I'm new to this so I'm hoping it's just something dumb...
I'm using IDE 2.2.1 and a Nano Every board and uploading code that compiled fine and when it's done uploading I get this:
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
Any guidance you could provide would be appreciated.
Here's the code I'm uploading:
#include "ServoEasing.hpp"
ServoEasing servoTop;
ServoEasing servoBottom;
const int action_pin = 2;
int location = 31;
// Below numbers should be adjusted in case the facemask does not close/open to desired angle
int bottom_closed = 107;
int top_closed = 167;
int bottom_open = 20;
int top_open = 20;
pinMode(action_pin, INPUT_PULLUP);
servoTop.attach(9);
servoBottom.attach(10);
setSpeedForAllServos(190);
servoTop.setEasingType(EASE_CUBIC_IN_OUT);
servoBottom.setEasingType(EASE_CUBIC_IN_OUT);
synchronizeAllServosStartAndWaitForAllServosToStop();
int proximity = digitalRead(action_pin);
if (proximity == LOW)
if (location > bottom_open) {
servoTop.setEaseTo(top_open);
servoBottom.setEaseTo(bottom_open);
location = bottom_open;
delay(600);
servoTop.setEaseTo(top_closed);
servoBottom.setEaseTo(bottom_closed);
location = bottom_closed;
delay(600);
This is because the NanoEvery does not use a bootloader, and the memory is not divided into flash and boot segments like the AT328 devices.
The warning was due to an issue with avrdude not recognizing this situation, but the upload proceeded as normal.
avrdude: AVR device initialized and ready to accept instructions
This has since been fixed in avrdude.
avrdudes:main ← MCUdude:main
opened 02:14PM - 29 Dec 21 UTC
This PR adds support for the @ElTangas' jtag2updi programmer and brings some imp… rovements too:
* Baudrates higher than 115200 are now supported
* jtagmkii.c has been patched to accept devices with `has_updi=true`. This "hack" was borrowed from Arduino's implementation. They have a board, the Arduino Nano Every, that uses the jtag2updi as its programmer.
~There exist other non-critical "problems" too, like the `avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description` error you're always getting when programming a target (see https://github.com/ElTangas/jtag2updi/issues/54), but I haven't been able to find an elegant solution to this.~
Also been solved
Closes #517
The megaavr core uses an older version of avrdude which has the issue
megaavr
avrdude: Version 6.3-20190619
MegaCoreX uses a more recent version, and does not give the warning message
MegaCoreX
avrdude: Version 7.1-arduino.1
