Error: avrdude: stk500_getsync() NEED HELP PLEASE
I get this error for a clone of ARDUINO ONE. Help would be greatly appreciated:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\cycla\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM8
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x78
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
  • :white_check_mark: I have the correct CH340 driver installed (board shows up as COM8).
  • :white_check_mark: Different USB cables and ports tested.
  • :white_check_mark: Bootloader is present (L LED blinks on reset).
  • :white_check_mark: Tried both “Uno” and “Nano (Old Bootloader)”.
IDE VERSION: 2.3.6
Hi, @alex235363
Welcome to the forum.
Have you been able to program with the IDE successfully with that board at all, and with other controllers?
Have you selected COM 7 in the IDE?
Its trying to use com8.
Tom.... :smiley: :+1: :coffee: :australia:
Thanks for the reply. I haven't been able to program correctly with it. It says COM-8 because I manually changed it to com 8 in device manager and I forgot to write com 8 instead of com7 in the forum (the text was copied at a different time). Basically the com in the device manager, always matches the one in the ide. Sorry for the misunderstanding.
