I have the download and add zip file of TTS.h library Text to Speech on arduino - Steps2Make from the above link and also make some arrangement shown in the link. but I have got error "Error compiling for board Arduino/Genuino Uno.
". I think it errors in the TTS library. I search for the new TTS library and also try to resolve this error. But i facing a problem.
So how can I resolve this error?
Invalid library found in C:\Program Files (x86)\Arduino\libraries\TTS: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\TTS
It's a really bad idea to install anything to the Arduino IDE installation folder (C:\Program Files (x86)\Arduino). The reason is that every time you update to a new version of the Arduino IDE, everything will be lost. The correct place to install libraries is {Arduino sketchbook folder}/libraries, where {Arduino sketchbook folder} is the path shown by File > Preferences > Sketchbook location in the Arduino IDE.
Better yet, don't manually install libraries. If you use the Arduino IDE's Sketch > Include Library > Add .ZIP Library to install libraries, they will automatically be installed correctly to the right location, which would have saved you from this error.
pert:
Better yet, don’t manually install libraries. If you use the Arduino IDE’s Sketch > Include Library > Add .ZIP Library to install libraries, they will automatically be installed correctly to the right location, which would have saved you from this error.
Sir, I follow the same processor but this time got the error <C:\Users\SImtest Dynamics\Documents\Arduino\libraries\TTS/TTS.h:28: error: ‘byte’ has not been declared>
In this link, they use 1sheeld and temperature sensor and got audio signal on mobile.
But I want laser sensor data on my Bluetooth headphone or Bluetooth speaker. For this, I have Arduino Uno, Bluetooth headphones, and one laser sensor and I purchase the Sparkfun RN-52 Bluetooth module.
So Sir, how can I get audio data on my Bluetooth headphone?
