
voici le retour de compilation:
retour de compilation.txt (7.84 KB)
regardez l'exemple DS1302_LCD de la lib "ds1302rtc"
voici l'en-tete
#include <Wire.h> // Need for NewLiquidCrystal library
#include <Time.h>
sans ces 4 lignes , çà ne compilera pas
Bonjour et merci elektrax pour ce conseil,
En fait c'est un code que j'ai "bricolé" pour l'adapté a la uno mais a l’origine était prévu pour une méga...
effectivement j'ai supprimé les lignes qui ne me semblaient pas utiles, notamment "#include <Wire.h>" qui si je ne me trompe est prévu pour une liaison série que je n'utilise pas avec le LCD...
Je vais refaire un essai demain et je te dit ce qui en ai
Cordialement
Bonjour à vous tous
C'est bon j'ai réussi a faire tourner l’horloge
Pas sans mal des problème de librairies pas ajour enfin bon
question comment la mettre à l'heure, la date est ok mais pas l'heure ?
Merci à vous
