Error adding floats
Hi all.
I'm doing some maths to extract some float values stored as ascii in a byte array from another system.
When I extract (say) the 10ths value from the array and add it to the current integer total I get an erroneous value from the add function.
1000.000 + 0.900000 = 1000.900024
                  float a=1000, b=0.9;
                  Serial.printf("Sanity Check %f\n",a+b);
Why would this be happening, and how can I get the results I need?
Cheers,
Jim
Read the topic:
"How to get the best out of this forum
And clicking on < code> in the toolbar, post your complete code.
This way we will better understand your difficulty and be able to help you better.
Which arduino are you using?
Hello jimbo182
Welcome back.
The Arduino is an MCU and has no FP unit on board.
All FP operations are emulated, which leads to "errors".
hth
Float values are not exact and you can expect only 6 to 7 of the digits in the decimal representation to be useful.
Here, the digits "24" are simply an artifact of how Serial.print() converts the stored binary value to decimal, and must be ignored.
Hi - I'm using the ESP32 in this case, programming in the Arduino environment using VS code.
I did post the offending code using the code section.
No, the results of the software and hardware calculations are identical.
Thanks for all the replies.
I am only interested in three places of accuracy - is there a cheap way to round the results when performing addition etc so as to avoid the errors?
Cheers, Jim
More detail than you want, but should be required reading for anyone using floating point.
Use Serial.print(value, 3)
or
Serial.printf("Sanity Check %8.3f\n",a+b);
Thanks.
Where's the code that uses the results? How do you use the results?
The cheapest way to do it is to let it calculate as it will and use just the three significant figures/ three decimal places, or whatever at the end of the calculation.
If your calculations depends on/is affected by the least significant bits of error, you may need to pay more attention to numerical methods
Errors in floating point operations cannot be avoided. They must be understood, and your program has to be written accordingly.
If you need higher accuracy in your calculations, use type double instead of float, where you get 15 to 16 digits of accuracy in the decimal representation. AVR-based Arduinos like the Uno, Mega, etc. do not support type double, by default.
On a ESP32, convert it to double as soon as possible and do all the calculations with double.
double a=1000.0;
double b=0.9;
  Serial.print(a+b,16);
void loop() {}
Result:
Sanity Check 1000.900000
1000.8999999999999772
This is not a fair test, because the compiler might do the calculation.
