i am trying to download a tts library from GitHub to the Arduino IDE but i keep getting this error message, what am i doing wrong? (apologies if this is in the wrong category but i did not know which to put this in)
Welcome to the forum
You might not be doing anything wrong but the files in the .zip may be wrong
Please post a link to GitHub from where you are downloading the .zip file
It's probably not a library, but it's just some coder's work. Without a link, we can't tell.
here are the links:
and i also tried:
From the first link above
The eSpeak NG is a compact open source software text-to-speech synthesizer for Linux, Windows, Android and other operating systems
Which of these Operating Systems do you have on your Arduino ?
what do you mean?
Read the quote that I posted and note the Operating Systems that the software can run on.
Which Arduino board are you intending to use and can that board run one of the required Operating Systems ?
i am using the wifi mkr 1010
Can it run Linux, Windows, Android or another Operating System ?
are you asking about the arduino board or my computer?
The Arduino board as it is the Arduino IDE that you are trying to install the library to
i thought that arduino boards can't run operating systems
They can't, but that is the point
The software that you are trying to install is not a library it is
It requires an Operating System which your Arduino board cannot run
ohhh... that makes more sense. so how do i find a real library?
A Google search sounds like a good start but don't hold your breath
thanks for the help i really appreciate it
Glad I could clarify what was wrong
Good luck with your project but don't expect too much trying to get TTS working on your Arduino
